Question about Dell Dimension 2400 PC Desktop
Unsure of what type of PCI expansion slot in dimension 2400
Hi. I'm thinnking of getting ADSL2+ and i'm going to buy a wireless modem/router for the broadband. I'm also going to need a wireless card for desktop like this* (it's Belkin). The belkin website said that it "fits any standard 32-bit PCI expansion slot". However i'm unsure whether my PCI expansion slot in my dell dimension 2400 is 8-bit, 16bit, 32bit or whatever. Please, i really need to know whether it is a 32 bit and whether or not the wireless card will work.
Thanking you in advance.
* http://catalog.belkin.com/images/product/F5D7000au/STD1_F5D7000au.jpg
  • 45 Answers
The dell dimension 2400's motherboard is a Dell (F5949) Motherboard. It has 3 pci slots and PCI slots are only 32-bits or 64 bits (PCIX). you should be good, you may of confuse it with the PCI-E speeds which is a different bus.
Posted on Jan 07, 2009
  • 42 Answers
You may have a PCI and a PCI express slot on your board but it should be really obvious which is which when you open your case. The bit rating is the max potential processing from that slot. From what you've described you should be ok with that card.
    Sergeant:
  • 290 Answers
8 and 16 bit PCI slots haven't been used in years so your slots would be 32 bit unless your PC is extremely old. That card will work fine.
2 Suggested Answers
renosean
  • 492 Answers
SOURCE: Unsure of what type of PCI expansion slot in dimension 2400 (2)
This machine will support up to 32bit maximum pci expansion card speed.  So it should work. http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/specs.htm
Wireless connection for e310
http://www.ebay.com/itm/100-TESTED-GUARANTEED-DELL-DIMENSION-3100-E310-MOTHERBOARD-JC474-WJ770-FAST-S-H-/321044602266?pt=Motherboards&hash=item4abfbfdd9a
The two long White expansion slots on the motherboard, are PCI Slots.
http://en.wikipedia.org/wiki/PCI_local_bus
If you have one available you can use a PCI Wireless adapter card,
(PCI Wireless Card);
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4389486&CatId=2701
OR,
A USB wireless adapter,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=357235&CatId=2704
Make sure your router is a wireless router, AND either it has a built-in modem, or your internet provider has provided you with one.
There are different setups, and different types of wireless.
Most common are DSL and Cable.
You can also go the satellite route IF available.
Regards,
joecoolvette
(A wireless N capability; wireless adapter card, or USB wireless adapter, has a range of 150 feet )
Regards,
joecoolvette
Jan 06, 2013 | Dell Dimension E310 PC Desktop
Hi there I have a Dell Dimension 3100, and at the moment it is connected to the internet via a cable to my BT home hub. Someone has told me all I need to do is get a wireless card and slot it in and then...
The card mentioned is a PCI wireless ethernet card card.
Open your tower and look at the motherboard, you should find anywhere betwee 3 and 5 pci slots
(Longish connector slots usually coloured white all parallel with each other)
A PCI card will slot into one of these, with its face (with areal on it) pokes out the back. You may
have to remove a small long panel secured by 1 screw from the back of your tower.
Once inserted, your pc will probably find it as you boot up and will ask for a driver disk. Put the disk provided in your optical drive and off you go.
You will then have to set up the connection between the PCI card and your router.
A bit easier would be to buy a Wireless dongle which just slots into a USB port, saves taking your pc apart. The rest of the hoop jumping is more or less the same.
Please note, its probably best to go for one with WPA-PSK security, WEP is a bit old now. Best to check what your router can accommodate.
If you're still not sure just type "PCI wireless ethernet card" and "Wireless USB adaptor" into ebay, you'll get loads of pictures of what you're looking for. You don't have to be a member.
Nov 28, 2010 | Dell Dimension 3100 PC Desktop
I have a Dimension 2400 Celeron desktop. Can I put in a wireless card?
Hello
Yes unless the PCI slots are already being used. Buy a Linksys or Dlink PCI wireless card and follow the instructions very carefully. You will be at some point opening the case. Make sure then power is absolutely disconnected. I'm assuming you do have a wireless network already? If not then you'll need to purchase a wireless router also.
Jul 28, 2009 | Dell Dimension 2400 PC Desktop
Modem bad on Dell Dimension 2400, Can it be replaced?
Ethernet port or dial up modem?
If it's the built in ethernet port, all you need to do is purchase a PCI ethernet card, disable the one that's built in in the device manager and you're good to go.
Thanks and please take a moment to give this solution a rating of fixya.
Mar 11, 2009 | Dell Dimension 2400 PC Desktop
Unsure if my wireless PCI adapter will fit in my dimension 2400?
You can get your systems exact specs on the Dell website under the support page. Hope this helps.
Jan 10, 2009 | Dell Dimension 2400 PC Desktop
Would there be any 32bit PCI expansion slots on an IBM windows98?
There are PCI slots, but the processor, ram, and video capabilities are far below what modern components expect. You probably could get the wireless card to work, make sure the manufacturer has drivers for Windows 98 before you buy the card.
In my opinion you should maximize your RAM. For a Dimension 2400, Dell's manual claims the min is 128 Mb and the max is 1Gb. Not sure how you got to only 32Mb of RAM but you'll see a big improvement in performance if you increase it.
Do you have an old IBM or a Dell (the area you posed the question in)?
Jan 08, 2009 | Dell Dimension 2400 PC Desktop
No ethernet port on older Dell desktop
Yes, all you need is a PCI ethernet card. You can pick them up rather cheap. Here is one. You basically plug it into an available PCI port on the inside of your computer. If XP doesn't automatically install it, just insert the included CD with the drivers on it and XP will do the rest. And remember to please give this answer a good rating of fixya. Thanks.
Dec 26, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop - Can't connect to internet
The NIC (network interface card) is integrated into the motherboard of the 2400 computer. Most likely that circuit is bad. To fix it you’ll have to replace the motherboard or purchase a NIC card and install it into one of the PCI slots on the motherboard.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 16, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
164 people viewed this question
Alun Cox
