Question about Cakewalk Music Creator 4
Playback is way off tempo
When i record an audio track its fine but when i click to play it, it sounds way to fast and higher pitched please help
  • Anonymous Jan 27, 2009
    i record a sound but when i play it back it is way to fast and high pitched
  • suzybsamari1 Mar 08, 2009
    tried and tried but it seems of no use. the first track is fine, but the second track plays back slower. it drags behind the first track and seems to get worse as the clip goes on latency all the way to safe. dithering set to none. sound card chosen for both recording and playback timing.enable driver mode to MME@128. enable both read and write caching. does anyone have a clue?
I had similar problem, mine played it back slower and lower pitched. http://www.cakewalk.com/Support/newfaq.asp#10
number 10 and 11 fixed my problem, hopefully it will help.
Posted on Jan 21, 2009
Cassette tape plays super fast
Sounds like the pinch wheel is not contacting the capstan correctly. It could become less pliable or mechanically not applying enough force to the capstan.
Jan 14, 2014 | Televison & Video
Hi folks :-) I'm affraid that we have started up wrong, but I hope we can fix it ! Problem: A band, we've made a que-track (everybody's playing and singing at the same time) now we've...
Real musicians do change tempo throughout a song, so its not necessarily a bad thing. As long as you like the sound it doesn't matter if you don't stick rigidly to a fixed tempo. Unfortunately you won't be able to fix the tempo after the initial recording so you'll have to live with it or re-record. If you need a click track to record along to, try recording yourself hitting drum stick together along to the already recorded track. As a human you can track small tempo changes much easier than a computer. If you need to create a count in, just copy and paste a section of this click track to the start of the track. I hope this makes sense!
Sep 20, 2011 | Tascam 2488 Portastudio Multitrack...
Playback is to fast
Oh wow dude,
it sounds like your bit rate and sample rate are out of whack. You should shoot an email to tech support cuz this is gonna need some more in-depth help than i can really get into here. But check your bit depth and sample rate first. They may be out of sync
Jan 27, 2009 | Cakewalk Music Creator 4
When i record somethin it is fine but when hit stop recording and
check out what sound card you have,then make sure that your card name is sloted as you playback output
Play back problem
At the top center of your screen right above the Play and Record buttons you'll see the tempo indicator. It will read 120.00 BPM or some number like that. Click on the 120.00. You'll get the number with up and down arrows to the right. Click on the arrows to increase or decrease tempo. Or you can hit the backspace ey and type in the tempo you want. Try changing it 10 beats at a time.
Jan 07, 2009 | Cakewalk Music Creator 4
Tempo change
click track on the play bar where u edit the tempo thers track and then fixed
Oct 28, 2008 | Steinberg Cubase SX3
No sound in playback (but can hear click track)
This might seem simple, but just to check: you have switched off the monitor on the track when you go to playback? With track monitor engaged, you will not hear playback, but will continue to hear the live monitor.
Sep 26, 2008 | Tascam US-144 Sound Card
GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Oct 15, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Problem with playback
Hi, I have the same audio interface. Alright, make sure that all of your effects are turned off. you probably (and most likely) have the "fx voice", "amp drive", "chorus" and "delay" effects turned on (bottom row). There is no way you should have distortion with tremolo & reverb on playback all the same time without the effects being turned on. the pop ticking could be produced by the buffer size. If youre using Sonar LE, you should tweek the buffer size until playback sounds smooth. I hope I helped! Good luck!
Aug 14, 2007 | Edirol UA-4FX External Sound System
Cakewalk Music Creator 4 Logo
161 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Anbes
Anbes
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
