Question about Whirlpool LER5636P Electric Dryer
New Element, still no heat
I just put a new heating element in my whirlpool dryer and still no heat, which way do I go?
  • Phil Brantley
    Phil Brantley May 11, 2010
    Did you replace anything else and does the dryer tumble with no heat or does it do nothing?
  • Whirlpool Master
  • 8,220 Answers
Check the hi limit mounted atop the heating element chamber New Element, still no heat - cc59322.jpg
Posted on Jan 07, 2009
You probably need a new heating element. Type your model number + Heating element into Google search. and it should bring up several retailers that carry the part. It's not a hard job to do, just labor intensive. Unplug your dryer, remove the back plate, disconnect element wires (remember where they go or mark them with lettered pieces of tape) unscrew the element. Install: Put wires on new element, reattach element, reinstall back cover, and you're done.
Apr 05, 2014 | Whirlpool Dryers
Barrel turns no heat-new fuse-same-new element-same. Old element burned could new fuse pop and I need new one
Be sure to check for lint inside the filter housing and also vent blockage. 240 volts is going into the dryer. The motor runs on 120 so you might have a voltage problem. Heating element needs 240 volts. here is my video let me know if this helps:
Dec 21, 2012 | Kenmore Dryers
How do i change the element on a samsung dryer
Hello.
When the dryer just isn't getting your clothes dry anymore, the culprit is usually the heating element. The dryer part may look intimidating, but you can replace the heating element.
Step by step instructions
TOOLS NEEDED New heating element,Screwdriver, Needle-nose pliers.
1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
4 Unscrew the screws holding the element in place and pull it out.
5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Thanks.
Sep 26, 2011 | Dryers
How do you replace the heat element on a whirlpool LER8648 dryer?
Before replacing the heating element, check first the continuity of the thermal cut-off and the high-limit thermostat located on the heater box, the resistance of the heating element, and the continuity cycling thermostat located on the blower housing. Replace the heating element only when it reads open. Replace both the thermal cut-off and the high-limit thermostat should any one of them is found open. The cycling thermostat must have continuity between its thicker terminals; otherwise, replace it.
All of the above components are accessible through the rear of the dryer. Remove the rear panel by removing the screws securing i to the dryer cabinet. Replace the heating element by removing the screws attaching its housing to the heater box then securing the new heating element housing in place.
May 28, 2010 | Whirlpool Dryers
Heating element is out.
Instructions Things You'll Need:
  1. Step 1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
  2. Step 2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
  3. Step 3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
  4. Step 4 Unscrew the screws holding the element in place and pull it out.
  5. Step 5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
  6. Step 6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
  7. Step 7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Dec 01, 2009 | Kenmore 62602 Electric Dryer
I'd like to know how to change a heating element in my dryer (29' whirlpool) I'd like to know exactly how to take it apart and where to find the element. I'am not sure of the dryer #
first you nead to unplug the dryer,next you nead to remove the vent hose,next you nead to remove the back panal and the power cord cover,on the left side you will see the heater housing,at the bottom you will see the heating element,there are four wires,the two at the bottom are hooked to the element,you nead to pull them off,the other two wires are hooked to the high limit switch,you nead to pull them off,next there are two 1/4"screws,one on each side off the heating element,remove them,now pull out on the bottom of element,with element removed,remove the high limit switch from old element and put it on the new element,take new element and put it back in the heater housing and replace the two 1/4" screws,you will see that the two wires that go to the element are biger than the two going to the high limit switch,put the two wires to the element,now replace the two wires to the high limit switch,replace the back panal and the power cord cover,replace the vent hose,plug power cord in and check element out.
Nov 25, 2009 | Whirlpool LER5636P Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Installing a new heating element on my Whirlpool dryer.
shouldnt make a diff, the orange wire can only go in one place,adn the 2 reds make no difference.. the only thing you need to do is remove the thermostat from the oldelemnt and install it on the new heater
Dec 04, 2008 | Whirlpool LER5636P Electric Dryer
Keeps heating on cooldown
needs new timer switch
the timer swithc contains 2 switches one for the motor and one for the heating element, the element switch has fused closed. not reliably repairable,
even if open the timer, break apart the contacts, file them smooth, reassemble, will still lock up again
replacement is less than a new dryer
Sep 05, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
78 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
