Question about Thermador SGS36GS Gas Cooktop
Clogged up burners
My burners on my hot point gas range is clogged up from months and months of build-up can u help me
2 Suggested Answers
textonor
  • 130 Answers
SOURCE: Burner with intermittent feature won't light once hot; spart OK - - no gas.
mdpaul, sounds to me like 1 of the burner switches for the ignition is sticking. There is a small area where the switches turn to that shuts down the ignition. If the switch has failed from heat or is out of position, this can cause this issue. The switch is designed so when you turn the knob it closes the contact. The switch has to be locked into postion on this model. There is a push fit type retainer that locks this down. Pull the knobs off and turn with a pair of plyers to see if one is moving around. If so then with a deep socket, see if you can tighten the retainer by pushing down on it. Hope this helps.
Posted on Feb 03, 2008
My Viking Range top has 4 burners and the automatic ignition on the left two burners do not wok. Can hear clicks and gas but no ignition. Can manually lite them. Any ideas?
Sorry to read about your problem, I hope this helps you out.
your lite tube may be clogged, or take a needle and clean the hole's next to the lite tube on the range grills..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 19, 2010 | Viking Cooktops
2 burners wont ignite
Hello there:
A burner doesn't work The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite. The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, either repeat the procedure or call a qualified appliance repair technician.
Jun 29, 2010 | Thermador SGS36GS Gas Cooktop
30 in. JGP336 Gas Cooktop: We have a GE model # JGP933SEK2SS gas cooktop. ...
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
May 18, 2010 | GE 30 in. JGP336 Gas Cooktop
All 4 Igniters keep firing after the burner is lit.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
ghhdf
May 02, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
We have a thermador 5 burner gas range top and the pilot light seems to have gone out. The burners don't go on but we smell gas. How do we re-light it?
Most gas range tops no longer have pilot lights but use an electronic ignition (sparker) to light the burner. Normally when you turn the burner on you should here a snapping or sparking sound, at which point the burner should ignite. Here is a link to the user manual for 36" - 5 burner Thermador rangetop...maybe this will help: http://dl.owneriq.net/a/ac64ae7b-1ed3-44a3-9235-e4dbd8fe4628.pdf
By the way, in the short term you could always use a match to light the burner. JUST BE VERY CAREFUL THE YOU HAVE THE MATCH LIT AND OVER THE DESIRED BURNER BEFORE YOU TURN KNOB TO START THE BURNER!!!!
Jan 15, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
Ge gas range about 7 years old delay in lighting
take burner cap off and clean all the gas ports with paper clip etc.it sounds like the gas is not reaching the spark.usually clogged with grease or soap.hope this helps .please rate my answer :)
Dec 08, 2009 | GE Cooktops
Cooktop igniter sparks but gas will not light
hello there. i can help you.
Jun 04, 2009 | Jenn-Air JGC8536 Gas Cooktop
No spark
Replace your Invensys U-67204-8 0+4 Module: http://www.toolbox.invensyscontrols.com/appliance/linkedElements/ElectronicSparkIgnition_SparkReignition.pdfwith a Tytronics 4 Point Re-ignitor #RI 120E-4: http://www.tytronics.com.au/__files/f/2792/4 Point Re-Igniter.pdf which has replaced the older Invensys Module on BlueStar Ranges like the RNB304BV1 - 4 Burner Range (also used in some Viking Ranges): http://bluestar-store.mwrc.net/en/product.php?product_id=40478 Call Prizer-Painter 800-449-8691 for instructions if not sure how to do this. Also, may want to do some cleaning first overall on the Burners and the Igniters - BlueStar Part #741801: http://bluestar-store.mwrc.net/en/product.php?product_id=37702 or replace if broken: http://www.bluestarcooking.com/bluestar-service-videos.html#
Apr 18, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Thermador SGS36GS Gas Cooktop Logo
24 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
