Question about Canon PIXMA MP830 All-In-One InkJet Printer
MP830 prints a black stripe down the back of the paper
Whenever I receive a fax or print something there is a heavy black line (about 1/4" thick") down the center of the back side of the page. If I print several pages in a row the line gets faint but is still there. After replacing the large black cartridge (#5) the unwanted stripe is darker to the point of making some of the info on the page difficult to read. I'm sure I'm wasting a lot of ink. Any ideas?
  • 3 more comments
  • Anonymous Jan 13, 2009
    I tried cleaning the nozzles and aligning the print heads, but I still have a heavy black line on the back of the sheet. I am going through black ink at an alarming rate. Any suggetions?
  • melissa315 Feb 17, 2009
    I have the same problem. I've tried cleaning the bottom plate (helps a little for a short while) and even around the cartridge area. Didn't help the line came back. Not sure what to do...any other suggestions?
  • Anonymous Feb 27, 2009
    Tried the cleaning where the cartridge goes. Didn't work. Any other ideas? Already bought another printer but would like to be able to use this one.
  • rherrman Mar 03, 2009
    i have the same problem
  • dana414 Mar 10, 2009
    I had the same problem with my printer. A professional came by and cleaned my machine for me and the problem has gone away. I'm pretty sure it will return at some point though. My last printer was the same model and after about a year of heavy use the line started appearing. I replaced it. The same time frame elapsed with the new printer before the problem developed. The printer seems to be made to stop functioning correctly after a short life.
The waste ink pads are full ..when the black line appears it is an indicator that the waste ink pads are full it is usualy because the printer has reached its life expectancy the solution is either buy a new printer or pay a tech about 170 dollars to repair it
Posted on Jul 19, 2009
  • 685 Answers
Try cleaning the cartridge and also where the cartridge goes.this may help if not let me know
Posted on Jan 08, 2009
I'M GETTING A THICK BLACK LINE DOWN THE MIDDLE OF MY. PHOTO AND UPLOAD. TRIED RE CALIBRATING WITH WHITE PAPER. DIDN'T WORK HELP
What printer do you have? Is the black line appearing on the paper when you print or when you fax/copy something?
If it is the latter, then there will be a mark on the optics glass that needs to be cleaned. Usually people using whiteout when wet causes this.
You will need to lift the cover where the paper goes through and check the glass
May 20, 2011 | Office Equipment & Supplies
Heavy black stripe on back side of every printed page
This is probably due to miss alignment, there is an option of test page which will be scanned to allign the cartridge, if ur's a all in one printer. This test page is printed at the first time and scanned instantly for first time operation.
Thankyou
Mar 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
When I copy or fax with my 4215 it leaves a thick black stripe down the middle of the page, but not when I print off the computer.
There should be somewhere for you to open the printer to see the area that reads the document (might be a small strip of glass), there could be something stuck on this area (tiny spec the width of your line), thus causing the lines on the scan and not the prints. I am not too familiar with that model, so that is the best I have for you. Hope it helps.
Aug 24, 2010 | HP OfficeJet 4215 All-In-One InkJet...
Printing on heavy paper gets a black vertical stripe
make sure all the catridges are fine and it is not getting leaked .if possible then remove the catridge and clean it and also when you give print command that time aslo you chosse paper type and size in printer properties option.
Jan 19, 2010 | Epson Stylus Photo 1290 InkJet Printer
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Stripe on receiving fax Brother MFC 7820N
I had the same problem, and I just fixed it.  It was a tiny little black dot which was stuck to the glass where the document feeder passes the paper to.  First you need to figure out where the line is on paper with respect to the paper, and just carefully run your finger on the glass to see if there is something on the glass.  I removed it, cleaned the glass, and anything which I run through the document feeder is now fine.  Hope this helps.
Aug 15, 2008 | Brother MFC-7820N Printer
I have a Panasonic uf-4100 that is printing,sending and receiving with a thick black line down the middle
We have a Panasonic UF-4100 and i am having problems faxing, it comes up with NO REC.PAPER 010
Jul 15, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Fax
From the manual:
If ink has run out while receiving a fax, if the paper size setting is incorrect, or if the paper type is set to a type other than plain paper, the fax is automatically stored in memory and <Received in memory.> is displayed. When the ink tank is replaced or the paper size/type setting is corrected, the stored fax is printed automatically.
Also, if the machine is in the process of something else (printing from computer, making a copy, scanning to computer), when a fax comes in it will be saved to memory, but it should print within a few minutes of becoming idle again.
May 08, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Brother fax
The drum cleaning blade is worn out. You must replace the Drum Unit.
Apr 18, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
1,160 people viewed this question
old marine
old marine
