Question about Acer AL1916W 19" LCD Monitor
Acer monitor cable/ accessory
Happy new year Jemmyrash I have an Acer monitor, is there a cable that one connection is the DVI to monitor and the other connection is Video in?> I would like to use the acer monitor as my video out so I can out put a digital receiver. I work with Final cut pro. Is there a cable like this?
Carlos :)
  • Carlos Mir
    Carlos Mir Jan 20, 2009
    Can you provide an example or brand or link to the 2 display adapter?
  • 47 Answers
The best way to do what you are describing it to have 2 display adapters installed...and use your 1st display for your monitor and the second for the digital receiver..... then you would optimal performance and have more video memory for each display allowing faster productivity
Posted on Jan 08, 2009
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Feb 21, 2011 | Acer X193W LCD Monitor
Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Jan 30, 2011 | Acer AL2216W LCD Monitor
You may have problem in the logic board, it uses surface monted components no much chance for DIY repair.
Service manual; http://elektrotanya.com/?q=showresult&megnev=Acer&megnev2=AL2216W&kategoria=monitor&kat2=all
The cases these days are hard to open, they use plastic finger hooks types, they go in easy but real hard to remove without damageing them.
Use thin flat blade to crack open at the bottom edge so the scratches will not be so noticeable, and work your way around, look out for cables attached to the front bezel also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Hi, I have an Acer AL1715s monitor and the VGA cable is cut about 5 cm from the backside. The monitor has no VGA input on the back but is connected inside with a 13 pin connector. I have to make a new...
you have a rgb connection or a dvi connection.
do not engineer your own version of a vga/dvi cable.
just go and buy a new cable, which should be cheap
here is a service guide for this monitor
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/s.g_al1715_book.pdf
Oct 15, 2010 | Acer AL1715 17" LCD Monitor
Are acer monitors unable to pick up HD video inputs?
There are two types cable to connect to LCD Monitor. VGA and the other is DVI,ight need DVI cable it has flat pins and is larger than the VGA small round pin models.
Dec 21, 2009 | Acer X193W LCD Monitor
My Acer P205H shows up for 1-3 seconds before showing a black screen. Connected DVI Cable but is there a need to connect vga too?
Depending upon the video port/s you have on the graphics card, you need to connector one video cable, either the DVI or the 15pin DSub to the monitor.
Sep 12, 2009 | Acer AL1916W 19" LCD Monitor
New install Acer x223w monitor
You would only need that cable if the other end requires a VGA end. Happy Holidays
Dec 17, 2008 | Acer 22" X223w LCD Monitor
DVI connection to DVI port on PowerMac G4
DVI offers better picture quality since no DAC occurs.
But to most of us Analog VGA will do
Rifaa
Aug 02, 2008 | Acer X193W LCD Monitor
DVI cable not working
If you still have your old monitor plug it back in for a bit and load the drivers for the new monitor (from the disk which came with the new monitor). Right click on your desktop and choose properties and set your display resolution to something like 1024 x 768. Shut down the pc and connect your new monitor to it with the dvi adapter. If it is recognised ok you can then set the resolution from 1024 x 768 to the recommended amount for your new screen. The refresh rate is also important as some lcd screens only work at a certain level. There should be an auto switch on the monitor and if you press this it sets the display to optimum, - or should do.
Mar 21, 2008 | Computers & Internet
Connecting dvi cable straight to acer monitor
The cable box is probably outputting a resolution the monitor is not compatible with. Computer monitor and television resolutions are usually different, and not cross compatible in some cases.
For example, wide screen monitors are usually 16:10 aspect ratio, while TV is usually 16:9 aspect.
The AL2216wbd is a 1680x1050 display, while HD TV is either 720p (1280x720) or 1080i (1920x1080).
If your cable box is set to 1080i that would be too high for the monitor. You will need to set it to output at 720p, and even then you will probably get a vertically stretched picture since the monitor has a taller aspect.
Nov 15, 2007 | Acer AL2017 20" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
111 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
