Question about TruTech PVS12701 Portable DVD Player
I have a Tru tech portable dvd player model no. 12701C, and i cant get the lid to close or the dvd player to read the disk i believe because it turns on and just says "Open" on the screen...the dvd inside isnt spinning or anything...can you help me?
    President:
  • 563 Answers
Unfortunately, if the lid will not close properly, there is nothing you can do to fix that. Furthermore, if while holding the lid down the unit still shows "open" on the screen, the unit definitely needs to be repaired or exchanged. If you're in warranty, contact the manufacturer or the extended warranty company for the procedure you'll need to follow.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Posted on Feb 05, 2009
Can i add rabbit ears to my tru tech tv
read your instruc manual, download the instr. manuall from www.fitness.manualsonline.com or www. retrevo.com and read about if you can use it.
God bless you
Jul 12, 2012 | TruTech PVS12701 Portable DVD Player
The portable dvd player isn't spinning the disc and it isn't reading the disk it comes up with saying no disc even when there is a disc in the player
it could be that when you close the lid it does not press the switch that start the motor. <br /> if you see the disc spining maybe the laser head is not clean <br /> or the main board is broken <br /> If you want to fix the portable DVD write to me , <a href="mailto:doron_c21@yahoo.com">doron_c21@yahoo.com</a>
Aug 26, 2010 | Sony DVP-FX810 Portable DVD Player
My Tru Tech portable dvd player is only a year old and just quit working. When you insert a dvd, it comes up with it's typical, ''loading''. Instead of going to the movie it just satays on the loading...
It's a wonder that DVDs (or even CDs) are read at all; the positioning mechanisms reading them have to deal with millionths of an inch precision and anything can upset the alignment of them.
You might try cleaning the path of the laser with a simple 'cleaning disk' you can buy at electronics outlets. They are not expensive (<$10 US) and can sometimes restore operation by removing dust from the light path. If this doesn't help, I'm afraid you have just another Chinese dumpster item since the repair costs will likely exceed the replacement cost.
Jan 24, 2010 | TruTech PVS12701 Portable DVD Player
Only says loading when started, does nothing
Hi, your problem is the laser lens, it went sour. This device is coded to read only region 1 disks, when U attempt to read other regions disks it will read them once, 2 or 3 times but then... it will stop reading any disk regardless the region they are. Regions codes were implanted on disks to control piracy, so USA has region 1, Mexico 4, Asia I believe is 3 and so on. There are a total of 6 regions worldwide, U have to get disks matching the region U are from or, better solution... get a multi-region DVD player.
Jun 23, 2009 | TruTech PVS12701 Portable DVD Player
When I close the lid on the portable DVD player it says that it is open and wont read the disk, can you help
The lid closure interlock is not satisfied; it's located to the left of the open button (a tab on the top lid should hit the switch when closed)
Feb 21, 2009 | Coby TF-DVD7100 Portable DVD Player
Will not play the entire DVD
your dvd reading head is out of sync open the lid hold the button that is pressed when the lid is close now with your finger move the head till the screen say's no disk that should be right to the center place a disk in and hold the button with your finger and notice a red light under the disk rotating pressing the next of fast forward button watch the light go to the outside of the disk . it should go right to the end without making a noise and read the entire disk if not keep moving the head till it does . your problem should be fixed there is no other reason to read only a part of the disk other then the disk it self is dirty.
Dec 20, 2008 | Initial IDM-7110 Portable DVD Player
Does not read disk
My portable dvd player turns on and the disk does not spins but the screen turn light blue and does not read the disk
Aug 03, 2008 | Liquid Video MVBG45 Portable DVD Player
Not repsonding when closed
Every time I close my Coby TFDVD5000 Portable DVD Player I whait untill it is finished loading but then it says no disk. I took the back off to look at it, and I noticed that each time i close it the disk will spin untill the lens starts reading the disk. The problems started when i put a disk cleaner in, and i gess the lens was not dirty. Can you help me?
Jun 07, 2008 | Coby TFDVD5000 Portable DVD Player
"Open" written on screen
There is supposed to be a little plastic piece that pushes down a button that tels it that it that the door is closed that plastic piece is broken off. Look for it and glue a little piece of plastic on it, should fix it.
Jun 04, 2008 | Toshiba SD-P1600 Portable DVD Player
TruTech PVS12701 Portable DVD Player Logo
98 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
