Question about Lucent PARTNER18 Corded Phone
Lost power and need to reprogram lucent 18D.
Incoming calls answer in one ring and go to intercom.
Call in a vendor. Your system has lost all programming. Voicemail is goofed up to a point.....
The entire system needs to be reporgrammed.
Posted on Jan 14, 2009
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
Lucent Partner 34D phone system with 18D extensions
That doesn't sound good at all. I would first try powering down the system and waiting about 15 seconds or so before powering back up. If the problem remains, the processor was some how damagedand would be best if it was looked at by your vendor.
Sep 25, 2009 | Avaya Lucent Partner 616 Phone
LUCENT PARTNER 18D PHONE W/INTERCOM
Press an intercom button and dial the 2 digit extension number. This will ring the extension. To page the extension, press an intercom button and then * (Star) and the 2 digit extension number. This will page the phone.
Jun 04, 2009 | Lucent PARTNER18 Corded Phone
Lucent Partner 18D phone not ringing.
On extension 10 or 11
Press Feature 00
Left Intercom, Left Intercom, Right Intercom
Input your first extension that you want to ring.
Press desired line to ring until display say Immideate.
Press Right Intercom for next Extension.
Cheers.
May 19, 2009 | Lucent PARTNER18 Corded Phone
How can I change the number of rings before the answering system answers on our Partner 18D system?
On extension 10 or 11 press Feature 00, left intercome twice. #506, mode 1, line 01, 1
Do the same for all lines.
Cheers.
Mar 20, 2009 | Lucent PARTNER18 Corded Phone
I need to silence an extension on the lucent 18d telephone
From ext. 10 or 11, press Feature 00, left intercom (twice), right intercom (once), Dial ext. number of boss' phone. Lights on the line button will indicate ringing state for that line:
Green light - Immediate ring
Fast Flutter Green light - No ring
Slow Flashing Green light - Delayed ring
Press each line key until Fast Flutter Green light appears.
Press Feature 00 to exit programming.
Jan 05, 2009 | Lucent PARTNER18 Corded Phone
Incoming calls to office cause all phones to ring in classrooms
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Hope that helps
Dec 02, 2008 | Lucent PARTNER18 Corded Phone
Change te number of rings
I need to change how many rings it takes my system to answer . It is set for attendant , I need it to answer after 5 rings . I need this changed because I now have a answering service that is set up though my phone provider verizon to call forward after 4 rings Lucent partner 18d
Jul 18, 2008 | Lucent PARTNER18 Corded Phone
Lost programing
From extension 10.
you have to set the ringing.
feat 00
left intercom twice
right intercom once
enter ext number
touch the lines util they display how you want them to ring
feat 00 when done.
To set the feature to p/u a ringing call
feat 00
left intercom twice
right intercom once.
press: ** (then press lines in order 1, 2, 3, 4, etc)
then press ** again.
feature 00
repeat both for all extensions.
Mar 05, 2008 | Lucent PARTNER18 Corded Phone
Avaya Partner-18D office phone-After an intercom call, the receiver's phone rings
Try hitting the speaker button and intercom your boss. When you hit the speaker button to hang up, do you get the same thing? If not. It could be that the gray "clicker" switch that pushes down when you put the handset back isnt going all the way back down...
Let me know.
Dec 28, 2007 | Avaya 700340193 Corded Phone
Lucent PARTNER18 Corded Phone Logo
144 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Computer Repairing
Computer Repairing
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
