Question about Behringer POWERED MIXER, 20 CH, 400 WTS AMPLIFIER => Model PMX5000 Car Audio Amplifier
Monitor blowen, mixer-monitor channel went out
My band had just got a Behringer sound system. Powered micer,4 mics,speaker stands,2 fronts and 2 monitors. Wire's for all. The problem is that we got this from muscians friends. They say it's past the 45 day return period. It has been 3 months. The problem is the monitor channel went out on the board and a monitor went out as well right before a show. Please let me know what to do to get this fixed. Thank you, Gerald Gentry (
  • 55 Answers
Posted on Feb 21, 2009
My behringer pmp3000 doesn't seem to have much power to use my two peavey 12" speakers and use a mic. I have to push the gain and faders up more than I think I should have to, to get a decent level of...
Where do you have the gain control set on the Mic channel ?
If you have no issues with either the speakers or the Mic, and the gain control for the channel you have the Mic plugged into is set at a somewhat "normal" position, you might have a problem with the mixer itself.
Oct 28, 2013 | Behringer Pmp3000 16 Channel Audio Mixer
On stage live...I want to use the B205D as a personal monitor...the band uses a Yamaha EMX512SC 8 powered mixer on stage...What would be the correct connections to hear only my vocals in the B205D monitor...
Oh my... the EMX512SC does NOT have any "sub busses" there fore there is no way to just hear YOUR vocals where there are other vocal present. The way to connect this is to run YOUR mic into the B205D and then run the line output that is intended to run to other B205D's from the B205D into a channel of the EMX512SC.
Jun 24, 2011 | Behringer Active 150Watt PAMonitor Speaker...
How much price value
The Escort's integrated design allows for ease of transportation, while its user-friendly controls offer ease of operation, making it the perfect choice for schools, churches, civic organizations and small musical groups. The Escort features dual two-way speakers driven by a five-channel, 300 Watt stereo powered mixer, making it ideal for both vocal and musical applications. The system also includes a PV®i unidirectional (cardioid pattern) dynamic microphone, two folding speaker stands and all necessary connecting cables. Among many professional features, the mixer includes 60mm faders, a five-band graphic equalizer with FLS® (Feedback Locating System) and digital reverb. The carrying case provides storage for all the system componets with ample room for additional mics and cables. This clever design incorporates the speakers into the package, allowing the unit to be easily carried or pulled along on its luggage-style wheels.
  • Convenient package with luggage-style wheels
  • Two-way speaker system with 10" woofer and piezoelectric horn
  • Five-channel powered mixer
  • Four XLR mic inputs with 15 V phantom power
  • Two stereo line inputs
  • 60 mm faders
  • High quality digital reverb
  • 300 Watts output power (150 Watts per channel) with DDT™
  • Five-band graphic equalizer with FLS
  • Two folding speaker stands
  • One PV®i cardioid dynamic microphone with cable
  • Two 25' speaker cables
  • Storage compartments for microphones, cables and accessories
  • Weight Packed: 64.00 lb(29.029 kg)
  • Width Packed: 16.62 x Depth Packed: 39.75 x Height Packed: 17.62
May 05, 2011 | Peavey Escort 2000 Microphone
I have a pmp6000 powered mixer. I was running an ipod in and sending out to one powered speaker. I heard a loud pop and smoke started pouring out of the mixer. I immediately stopped using it. This morning...
Cease using the mixer until it is repaired. One or both of the amps have blown. Further use MAY result in power supply damage. 1 to 6 switching power transistors will have blown and often a Zener diode or two. If the metering resistors smoked, there will be two small surface mounted transistors per channel blown wide open as well. These are all in the HCA2400 amplifier module.
Feb 12, 2011 | Behringer PMP6000 / B215XL Powered Mixer...
When we are trying to get a reasonable level of sound for vocals before it gets loud enough to be able to hear clearly with the band playing it starts to clip at the speakers now we are only using this set...
Proper level setting of the mixer is important. HOWEVER if the clipping is occuring at the speakers the only possible problem MIGHT be that you have a supersonic feedback that is saturating the speakers above your hearing range, Be sure you don't boost the highs too much with the EQ as this can cause the feedback that you can't hear. Also make sure that you power the speakers from the SAME receptacle as the mixer, even if it means running an extension cord to bring power to the mixer. This is to avoid a low frequency hum and common mode distortion/damage. A low frequency hum could cause the clipping.
It would be a good idea to get a sound meter to check the sound level. You should be able to reach 85 Db from this system without clipping. If you need more than that, you MAY need more speakers if the band instruments are too loud. Also if the band has amps that get into the vocal microphones that adds to the clipping level... make sure the mics don't "hear" the band instruments. Make sure your speakers are toward the audience from the mics to avoid the supersonic feedback problem. If the vocalists can't hear themselves with that configuration you need to set up seperate stage monitors.
There are some pretty good videos on YouTube about proper mixer level setup.
Jan 30, 2011 | Behringer Xenyx X2442USB / Harbinger...
Hi, I would to say thanks a lots to let put some words on yours email box. It's just regarding about how to set up a live band gigs @ outdoor stage in to mixer system. In a mixer setting, i wana know how...
You will need at least a 24 channel mixer to give you spare channels. You also need an active crossover and a snake. The advice you need is too much to include here so I am including some links:,,,, and You may need more monitors than you are planning on and you might consider in ear monitoring.
Aug 22, 2010 | Music
180 watts mixer/amplifier and 400 watts speakers
Hiya, they are thermally or DC protecting. You will have to add some extra cooling if you can, external fan etc. Bottom line is you are going to have to crank it down a tad or increase amps and speakers. If its DC protection, its because the distortion levels are 2 high. Very easily achieved with mics not compressed. Again, try tone them down a tad.
Hope that helps
Jul 13, 2009 | Behringer POWERED MIXER, 20 CH, 400 WTS...
Mic feedback. I sing on a shure beta 58 mic, into a 350 watt peavey amp, into 2 - 200 watt peavey speakers. My band is loud, and I simply cannot get my mic loud enough for them to hear me, without constant...
It sounds as though you are pointing the peavey at the band in a practice situation? If so make sure that each speaker is at about 60 degree angle to either side of the back of the mike (you facing the speakers), most mics reject feedback when the the user is directly in front of a monitor, but Beta 58s' tend to feedback more in that situation. Alternatively (if it is a practice room situation), why not place the speakers behind the band at 60 degrees each and turn to face the band.
Mar 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
No Volume oe sound coming out of speakers
try connecting speakers to another sound source or if you have access to a ohm meter, check impedance of speakers, should measure 4~8 ohms.
Jan 25, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Car Audio & Video Logo
106 people viewed this question
Top Behringer Car Audio & Video Experts
xxxxxx xxx
Are you a Behringer Car Audio and Video Expert? Answer questions, earn points and help others
