Question about RCA E13309 13-Inch Diagonal XL-100¿ Color Television Television
DTV hookup for an RCA XL-100 TV
Where do I start? my TV has no cable outlets I have an converter box with RF cable plus I have a balun I don't know a thing about installing DTV??
  • 2,071 Answers
Buy a box modulator which have RF input then have RCA output that's input to your TV or other option below.
Just click and choose whatever hooked up connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
HP TVs - TV Cable and Connection Types
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Jan 08, 2009
How do I hook up Coby 5" black & white TV to my digital converter box ?
You will need a digital to analog converter which you can get at Radio Shack, Best Buy and most big box retail outlets or online. Your Coby is most likely analog and will require the digital signal to be converted to an analog signal from the digital converter box to the TV. UNLESS the digital converter box has analog (round connectors on the back) then you just need an analog RCA cable (which you can also get almost anywhere even your local CVS/Walgreens) to make the connection.
Nov 24, 2014 | Coby Televison & Video
Tip
RF Modulators and cable connections
RF MODULATOR HOOKUP
For a TV with only a RF input jack, a RF Modulator can be used to hookup DVD players, DVD recorders and other devices which output RCA composite video and audio. For example, analog cable TV can be connected using a RG-6 type coaxial cable to a VCR or older DVD recorder's analog cable ready tuner RF input. Then as shown above, the output can be connected to the TV thru the RF modulator. The modulator outputs on channel 3 or 4 for the older TV so the TV is set to channel 3 or 4. Some RF modulators are built-in to Audio/Video switch boxes. These allow multiple RCA inputs along with RF input.
RF MODULATOR CLOSE-UP
The modulator converts signals to channel 3 or 4 so older TVs can tune them on their analog tuners channel 3 or 4.
RF Modulator - buy online
http://sewelldirect.com/belkin-rf-modulator.asp
on Aug 23, 2010 | Audio Players & Recorders
I do not see a standard cable input on the tv...is there an adapter to connect standard cable line to the antenna input?
if the TV has 2 screws for an antenna connection then you could use what is called a BALUN aka matching transformer. you can buy them at a dollar store. it has a male cable connection and 2 wires.
I am surprised that an LCD TV would have an antenna connection, they are from the days before cable TV.
if your TV does not have a cable input you can use an old VCR as a tuner
or buy an RF converter (but they are overpriced IMO)
you would plug the TV cable into the VCR and use rca cables red,and white for right and left audio, and yellow for video
Jan 10, 2010 | Mintek DTV-265-D 26 in. LCD TV
Has anyone figured out IF such a digital anntenna exist yet?
You don't need a digital antenna; any indoor UHF/VHF antenna will work. The antenna and the TV both connect to the converter box, not to each other.
A standard rabbit ears (UHF/VHF) antenna with flat wire (300 ohm) connections can be hooked up to the coaxial cable that goes to the Antenna (RF in) jack on the converter box by using a balun (Radio Shack catalog # 15-1297, about $8). If you have an antenna with coaxial cable already attached, you don't need the balun.
To connect the TV to the converter box, you need an adapter that has an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 08, 2009 | Casio TV-980 2.3 in. Handheld Television
PS2 won't work with magnavox dtv converter box
first off make sure u have the box turn off
this is what i would do:
i would get a short coaxile cable and splitter and hook them up to your tv
........................TV.........................Coax input
.........................|..............................Coax Wire
......................../\.......................................Coax Splitter
....................../...\.......................................Coax wire from ps2 and dtv box
...............PS2......DTV box......................
Hope this helps
Apr 28, 2009 | 1991 Honda Accord
Dtv converter box, no PS2
you need to hook up the ps2 directly to the tv not the converter box the converter box is only for digital Chanel's that will go off air on june 12 but if you have cable or satellite then you don't need a converter box this is only for free Chanel's with they don't requires subscription to cable or satellite your playstation should work with out the box try to hook it up directly to the tv not the box
Apr 28, 2009 | Video Game Consoles & Games
Try the $40 RCA DTV Tuner/Converter from Wal-Mart. Connect your existing VHF/UHF antenna (if you don't have one, Wal-Mart sells them too) to the antenna input on the back of the converter and the converter to the antenna input on the back of the TV. If it has only twin lead antenna inputs instead of the standard coaxial type, you'll need a simple twin-lead/coaxial connector, which is about $5. Tune to VHF channel 3 or 4 (set your converter switch correspondingly), turn on the conveter box and follow the onscreen instructions. If you see static, use the automatic or manual fine tune control until you see a clear picture of the menu screen.
Jan 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
I have a ViP 722. It has no rf output for TV1, just the hookup for TV2. The multi RCA hookup for HD. HD is not as important to me as is a clean picture and audio on my TV. No matter how I do it, I get a...
Okay I am not positive I have this right as far as the configuration of the system but I will give it a shot. If you run the 722 to the tv using rca's you get the hum. I assume this as there are no inputs on a dish 722 receiver. I can suggest one possible solution which is to buy an rf modulator. It will convert the signal from rca to coax so you can connect as you wish. There are several types out there so ensure you get the one that converts from rca to coax. I would suggest the following configuration: Remove all connections from tv and hook 722 up via rca's to rca input 1 on the tv, check for hum. If it is present now you need a new 722 as it is passing to much power thru the connection. If there is no hum connect your cable and tivo to the tv via whatever inputs you have remaining. Lastly connect the DVD player to another input that is free. You will have to system through your inputs to view the three sources but should not have the hum. I hope this solves your issue. Thanks for using Fix Ya and let me know if I can be of further assistance.
Dec 06, 2008 | DISH Network DVR-625 DTV Receiver /...
60hz hum
I sent a solution to this already. If you did not receive please let me know. Thanks for using Fix Ya.
Televison & Video Logo
572 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
