Question about Pentax Optio A10 Digital Camera
Power issue When I switch thw camera on it fires up, the sound is heard, it remains on for about 5 seconds the turns itself off for no reason. Battery is fully charged & the memory card is not full. Anybody have any sugestion please
  • gios_007 Jun 03, 2008
    I have a pentax Optio A20, the camera turns on for about 5secs, then turns itself off. Please help, just got the camera.
Same issue on optio m-20. sent it to pentax. was told my camera must have fallen and the lens is bent. They wanted $182 to fix(camera cost $118) I declined and recieved it back today and am looking for someone to repair it
Posted on Jun 27, 2007
    Genius:
  • 2,985 Answers
First of all try the Pentax web site Technical support line. also when fire it up press the battery compartment door shut it may be tired contacts. But it looks like a repair job is needed- or it it is getting on a bit - replacing
Posted on May 30, 2007
  • john ash
    john ash May 30, 2007
    More You could try taking a piece of foil and laying across the batteries top [onder the compartment lid ]to improve contact.
SOURCE:
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
My sony Camera (DSC -W110) is showing "Turn the power off and on again" while switch on the camera,it appers again & again after switching the camera on and off
I'm sorry that the Camera is displaying the error message. "TURN THE POWER OFF AND ON AGAIN" displays on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset. Please follow the below steps to perform a power reset.
· Turn off the camera.
· Remove the battery pack.
· Press and hold the power button for 30 seconds.
· Allow the camera to remain without power for 60 seconds.
· Reinsert the battery pack.
· Turn on the camera.
Also tryinitializing the Cameraif you're able to access the Menu items on the Camera. The Initialize option will be available under Setup or Main settingsSub Menus.
If the issue persists again, service is required. Please click hear to locate the service center near your area.
Thanks for understanding. Please let me know if your require any clarifications.
Mar 21, 2011 | Sony Cyber-shot DSC-W110 Digital Camera
When i try to record it dosent let mi and in the screen it shows a tape with a line through it. what do i do?
The tape with line through it indicates that there is some issue with tape/tape mechanism. I believe that the tape symbol is as follows:
If the tape warning indicator flashes slowly, the reason may be.
  • The remaining tape becomes shorter than the length of five minutes recording.
  • No tape is inserted
  • The write protected tab on the cassette is set to LOCK(red).
If you're confirmed that the reason is not the first and second, it should be because of the write protected tab on the tape.
Don't worry, I will help you with that. Please see the below picture to view the LOCK slide switch:
If the tape with line symbol flashes quickly, it indicates that the cassette has run out of tape.
If the issue persists, please follow the troubleshooting steps and check if that helps.
  1. Reinsert the tape.
  2. Reset the Camcorder by pressing the reset button behind the LCD panel using a sharp pointed object.
  3. Perform a power resetting
  • Turn off the camcorder. Disconnect AC power adapter. Remove the battery pack.
    Move the POWER switch to the CAMERA position for 15 seconds.
    Move the POWER switch to the OFF position.
    Reconnect the AC power adapter or reinsert the battery pack.
    Turn on the camcorder.
    I hope performing the above steps should resolve the issue.
    If you need any assistance please get back to me.. Thanks for understanding.
Feb 17, 2011 | Sony Handycam DCR-TRV250 Digital Camcorder
My DSCS780 says Turn the power off and on again but, it does not turn on what should I do...I also heard you could reset the camera if so how do you do that?
The Turn off and on again error message displays when there is an internal malfunction or a malfunction with the Lens. The error message normally displays with the issue with the Lens. Try the following steps to check if the issue can be resolved.
Try power resetting the Camera.
Turn off the Camera.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack and check if the Lens retracts.
You can also try resetting the Camera back to factory default. This can be done only if you're able to access the Menu of the Camera. To reset the Camera back to factory default, select the INITIALIZE option from the Setup 1 Menu of the Camera to OK. (Menu-->Setup-->Setup 1-->Initialize-->OK.)
Thanks for using FixYa
Jan 18, 2011 | Cameras
My camera doesnt allow me to take photos, the lens doesnt work.
Most of the lens issues due to mechanical problem. some of the causes are dropping the camera.
Hard shake like keeping the Camera in the hand and jump through steps, Moisture condensation, Insufficient battery.. etc If If you feel that the issue is not with the above reason, try initializing the Camera. To initialize the Camera, please use the Initialize option under the setup 1 Menu.
If the issue persists, perform a power reset of the Camera.
Performing a manual power reset Turn off the camera. Remove the battery pack. Remove the button-sized lithium battery. Allow the camera to remain without power for 30 seconds. Reinsert the button-sized lithium battery. Reinsert the battery pack. Turn on the camera. If the issue persist, service is required.
Jan 07, 2011 | Cameras
The lens on camera doesnt work
Hard shake like keeping the Camera in the hand while jumping through steps, Moisture condensation, Insufficient battery.. etc If If you feel that the issue is not with the above reason, try initializing the Camera. To initialize the Camera, please use the Initialize option under the setup 1 or Main Settings 1 Menu.
Jan 07, 2011 | Sony Cyber-shot DSC-W110 Digital Camera
My sony cybershot dsc-w350 keeps turning itself on and off and reads system error
The system error is displayed in the Camera when there is some internal malfunction or when the Lens in the Camera get stuck.
Try power resetting the Camera to check if it resolves the issue. To power reset the Camera, turn off the Camera and remove the battery pack. Press and hold the power button for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery.
If the issue persists, try Initializing the Camera. The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETTINGS-->MAIN SETTINGS-->INITIALIZE-->OK.
KenSolutions
Dec 05, 2010 | Sony Cybershot DSCW350 Digital Camera
Dsc t2 61 00
This issue may occur for one of the following reasons:
The memory card was removed while in the process of recording or finalizing.
The camera was dropped or subjected to some type of impact during recording or formatting.
Performing a manual power reset may help:
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Reset the camera to factory specifications to try resolving the issue.
If the issue is still unresolved, service will be required.
Thanks,
KenSolutions
FixYa
Oct 22, 2010 | Sony Cyber-shot DSC-T20 Digital Camera
My less than 2 year old sony dsc-w100 keeps powering off and on
my only idea would be that the power button is glitching out...anything in the manual about this?
Jan 22, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Hotpoint Aquarius WF530 LEDs flashing
I cannot tell from your description what the error may be but here is a list of reasons;
https://www.whitegoodshelp.co.uk/hotpoint-aquarius-lights-flashing
Jun 13, 2017 | Hotpoint Washing Machines
Pentax Optio A10 Digital Camera Logo
85 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
