Question about JBL Car Audio & Video
Amplifier problem amp is connected perfectly in my car i checked all the wireings everything is perfect amp turns on but the subwoofer doesnt play a sound i tried different subwoofers but same problem... sumone please help me with my situation.... amp doesnt go on protect mode... alll the fuses are fine... but no sound!
    Problem Solver:
  • 18 Answers
Try this it may help do you have a frend that you could swap amps with just to test (put your amp in a working system to check yor amp) as it could be a number of things it could be no out put from the head unit or a break in the rca cables or dare i say it but the amp could be blown it may even be speaker cable from amp to sub or the remote not working have fun !
Posted on Jan 07, 2009
My Jl Audio 500/1, power light comes on but no power to subs
maybe it dont have enough to push it ,,did you try it before you buy it?
Mar 01, 2010 | Jl Audio 500/1 Car Audio Amplifier
I have an alpine MRP-500 amp that used to work great with my 2 10" Type-R subwoofers. Out of nowhere the sound just stopped working and still will not. I had the amp and subs tested and the guy said it was...
  • make sure the subwoofer level is up on the head unit.
  • Make sure the RCA cables are good.
  • Make sure the remote wire is connected and has 12v+ when the head unit is on.
If the remote wire is not turning on the amp, its not going to work. To hot wire it to see if thats the problem, just run 12v+ to the remote jack. That will turn on the amp.
Nov 22, 2009 | Alpine MRP-M500 Car Audio Amplifier
What is wrong when my amp shows that there is power and my subwoofer doesnt play
u need to make sure all wires are connected and ur gain is adjusted correctly. all wires includes wires at the stereo
Aug 30, 2009 | Lanzar 2CH 800W VIBERANT AMP Car Audio...
2005 Dodge Neon SXT Kicker Amplifier
if its a new amp there should be a problem. make sure you have your remote wire hooked up to your radio(its blue). make sure your fuse on your amp wire isnt blow and make sure you have a good ground. if your runnin the ground off the car make sure the paint is scratched off that area
Mar 08, 2009 | 2005 Dodge Neon
Amplifier Powers on But Does Nothing!
Try finding a better ground some amps are more finicky about ground than others. Try running a wire from the ground on your battery to the ground on the amp if this works then you will know you need to find a better place to pick up a ground.
Jan 24, 2009 | Pyle BZDBP212 Car Subwoofer
Subwoofer not working properly after a few mins playing
Get a hold of the woofer connector (I believe its brown) right by the whoofer and move it around/press it/disconnect and reconnect and check if the woofer comes on. There is a bad connection in the connector for the woofer itself. I have a 2001 GLE my self and that's what I found to be the problem with mine.
Dec 16, 2008 | 2001 Nissan Maxima
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Sep 08, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Subwoofer Output Not Working...
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Jul 02, 2008 | Eclipse CD5405
I dont get any sound
Many vehicles have factory amplifiers that must be activated or bypassed when installing a replacement head unit. If the factory amplifier isn't integrated or bypassed, you won't hear sound from the factory speaker locations. Another possibility is that you have a shorted or pinched speaker wire or terminal. A short at any speaker will shut down the head unit's internal amp, killing the sound to all the speakers. The RCA outputs wouldn't be affected, so the subwoofer keeps playing.
Feb 23, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
153 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
