Question about Ricoh FAX3900NF Plain Paper Laser
Fax Machine I have a Ricoh Fax 3500L. We got it used with out a manual and wanted to know how to remove the ID (I think that's what it is called) You know when you fax something at the top it says who it is from. I can't figure out how to remove it or to change the name. Thank you in advance
    Scholar:
  • 77 Answers
Although I could not find the manual for your specific model, go to the following site and download the manual for a model similar to yours. http://ricoh-usa.com/downloads/manuals.asp Similar models in the same family will generally use the same programing conventions. Pay particular attention to the RTI, TTI and CSI functions. Let me know if it was successful Ed
Posted on Jun 01, 2007
Who would I call to see why my fax machine on my 3 in one ricoh aficio mp 201spf fax stopped sending and receiving
what area do you live in?for the best service call Ricoh direct and they would help you. but you may want to check your phone connection. just plug in a good phone and see if it works. then replug your fax. good luck Tom
Mar 06, 2015 | Ricoh Office Equipment & Supplies
Ricoh 3310l fax shows error code 0390H in display. Anyone know what this means?
I've never seen a message like that with the 0390H code. There is no mention of that code in either the user manual or service manual. The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that problem.
If the new PCU doesn't fix the problem, you might want to try calling Ricoh for support, since their documentation doesn't mention that code.
Jun 11, 2010 | Ricoh 3310LE Plain Paper Laser Fax
How do I turn off the fax notification on a Ricoh Afico MP 3500
Most Ricoh multifunction printers have a set of parameter lists that control reports and journals. The parameters are set by using bit switches in the User Tools, and each machine has different switches to control different settings.
What kind of fax machine or printer do you have? The user manual has a list of all parameters and bit switches.
Jan 21, 2010 | Ricoh Aficio CL2000N Laser Printer
REMOVE ACCESS CODE
Enter in the user tools and select the password cancel or machine settings and set the machine.
Sep 24, 2009 | Ricoh 3310LE Plain Paper Laser Fax
Ricoh fax 120 please let me know how to put ricoh on automatic fax receiving while not in the office also when someone rings i can hear the fax sound from my ricoh
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} - Follow the next instructions to change the reception mode :
1. Press the [F2] key. “ this key is located on the left side of the Control Panel next to the key [12] from the left side and next to the [Memory Trans.] key from the rigt side ”
2. Press the left arrow key to select the reception mode “ this key is located under the Display of the Control Panel”
3. Press the [OK] key when on the display is displayed the mode you want.
note:as you sad you want the machine to reaceive faxes when you are out of the office, so the reception mode [Auto Select] is the most compaible mode for you.
The machine can treat incoming fax
messages and telephone calls in three
ways.
1.Manual Receive
- Use this mode if your line is shared
by a fax machine and a telephone
but you wish to answer all calls
yourself and decide whether they
are fax documents or telephone
calls. You must manually press the
[Start] key to receive a fax.
The machine will ring continuously
until you answer the call, so you
have to be near the machine at all
times. The Manual Receive indicator
is lit when the machine is in this
mode.
2. Auto Receive
- Use this mode if you have a dedicated
fax line. The machine assumes
all calls are fax documents.
It will ring once to alert you of an
incoming call, and then starts receiving.
3. Auto Select
- In this mode, the machine rings a
number of times. You can answer
the call while the machine is ringing.
If you do not answer the call,
the machine automatically changes
to receive fax messages.
Jul 11, 2009 | Ricoh Office Equipment & Supplies
I want to send a fax message using Brother 2820 fax machine, but I don't want the receiver to see my phone number when he receives the fax message print out. Is there any way I can do this?
The FAX machine will print the Tel number that has been programmed in your machine. It does not print on the basis of the caller ID received. So i think if you remove the number programmed in your fax machine
May 23, 2009 | Brother IntelliFax-2820 Laser Fax
How do you change the date and time on a Ricoh 3800L fax machine?
To change the date and time on a Ricoh 3800L:
Press the Function key, 6222291, Yes. When the date appears, use the asterisk (*) and pound sign (#) to change the month and to change AM or PM, and use the keypad to change the date, month, and time.
Press Yes Function when you've got it set and want to save it.
Dec 23, 2008 | Ricoh FAX3800L Plain Paper Laser
Brother 4100e Fax Problem - Caller ID won't work with Fax Machine
Usually, fax machines don't have caller ID capability.. If the sender's fax number appears on the faxes you receive, it's just that they have programmed it into their fax machine as a header.
Jun 29, 2008 | Brother IntelliFax-2820 Laser Fax
Ricoh 3500L fax machine
i think you are in manual mode.. try searching for an auto mode, or a big button to receive faxes.. ... in manual mode, the guy should usually ask (in a call) you to give you feed so you give him line by pressing some big button.. and you also need to always have paper.. otherwise it wont be done
Jan 03, 2008 | Ricoh Aficio CL2000N Laser Printer
Ricoh FAX3900NF Plain Paper Laser Logo
104 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
