Question about Toshiba E-Studio 3511 Color Copier
Estudio 3511 is not plugged in to the network but the light on the nic card is lit green. The screen says network initializing and will not time out. I need to get into the admin section and set the static ip address but it will not allow me as the button is grayed out- I think because it is trying to connect to an old network it was set up on previously. How would I bypass this for the machine to allow me to get into the network setup to set the IP address??? Help
  • Anonymous Jan 23, 2009
    Same problem for me
REBOOT
Posted on Jan 08, 2009
2 Suggested Answers
SOURCE: Toshiba estudio 3511 will not allow me into the network config
First of all, the default password for Admin is '123456'. The network button is grayed out because network is initializing. Which means the network portion of you copier is trying to boot up. If it never finishes booting up, you will need an authrized technician to re-load system firmware on your machine.
Posted on Feb 04, 2009
Nic card not working, no green light on back. Is there a plug and play nic card that I can purchase to replace?
There are may plug and play network cards around. It will depend on your version of windows as well though.
Have a look at cards in what ever store you usually use at the price range you like and I am sure you will find something.
Thanks
May 05, 2011 | HP Compaq Presario SR1650NX...
Toshiba estudio 3511 keeps giving error c360. I've checked the charger and the gears are messed with drive motor. Motor turns initially but gets to stopping point and gives error. Is there a charger...
At our repair shop we have begun to put a small (1/8" or so) washer in between the frame and the bracket the worm gear is attached to when we get this error intermittently. It seems to pull that worm gear closer to the main charge cleaner gear to give it better meshing. Hopefully this helps you!
May 27, 2010 | Toshiba E-Studio 3511 Color Copier
Estudio 3511 in storage for 6 months
hi do u have try to refix your developer unit i mean just remove and re fix it again thanks
May 11, 2010 | Toshiba E-Studio 3511 Color Copier
We changed the toner in our E Studio 3511 and now it keeps saying network initializing? Can you help?
Hi how are you hope you are ell
This is jack jack_pak@hotmail.com
Dear dont wary after some time network initializing is finished automaticaly.
PLEASE VOTE ME.
Thanks
Best Regards,
Apr 19, 2010 | Toshiba e-Studio 350 Copier
Como instalar el escaner del una toshiba estudio
buenas noches quiero sabe como scanear en la multifuncuional toshiba 2330c y hacia que carpeta direcciona los documentos gracias
Mar 20, 2010 | Toshiba E-Studio 3511 Color Copier
I have a persistent red light on the wireless adaptor, but the xbox is not recognising that it is plugged in. There is no option for the xbox to search for a network
Blinking green means initializing, steady green means it's found a wireless access point and connected.
Steady red means it's looking for a wireless network (wireless access point) which means you have to configure your SOHO router with an SSID that's broadcast so the wireless xbox NIC can find it.
I think you may have confused a comment I made - the xbox can be connected to your SOHO router by either a WIRE (ethernet cable) OR Wireless NIC (network interface card). If you're using one, disconnect the other!
If you have wireless enabled on your SOHO (small office home office) router then you should either use WEP or WPA for wireless security WPA-2 is recommended. This means you will have to know the key to attach to the wireless network. If someone else set it up then you will have to ask them for the key / passphrase.
Sounds like the NIC isn't the problem but the attaching to the wireless access point (WAP) is. Try www.xbox.com and search for some support regarding your situation. They have a good how to that details the installation / configuration step by step and it sounds like its one of those steps you're missing, unless I've misunderstood.
Good luck,
Feb 10, 2010 | Microsoft Wireless Network Adapter Xbox...
Jan 07, 2009 | Toshiba E-Studio 3511 Color Copier
Dell 4700 Computer Integrated NIC Problem
Check for the pins inside the integrated NIC to check if the pins are bent / disfigured. Does not look like the additional card is making any different, looks more like a moving NIC cable is makin the difference.
Lemme know if this helped!
Dec 13, 2008 | Dell Ethernet Card Network Adapter
Trouble networking copier to computer
you might have to set up the nic card in the machine. set it to a static IP address (not DHCP), then ping it from a PC..
If you can ping it, then instalation should find it!
I dont understand " time warner connection to rout both computors thru " ?
you should have.
One broadband Modem...
One Router which all pcs and machine's are connected to...
do ipconfig/all to figure out the pcs IP address, arp -a shows the arp table. determine what IP address to give the machine.
the machine should have a nic card with a light on it, if that light is green when you connect the cable, then the nic card is working.
then proceed to install the drivers to the PCs.
Oct 23, 2008 | Toshiba E-Studio 3511 Color Copier
Can't see the Axis over the network
Solid green lights usually mean no activity. Have you checked the Network Card properties and made sure you are using DHCP? Are you plugging into a switch? Is the switch on the same network as your DHCP server? Have you tried different ports on the switch? Also, is the duplex set appropiately?
May 22, 2008 | Computers & Internet
Toshiba E-Studio 3511 Color Copier Logo
200 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
