Question about Conair Heated Back Massaging System Bm1
AC adapter voltage for Conair Heated Back Massager
I have a Conair Heated Back Massager but have lost the Ac Adapter. I have tried 12 volt output (the motor ran a while then shut off), I tried a 30 volt output and it started smoking. Could you tell me what output voltage to get. I know the massager works because it worked a few seconds on the 30 volt AC but it was evidently too strong for it. I don't have the book or box it came in as it was given as a present. Thank you,
  • thewise3 Feb 03, 2009
    I lost my adapter also. I will try to find one in thrift shop bins. It would be nice to know the correct one to look for. thanks
  • mintcooki Mar 04, 2009
    I have tried searching for my model everywhere online and can't seem to find any specifications on it.
    It's a CONAIR Model 4502RT Heated Back Massager.
    If you figure out what size it is, please let me know!
It is a class 2 transformer
The Conair part number is TEAD-57-121600U
Input: 120 volts AC 60 Hz 29 Wats
Output: 12 volts DC 1.6 Amps
Sorry, I don't know where you can find one.
Posted on Apr 02, 2009
  • Rigel7 Apr 02, 2009
    One more thing.
    The center of the plug should be positive.
There are no instruction and no place to plug the adaptor in and we got it as a gift and my sister is living in Italy. And I can not find any information on how to use it. And Conair wants money to find out, which is stupid. If I don't get this fixed. I will make sure I never buy or have a family member buy another product for conair.
Posted on Oct 11, 2009
I actually found the adapter in my garage, but no longer have the massager. I have no use for it-never been used.
lostlapi@yahoo.com
Posted on May 23, 2009
    Problem Solver:
  • 18 Answers
To plug it in you have to look at the hand held controller that is atatched to it and that';s where you plug it in at.
Posted on Aug 12, 2011
It will not trurn on does the ac adapter need replacement it is over 10 yrs old
Look at adapter, see what output is supposed to be- maybe 12 volts DC? Find a multimeter that will measure DC voltage, and see if the output plug has that across the connector. If you have an ordinary power cord without an adapter, it will have 120 volts AC like any other cord, which you can also measure on AC scale, but be careful as you can get a dangerous shock, just like you can from an ordinary household outlet.
Note: AC voltage may vary by country.
Apr 09, 2014 | Canon PIXMA iP3000 InkJet Photo Printer
Conair massager model 4502ST
I have a homedics shiatsu massaging cushion model SBM-300. I have lost the power adapter. The box says 120VAC/12VDC 1A. I cannot find a replacement anywhere. Any help would be appreciated. Thanks
May 02, 2012 | Conair Heated Back Massaging System Bm1
I have the Western Digital My Book Essential Edition 250GB External Hard Drive. I have moved and lost the power cord. I purchased the DYNEX 500ma Universal AC Adapter as a replacement. When I plug the...
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Sep 15, 2011 | Western Digital 250GB MyBook External USB...
We have an Acculab V-200 electronic balance here at school. The AC adapter was misplaced, however one with a 12 volt output was found. It fits the balance but I am afraid to plug it in since the unit can...
re: Acculab V-200 Digital Scale
The original AC acpater is rated at 12VDC 300mA output. It is unregulated (i.e. the output voltage is about 16-17V with no load)
The centre pin is NEGATIVE, which is the opposite of "most" AC adapters.
(Acculab model number is 41-12-300D, for the 120V 60Hz version)
Aug 16, 2011 | Health & Beauty
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
Output: 12VDC / 2A
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
Vgn fs 980 adapter how to tell if it is not working
AC adapter? Test the output voltage.
Use a multimeter.
Stores like Radio Shack, Walmart, and auto parts stores, for a few examples have cheap one's you can buy.
About $12.
Set the multimeter knob to DC volts, and the 0 to 50 Volts scale.
The middle hole of the AC adapter plug is the Positive connection. This is where the Red lead goes.
The outer shield of the plug is the Negative connection. This is where the Black lead goes.
Look on the AC adapter for the OUTPUT VOLTAGE
(Not shouting)
Example:
I'm looking at an AC adapter for an IBM Thinkpad 370, right now.
INPUT: 100V 50-60Hz 130A
OUTPUT: 18V ~~~3.36A
The Output voltage is 18 Volts
The Output Voltage of your AC adapter should be close to this.
Dec 20, 2009 | Sony VAIO VGN-FS980 Notebook
Use Sony ICF-C1IPMK2 in Europe
A transformer type (Linear Mode Power Supply) AC to DC power adapter with a 9.V nominal output, measures about 12.V without load when tested with a multimeter. A power adapter with a nominal output of 7.5 V, measures a little over 9.V. Considering a number of people across different forums reported the adapter's measured power output as 12.V, I think the nominal rating of the AC to DC adapter should be 9.V. However, keep away from Switch Mode Power Supplies.
Jul 21, 2009 | Sony ICF-C1IP White Powered Speaker System...
Ac adapter
Hi I am an Indian too !
Of course you can use the 220v AC adapter, it will not harm your massager but may only underperform [slow speed, slow vibrations etc]
And be aware that the foreign products you receive, and have adapters rated at 120v are bound to get busted if you use them here in India, don't use them at first place.
Rather, buy an adapter rated for 220-240v for the same output voltage as that of 120v
Jul 12, 2008 | Televison & Video
Ac adapter voltage
Usually it is 5 Volts and 12 Volts Generally also it is DC not AC. on a standard connector for the power it is 12V 0v 0v 5 V. Hope this helps
Jan 29, 2008 | Western Digital My Book Essential Edition...
Conair Heated Back Massaging System Bm1 Logo
3,830 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
