Question about Bernina Virtuosa 160
How is presser foot adjusted ?
I have lost my book for Bernina Virtuosa 160
I need explaination of
the presserfoot adjustment circle on the left end.
as the stiches are too tiny even tho I have stitch
length at 4.
  • Anonymous Mar 14, 2014
    STITCH LENGTH SHIFTING LEVER CRACKED APART
  • 202 Answers
If your stitches are tiny more than likely the feeddogs are not working correctly. More often than not its because the pivot points for the feeddog mechanism inside are gummed up,dirty and oily and they need to be cleaned. Your machine is in need of service. Does not really have anything to do with presser foot pressure especially if you have tried adjusting that to no availe.
It needs servicing.
Posted on Feb 13, 2009
  • 19 Answers
Presser foot height is 7.5mm and your feed dogs should be just a little shy of 1mm. IThat little knob merely changes the pressure on various materials and doesn't effect the stitch lenght. t sounds like your feed dog timing is a little off, rotate your handwheel and make sure they are moving in the right direction and down before the needle reaches the stitch plate. Remove the free arm cover that surrounds the carrier/bobbin area, there is a tiny little fan/traingle shaped gear that adjusts the feed dog direction and travel direction. Make your adjustments there and let me know! Couldn't really confirm if this was your problem?
Posted on Jan 17, 2009
  • Crayoneater Jan 20, 2009
    Pull the head cover off: That presser foot knob needs to be rotated all the way counter clockwise, then make sure the clip/spring is pushed all the way up to the elbow. Loosen the set screw on the presser foot shaft and put a pencil under the foot pedal (pencils are roughly 7.5mm) and then tighten it back up. Make sure those feed dogs are dropped!
I am still looking for the instruction book because it is here somewhere.
I will do trial and error method.
With forty years experience with Singer and Simplicty, but only two with Bernina
I will figure it out.
Posted on Jan 08, 2009
How do I adjust the presser foot shank on the Bernina 790
Difficult to understand your question. Why would you need to adjust a presser foot shank? It should either work on your machine or not. If it is the wrong presser foot, then you should get the correct one. The only adjustments I've heard being made on Bernina presser feet is to adapt a presser foot for an older machine to a newer machine, or vice versa. That involves making a permanent modification to the latch apparatus.
Mar 01, 2017 | Bernina Sewing Machines
What foot do I use to use the letters?
sorry but no idea , as I do not know what feet you have.
Nov 17, 2015 | Bernina Virtuosa 160
What is presser foot 37 for
The Bernina foot 37 is called the 'Patchwork Foot'. It is very useful in piecing quilt tops as the foot features an accurate 1/4" and 1/8" on both sides of the needle. It also has a 1/4" guide in front and behind the needle to allow accurate 1/4" stops and starts from the end of the pieces being stitched together.
An excellent reference guide is available on line at: http://berninainstitches.com/pdfs/Bernina_Presser_Feet_Guide.pdf
Oct 12, 2014 | Bernina Virtuosa 160
Bernina Virtuosa 150 Presser Foot Loose
try increasing the presser with the adjuster
Feb 10, 2014 | Bernina Virtuosa 150
Bernina 1230 Is there a way to adjust the pressure on the presser foot?
Just checked on U-Tube there are several video's there for problems, otherwise there is a spring at the top of the needle shaft that can be loosened. Good Luck!
Sep 28, 2017 | Sewing Machines
Bernina Virtuosa 153 Quilter's Edition sewing machine jams
Bernina Virtuosa 150 pressure foot does not go down quite all the way. The stitches don't go straight and are not even. PrewettOE
Apr 07, 2009 | Bernina Sewing Machines
Not feeding
Hi, most likely you don't have enough presser foot pressure. Adjust accordingly. Are the feedogs up and not in darning mode?
Rick
Mar 26, 2009 | Bernina Virtuosa 160
Can I loosen the presser foot so knits will not stretch
Pressure on the pressure foot can be adjusted on some machines by turning the knob on the top leftside of the machine directly above the needle assembly. Look for a knob that has fabric types on it and adjust accordingly. Also check your thread tensions.
Feb 09, 2009 | Bernina Virtuosa 160
Bernina Virtuosa 150 and uneven layers or bulk.
Hi, have you tried changing the pressure of the presser foot using the dial on the side of the machine? Fiona
Apr 11, 2008 | Bernina Virtuosa 150
Feed dog
It may need the feeddogs adjusted by a tech. We use a guage to measure the correct height. Even though visually it may look like they are moving ok they may be too low. You could use the top end of a needle and lay it alongside the feeddog at its highest point. It should be level. Also check the presser foot pressure. It may be set too high and not holding the fabric down. Good luck to you. Rick
Aug 05, 2006 | Bernina Virtuosa 160
Sewing Machines Logo
219 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
