Question about Frigidaire GLMV168K Microwave Oven
Frigidaire GLMV168CS1 Over the Range Microwave loses power
Sometimes after the start button is pressed or a preset cook button is pressed, the microwave runs for a few seconds and then cuts off and the display goes blank. I then have to reset the clock and date. Press a preset button or start button to start again and it may happen again or the microwave may work fine. Sometimes have to go through this 3 or 4 times before it works as it should. It heats fine when it doesn't stop. Otherwise, everything works great. It is about 4 1/2 years old. Thanks for any help.
  • sailaway58 Feb 15, 2009
    I have the same problem and the thing had done it off and one for a long time. It now wont cook at all.
    I cannot find an answer and if I buy a new one it will not be a Frigidaire if I can't fix this problem
  • William Miller
    William Miller May 11, 2010
    This may be a bad connection or it may be a bad magnetron generating electrical interference that is disrupting and resetting the controller.
    One way you or someone you know can test it is to do the following:
    1. Unplug the microwave or turn off its breaker.
    2. Open the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires.
    3. Plug the microwave back in.
    4. Put a few cups worth of water in a microwave-safe container and place it inside the microwave.
    5. Run the microwave for about 1 minute or so on full power.
    6. If it does not fail, try it several more times. When the water boils, change the water and try again.
    If
    it still does not fail, I would recommend that you put it all back
    together and keep using it until it fails more consistently, then
    repeat this test.
    While a microwave should never be left
    unattended, it's even more important when one is exhibiting a failure or any odd behavior.
    So play it safe and stay with it while it's running.
    Let us know what you find out.
3 Suggested Answers
MicrowaveSvc
  • 9086 Answers
SOURCE: magicchef over the range microwave loses display and power
It sounds like your magnetron is overheating and its thermostat is resetting.
Try it with a cup of water in one corner and see if that helps.
Otherwise, most manufacturers have a warranty of several years on the magnetron.
For info on that, visit http://www.magicchef.com/home.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 08, 2007
MicrowaveSvc
  • 9086 Answers
SOURCE: I have a Frigidaire Gallery
Unless you've had the magnetron replaced recently, I'd say you have a bad connection on the control panel / circuit board.
We repair these for customers nationwide with our guaranteed $39.95 service.
We have full details, plus critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
Posted on Jun 08, 2008
How do I change the power level?
Usually, power level is selectable using the keypad.
Jan 03, 2016 | Samsung 1.8 Cu. Ft. Over-the-Range...
Cannot unlock the display panel
Elise,
So I'm understanding that the lock icon stays on no matter what you have tried. I would try pressing and holding the START/STOP button for 5-10 seconds to see if it changes. I don't know how long you've been leaving it unplugged for when you do unplug it, but i would suggest at least 3-5 minutes. If these don't work what I would do is either contact the manufacturer or maybe even a local authorized technician. This way they would be able to assist and possibly have some more suggestions or be able to find and solve the issue for you.
-Best regards-
Jan 16, 2014 | Frigidaire FFMV164LS 1.6 Cu Ft 1,000 Watt...
Hello, I have an AEG microwave, 6 years old. When I turn the button to chose the cookingtime and the WATT , the display shows what I choosed so thats OK. When i then press the start button the microwave...
This can be due to wrong choice or fault in the power supply ,main board or the magnetron.
You should try with a preset selection and if the microwave works then the fault relates to correcting the power to time settings.
Check out with microwave cooking tips.
Feb 01, 2013 | AEG MC143EUX 750 Watts Microwave Oven
My microwave is completely dead. I have checked the fuse in the plug and it is fine. Any suggestions?
What you are to do to solve the problem is to do a general troubleshooting on your oven below are instruction to follow.
The Microwave is a counter top model with a variety of preset cooking options, including timed cooking at a variety of power levels and sensor-cooking settings for popcorn, rice, beverages and single-serving reheating.
The sensor cooking and reheating features detect increasing humidity levels inside the microwave and automatically adjust cooking time for various types and amounts of food. This microwave also includes a turntable and an electronic control panel.
Instructions below are step by step solution for your oven
  1. Check to see if the microwave will start. If it will not start and the display panel is blank, you may have a power problem. Unplug the microwave and then plug it back in, making sure that all three prongs of the power cord are fully inserted into the wall outlet. If this doesn't work, check your home's fuse box. Reset the circuit breaker to restore if necessary.
  2. Ensure that the microwave door is fully closed. Press the Clear/Off button to cancel any previous cooking instructions. Re-enter your cooking program, including cooking time and food weight if necessary, and press Start.
  3. If "Err" appears on the microwave display, press the Clear/Off button and reenter your cooking program. The "Err" message will appear during the sensor-controlled programs (Popcorn, Rice, Beverage or Reheat) if the door is opened before steam is detected or if no steam was detected within the maximum amount of time allowed by the microwave. Be sure to leave the door closed during these programs, at least until time is shown counting down on the display panel.
  4. If your control panel will not work or if an "L" is displayed on the screen, press and hold the Clear/Off button for a full three seconds to unlock the control panel.
  5. If your sensor reheat program is resulting in under- or overcooked food, first try decreasing the amount of food in the microwave; the sensor programs are designed for single servings of food. The sensor reheat function works by measuring humidity inside the microwave--do not use a tightly-covered dish with this setting because no moisture will be able to escape and the food will overcook. Be sure that cooking containers are dry; moist containers will increase the humidity in the microwave and mislead the sensor, resulting in undercooked food.
  6. If your turntable is not rotating, first check to ensure that your food container is positioned so that it can freely rotate without hitting the microwave's interior walls; using a smaller food container can fix this problem. If the turntable still will not rotate, lift the turntable from its support and replace it carefully, ensuring that it rests evenly on its support.
Good luck.
Thank you and thanks for using fixya.
Nov 23, 2010 | Neff H5470N0GB Microwave Oven
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
Frigidaire GLMV168CS1 Microwave - Sensor Error
If you are handy take it apart. Somewhere inside is a small switch that the door activates. Switch might be broken or a small plastic actuator might be broken. What do you have to lose at this point except time?
Jan 09, 2009 | Microwave Ovens
I have a Frigidaire Gallery Series over the range Microwave Oven model# GLMV168CS1. The issue I am having is that when started, sometimes it runs for a few seconds and stops, the display shows stars, and...
prototech@usa.net
May 30, 2008 | Frigidaire Microwave Ovens
Frigidaire GLMV168K Microwave Oven Logo
223 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
