Question about Nintendo Video Game Consoles & Games
Nintendo won't come on the tv
I've got a nintendo64 and the games won't come up on the screen in the video function. it was brought into my house already hooked up to a tv and just needed to be plugged into electricity. you put the tv on video mode and turn on the nintendo and nothing happens. I've tried both channels 3 & 4. I've tried blowing in the game and the nintendo unit to get dust out. any suggestions?
You might want to try this---
Does the TV you are using have an AV channel? if it does try changing the channel on your tv to AV.
Posted on Jan 14, 2009
My nintendo 64 was working earlier on a different tv, but a hd one like mine, i have all the right cables and everything, i brought it back to my house from my nans earlier, and set it up, lights on so...
Nintendo 64 - Blank Screen Troubleshooting
Quick Tip:
If your system is connected using AV cables and you cannot see the game on your screen, it is likely all you need to find is the input select on your TV or VCR. Link here for help.
Make sure your system is hooked up correctly. This is the number one reason for a blank screen. To ensure all hookup connections are firm and correct, remove the AV cables and reinsert them with a slight twisting motion (this will help fully seat the connections). For more information about connecting the system, check the following hookup steps:
Audio/Video Cable to a TV
Audio/Video Cable to a VCR
Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
Make sure the system has power. If you don't see the red power light when you turn your system on, go to the No Power Light instructions.
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position. (Inserting the game with the Power ON will result in a blank screen.)
Check under the Memory Expansion door (on the top of the Control Deck) to verify that the Jumper Pak or Expansion Pak is still inserted. If one is not inserted, slide the Power Switch to the OFF position, insert the Jumper Pak or Expansion Pak and slide the Power Switch to the ON position. Simply pressing reset will not solve the problem. You must turn the power off and then back on.
If the above steps do not resolve the problem you are experiencing, there may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (how to buy replacement parts). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
If this does not resolve the problem you are experiencing with your system, your system may need to be replaced. For more information on what options are available, please click here.
Jul 24, 2011 | Nintendo 64 Console
I've hooked up my nintendo64 into the tv and power and even set it up at the right input and it won't turn on
Well it might just be the fact that it has died or the ac adapter is causing the problem.
Dec 19, 2010 | Nintendo 64 Console
I have a nintendo64 and im trying to connect the red white and yellow plugs to a vizio HDTV I dont know where they go in tv av1 av2 or component? Help
You need to plug them into the AV1 or AV2 plugs, they are colour coded so you know which lead goes into which socket.
Hope this helps
Aug 08, 2010 | Nintendo 64 Console
Which cables do I need to connect my Nintendo64 to my TV? And where do I put them? The tv is an emerson model: ewl20s5 c
the only cord you need to plug into you tv just to play is the input plug (the one that splits into 3 plugs; one yellow, one white, one red).
you also obviously need to plug the nintendo 64 into the wall for power.
this goes for most, if not all video game systems, as long as your not trying to go on the internet
Nov 23, 2009 | Nintendo 64 Console
My nintendo light comes on but the screen stays blank
Clean the control deck and the cartridges. Check the input cable to the TV.
Hope this helped :)
Oct 26, 2008 | Nintendo 64 Console
Nintendo64
Time for another one, You probably fried the mainboard.
Apr 18, 2008 | Nintendo 64 Console
Power plug
I think that the console got fired by now then.
Apr 17, 2008 | Nintendo 64 Console
Video Game Consoles & Games Logo
425 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
