Question about Car Audio & Video
My amp works but something is wrong with the wiring or something.
Ive had my amp for about a month and it just quit working all a sudden. I tried my amp in my friends car and it works fine. but when i put it in my truck it will sometimes will ficker on off when the truck is cut on. ive took my radio out and checked it out and all my wiring. So what could be the problem??????
    Problem Solver:
  • 7 Answers
There is a loose connection on the power supply going to your amp,check the fuse holder
Posted on Jan 08, 2009
8" compact subwoofer not working it was installed
post more information about your amp. its likely the vibrations moved something in the amps, or buttons.
Oct 10, 2013 | Alpine Swe-1000 8" Compact Subwoofer...
800 watt mono block sony xplod amp blowing my dual coil 1500 watt subs
if the wiring to the sub is correct, then you have something wrong with the amp itself... something is power surging to the subs which is causing them to blow
Aug 25, 2012 | Car Audio & Video
Hi Ive brought a Sony 2dx-gt590ui and sub and amp got it all wired up but the sub only works on radio can you tell me what Ive done wrong???
You can try to connect the remote power wire at amplifier to main power with a jumper wire if sub works with cd and other sources.Then check remote wire from behind radio or you can simply connect remote power wire to a another switched power source from fuse panel.Just make sure its a clean dedicated power source from fuse box and make sure it turns off amp..Goodluck
Sep 23, 2011 | Car Audio & Video
I have a problem with my amp in my Jeep. At first I thought it was a bad cable because one day after it had sat for two months it quit working and will always blow the fuse in the amp. tried diff grounds....
check the switch power wire. the blue small guage wire to the amp and check to see your not supplying to much voltage there. also check to see the wiring to the speakers are not bridged in the wrong way or touching each other inside your box
Nov 21, 2009 | 1998 Jeep Cherokee
New amp
Something is def. wrong. did you check the fuses on the amp after the light went out? probly have a bad connection somewhere. check ground wire and power make sure they have a good connection and arent cut up and shorting out.
Oct 21, 2009 | Pioneer Car Amplifier GM-7100M - Mono Bass...
Jbl am in protect mode
if it goes in protect mode means ur amp is turn up to high or it is over heating so it protectn it from fryn ur amp try to adjust it down
Jul 12, 2009 | JBL BP1200.1 Car Audio Amplifier
Instrument panel guages quit. Getting 'No Bus' error in odometer.
That wire needs to be hooked to the factory radio , part of the PCI bus - serial data communication network . I know on GM vehicles if the radio isn't hooked to the bus the vehicle will not start an run . Don't know if Dodge vehicles are that complex . http://www.dodgeintrepid.net/31-car-audio-video/58412-why-pci-bus-connection-radio.html http://www.carsondemand.com/IDLdocuments/Learning%20Guide/4450-t9r0k5io6vxazm80x5ire9zj4.pdf
You mite call a aftermarket installer an ask or the dodge dealer
Feb 28, 2017 | 2005 Dodge Ram 1500
No spark
Is the coil pack working at all? It could just be a simple ignition ground gone bad, or even a power wire corroded to badly. Also, clean the connections between the plugs and wires, and also the coil pack and wires.
Sep 10, 2008 | 2001 Ford Escort ZX2
Lanzar Vibe 1200D protection light
You will need to show it to a service technician as it seems the output section has blown so it remains in protect mode. One reason (could be) that the input to the amp was high and may have been clipping for some time before the amp decided it could take it no more
Jan 14, 2008 | Lanzar Vibe 1200D Car Audio Amplifier
Amplifier stop working
this problemis your amp is dead powerflux you need the asistance techinic
May 27, 2007 | Crunch BlackMaxx BLX2000D Car Audio...
Car Audio & Video Logo
76 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
