Question about GE Profile¿ Energy Star® 22.6 Cu. Ft. Side-By-Side Refrigerator with Dispenser, PSS23MGS
Ge profile french door refrigerator is leaking water
Newly installed refrigerator is leaking water behind deli drawer after filter was put in and icemaker used
aborcass
  • 2651 Answers
SOURCE: Water freezing at bottom of refrigerator/Temperature not right
thats a water tank holding water dfor the dispensor, if everything in refrig is freezing quite possible that the water in tank froze as well, which would explain no water,
Posted on Feb 24, 2008
  • 17 Answers
SOURCE: I have ge profile refrigerator tfx25pr with
THIS MODEL DOESN'T HAVE A FILTER
Posted on Nov 19, 2009
woodchuck789
  • 4070 Answers
SOURCE: Refrigerator knocking noise
If it seems to be coming from underneath the unit it could be the compressor. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} That's usually mounts inside the compressor. Usually when the compressor cuts off. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Any other noise would be from a fan. One in the freezer behind the back panel and one under the unit where the compressor is.
Posted on Dec 29, 2009
  • 2525 Answers
SOURCE: GE Profile PSS26PSTB refrigerator ice melts inside icemaker
when you open the freezer door do you hear the fan blowing,you could have a bad evap fan motor,also if there's ice on the back wall you have a defrost problem,take off the inside back wall of the freezer where the ice is,you need to shut the control off and melt out all the ice,g.e. has had alot of problems with their computer boards which is a very expensive part number WR49X10152 around 200 bucks,look behind the kick plate on the bottom of the fridge and hopefully the tech sheet will be there,it will tell you how to put the machine into defrost,do this first before you melt anything out or before you touch the control,i think you click the lite switches together 5 times to make it go into defrost,it should tell you on the tech sheet,if ithe heater doesn't come on you need to read out the heater with a meter to see if it's good also read out the defrost thermostat,you have to check the thermostat while it's cold if the t-stat warms up you won't be able to check it, you should change out the t-stat anyway so you can cut the wires going to the t-stat,bypass it by connecting the wire directly to the heater and click the lite switches 5 times and the heater should come on,if it does leave the heater on to help you melt it out.so if the fan is running on the freezer side,click the lite switches 5 times and the fan should shut off and then you'll know it's in defrost,the heater should come on ,if the heater and t-stat read good and it won't go into defrost then it 's the board,also you can take out the board in the back of fridge ,unplug it first and look at the board for burn marks on the back or on the soldered spots,the board tells it when to go into defrost and melt the ice off the coil and like i said g.e.has had a lot of problems with the board,if you need any more help let me know,good luck
Posted on Mar 24, 2010
  • 19 Answers
SOURCE: Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Posted on Apr 05, 2010
GE Water Dispenser not working
Sounds like the water tank in the fridge section froze and split open causing a leak. Plus, the water feed line to the dispenser has frozen where it runs up through the freezer door- guessing your trimmer line only goes about 5" into the tube?
There is a water line heater kit that GE makes : Refrigerator Heating Element WR49X10173 .
Then, buy two quick disconnects 5/16" and about 10 feet of 5/16" plastic tubing- use the tubing and disconnects to replace the cracked water tank and you should be good to go... Refrigerator Water Line 5210JA3004K
Jul 03, 2016 | GE Refrigerators
Why is fridge not cooling?
Did you check to see if the auto defrost mechanism is working? Defrost heater any good? Ice in back of freezer?
Nov 26, 2015 | GE Profile PFSS6PKX Bottom Freezer French...
Water is collecting under the deli draw of my french door samsung refrdgerator
Is this the Samsung 4-door fridge/freezer with a round water-filter between the two drawers in the Refrigerator? a) Is your water-filter correctly installed in it's place? b) check where the water-drops are coming from: it could be the ice-maker - need to call Samsung service.
Sep 28, 2014 | Samsung Refrigerators
Ice under the deli drawer
it could be that u have a leak.. sometimes this happens when to much water is delivered to the ice tray and it overflows a little leaking into fridge. if that is happening then u most likely have a problem with the water inlet valve at the back of fridge, u can buy the part on line at appliancepros.com. good luck
Apr 13, 2014 | GE Refrigerators
I am continually getting a frozen sheet of ice beneath the deli drawer
Hi this is your water tank leaking due to it freezing from too low of temperatures, this particular model, had problems with damper assembly leaking, you will need to change out the water tank, but before you do that you need to fix the temperature problem, which requires adjusting or replacing the damper assembly in the back of the refrigerator at the bottom, You can install a bigger gasket or the new damper comes with one. If you need futher assistance let me know.
Sean
Mar 27, 2011 | General Electric Profile PFSS2MIXSS...
Samsung RFG297AA Thin Film of Ice Forming Under Deli Drawer
My be an air leak,wipe/check all seals on doors and make sure doors are closing tight on seals.
Jul 24, 2017 | Samsung RF265AA Bottom Freezer French Door...
GE Profile¿ Energy Star® 22.6 Cu. Ft. Side-By-Side Refrigerator with Dispenser, PSS23MGS Logo
46 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
