Question about IBM ThinkPad T41 Notebook
IBM T41 Power issues?
I have an IBM T41 notebook computer, and it just recently quite powering on. I remove the battery pack and try to run it off the ac adapter alone and when I press the power button all the system lights flash quickly once, and then go off. Now when I try to power it on a second time the lights do not even flash, I have to unplug the adpater (from the laptop) and repeat the process and they blink again. The CPU fan does not come on so I know its not running. When the battery pack is inserted it will do the same thing only it will do it the first time and is non-responsive until I pull it out and repeat with the ac adapter. Could this be a mainboard failure? Any thoughts or potential solutions would be helpful.
    Genius:
  • 2,985 Answers
Could a MoBo failure or nothing more that a connector- solder problem. I depends on your abilities- take it apart and have a look or Send it to a repair shop or Take it apart- shudder put it back together then send it to the repair shop ;-)
Posted on May 30, 2007
Error 0176 ibm
Lots of issues with 0176 error. Could be caused by a dead cmos battery or the system thinks it has been tampered with. I found a couple of clues for you;
The T41 Hardware Maintenance Manual gives the following instructions in case of error 0176:
"Run BIOS setup utility, and save the current settings by pressing F10."
To get into BIOS, you need to press the F1 key when you see the splash screen. I suppost that the splash screen on a T41 will display a ThinkPad or IBM logo, and something similar to "to interrupt normal start procedure, press the blue thinkvantage button".
The idea that a new motherboard might be necessary comes from the T41 Hardware Maintenance Manual. It says that in case the first instruction, i.e. get into BIOS and save current settings, doesn't fix the problem, a new motherboard should be installed.
You could try the following:
Disconnect the AC adapter from the notebook, disconnect all other cables. Remove the battery pack. Press the power button ten times in one-second intervals. Then press the power button again, and hold it pressed down for 30 seconds. Then install the battery pack again, connect the AC adapter. Press the power button.
Re: 0176 Security - The system has been tampered with
The padlock came up after removing the BIOS-battery. It is a security-feature and cannot be bypassed.
Removing the BIOS battery does not remove the supervisor-password but locks the system, if one hat been set to protect the computer from illegal use.
So either try to get the SVP from the previous owner ore replace the board.
Mar 20, 2014 | Lenovo ThinkPad R60 Notebook
I want to remove bios password from IBM thinkpad t41
It is difficult to remove the Power On and BIOS password because the passwords are stored on an EEPROM chip.
For instructions on how to remove these passwords go to this link.
My Thinkpad - remove Power on Password
http://www.fixya.com/support/r4335050-remove_bios_power_password_thinkpad
Oct 23, 2012 | IBM ThinkPad T41 Notebook
I seem to be locked out of my ibm thinkpad t41 it wont let me switch it off or access ibm
Locked out how? With a password? You can't switch what off? Press and hold the power button until it shuts off or Just unplug it and remove the battery as a last resort. With no power source, it will cut off.
May 30, 2012 | IBM ThinkPad T41 Notebook
My IBM T41 laptop will not boot up! When i press the power button all the lights come on then only the crocked Z with a circle and d battery lights stay on! What should i do?
Try to remove your keyboard and fix it back. Seems like the keys are getting struck. You could search in Youtube of how to remove and fix the keyboard back on the laptop.
Nov 29, 2010 | IBM ThinkPad T41 Notebook
My ibm t41 just freezen and is not working at all
try to turn it off, pressing the power button for 10 seconds.
that should do it.
if that doesnt work, disconnect the ac plug, then remove the battery.
wait 30 seconds and start it again.
Apr 27, 2010 | IBM ThinkPad T41 Notebook
When starting the computer it does not boot up
Yes you are right it sounds like a power problem. I know for sure that desktop computers still can calculate time even when not in use for several days. They have an internal power supply charged from the time it's plugged in. I'm not sure that the laptop would be the same but it very well could be. So I would suggest to fully use up the battery power and leave the machine disconnected from the wall for about one week. That way there should be no internal power at all left in the machine. Then see if there is any improvement. However, before you do this one week marathon, see if the machine boots from CD or floppy because if it does then it could be a malware or OS problem in which case you will need to do a repair install of the OS. But it's unlikely. If it still won't work even after you try the power depletion, then I'd suggest to contact IBM, tell them everything you tried and see if there is any possibility for a replacement part. If any of my suggestions help, please do rate me. Thanks and good luck. Hope it all goes well for you.
Feb 13, 2010 | IBM ThinkPad T41 Notebook
Power shut down after inserting usb driver or usb mouth
This failure is caused by the usb drivers conflicts, power supply or failure on the motherboard - You can go to the IBM website and check it out more about this issue.
Sep 24, 2008 | IBM ThinkPad T41 Notebook
T41p boot issue
This sounds like a memory problem. Remove the memory, then try each chip one at a time in each slot. Try this and let me know.
Aug 24, 2008 | IBM ThinkPad T40 2373 Notebook
IBM T41 No power
No power or computer does not turn on. Additional information to why you may be recieving now power from the computer and/or why the computer is not turnning on.
Installing a pc computer power supply
Once no power supply is installed into the computer, place the new power supply into the computer and screw the screws into the back of the power supply.
POST troubleshooting steps. Note: Make sure your computer is turning on, if you press the power button and nothing happens (no lights, no sound, no fans, etc.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | IBM ThinkPad T41 Notebook
IBM ThinkPad T41 Notebook Logo
367 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
