Question about Intel Motherboard, 945GC, Core 2 Duo, S775, 800MHz, MATX, Max 2GB DDR2, PCIEX16,2PCI,FENET,Vid,Aud,SATA3Gb (BOXD945GCCR)
? Cannot tell if this motherboard has a raid controller
Received a HP computer for xmas. The specs. from HP do not indicate if the motherboard has raid controller (motherboard Foxconn MCP73M01H1 NAPA)
    Scholar:
  • 149 Answers
This motherboard has raid support...check with the bios settings
you can get raid drivers straight from foxconn
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=946GZ7MA-8KRS2H&TypeID=en-us0000004
nb choose the correct model
Posted on Jan 07, 2009
I have an Asus NCCH-DL motherboard constantly telling me i have 2 unknown devices and a Raid Controller without correct drivers in my Device Manager. AVG PC Tuneup said it found 2 incorrect drivers, but...
If you are not running raid then disregard that item. What operating system are you using? Assuming it is a Windows version, go to control panel, System, Device Manager, and look to see if there are any question marks (?) in yellow indicating a device driver has not been installed. If you do have a missing driver go to http://www.asus.com and get the drivers for your motherboard. If you found no indication of missing drivers in Device Manager then disregard the AVG PC Tuneup continue operating normally.
Sep 21, 2011 | ASUS NCCH-DL Dual...
Have a supermicro x6dal-tb2 motherboard, upgraded to windows 7. Can't find drivers for the Sata Raid controller. Help?
That driver will be issued by the RAID card manufacturer. If this is a software RAID controlled by the motherboard, your only hope is the latest BIOS firmware R1.0c:
Super Micro Computer Inc Products Motherboards Xeon Boards X6DAL TB2
Oct 19, 2010 | SuperMicro X6DAL-TG Motherboard
I have HP PROLIANT DL 380 (G4). I removed hard disk. Its start and few seconds restart again. its happening continuously. Any solution.
need to provide moreinfo.
is the server (prolaint DL380) constantly rebooting within BIOS mode or has it got to the stage of running windows.
The other item not mentioned here, is, IF the raid controller has failed, you will not see any disks initializing and would cause the system to continually reboot.
If it is an internal raid controller, it is part of the motherboard, you will need to contact HP to have it replaced.
If an pci related array controller .. i.e. separate to the motherboard, this will need to be replaced to see the HDD's.
Either way sounds like a hardware issue. Best to liaise directly with vendor to have the faulty components replaced.
Sep 28, 2010 | HP Compaq ProLiant DL380 G4 Server
Problem using VT6421 card as extra IDE port. I
First, you have to know if all driver components is installed in your computer, I'm talking about your motherboard make sure that all the drivers is installed.
View the status of your device driver.
If you are using Windows base Operating system like Windows XP open this menu:
Start Menu > Control Panel > System icon > go to Hardware tab > click Device Manager
Look for the question mark, it indicates a not working device.
VT6421 is a Serial Raid Controller
http://www.via.com.tw/en/products/peripherals/serial-ata_raid/vt6421/
Refer to the product specification of your motherboard, view this site:
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2314
Download and install the Device driver for The Raid Controller of your Motherboard
Jan 13, 2010 | Intel Motherboard
I cannot configure a SATA RAID 1 to mirror two WD HDD 1 TB
You sure you installed the ASUS RAID drivers when you installed Windows? Ya need to get the drivers off the ASUS disk, transfer them to a floppy, hit F6 when windows tells you to (during windows install...you only have a second or 2 to see the message!)) and use the floppy to install them. Might take a few tries to get it right.
Dec 26, 2009 | ASUS P5GD2 Deluxe Motherboard
Can a OPTIPLEX GX150 be upgraded to a p4 it was a cheap xmas present and just would like to know
No. Even if it could you could only use 1ghz of a 3 to 4 ghz processor. You will need to buy a new motherboard in order to do that. Here is the specs. let me know if it isn't the right computer.
http://www.bizrate.com/desktopcomputers/dell-optiplex-gx150-1-ghz-pentium-iii-desktop--pid306165798/
Dec 30, 2008 | HP Pavilion 8650C PC Desktop
M7NCD ULTRA raid drivers
If the SATA drive is operating in 3.0 Gbps mode and your motherboard can only support 1.5 Gbps mode, the drive will not be detected in BIOS or XP. Try jumpering the drive to SATA 1.5 Gbps mode. The label on your hard drive should indicate which pins should be shorted to achieve this setting; if not, look up your particular model on WD's website to find the manual.
Nov 05, 2007 | Biostar M7NCD ULTRA Motherboard
Intel Motherboard, 945GC, Core 2 Duo, S775, 800MHz, MATX, Max 2GB DDR2, PCIEX16,2PCI,FENET,Vid,Aud,SATA3Gb (BOXD945GCCR) Logo
905 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
