SOURCE: 1998 S-10 cold start
The cold weather wreaks havoc on everything. I am thinking that the cold weather and your octane rating are not getting along, hence no error codes. Have you tried fuel drier and or octane booster?Since the truck starts when the temperature gets warmer, I would look at octane as the culprit. Try some octane booster and see if that helps. Let me know. Hope this helps.
Thanks;
Rich
RPM Northwest
SOURCE: 2004 Chevy Colorado
i have a 2005 colorado it was in a accident the radio comes on but it does not pick up any chanel and thegas gauge does not work
SOURCE: 2001 Chevy Silverado will start up but cuts off after seconds
Could be either one of these. Or both. Check to see if you hear the fuel pump when you turn the key to ON. If you can't hear anything , the pump is bad . Or going bad if you don't hear it all the time when your key bis in the ON position.
SOURCE: I have a 2000 s500 engine just shut off by itself
you need to have car scanned for codes and it sounds like it is due for a major service
SOURCE: When I go to start
sounds like factory security need remaped should be under warenty dealer only
Click
the link below to troubleshoot this problem: ---
Car loses power while
acceleration?
http://schematicsdiagram.blogspot.com/2011/12/car-loses-power-while-acceleration.html
Loss of acceleration?
http://technoanswers.blogspot.in/2012/02/loss-of-acceleration.html
Acceleration lag problem?
http://repairhelpcenter.blogspot.com/2012/01/acceleration-lag-problem.html
How exactly the Vehicles
Accelerator Cable works?
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-cable.html
How exactly Vehicles
Accelerator Pump Diaphragm Works?
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-pump.html
accelerator pedal sensor?
http://technoanswers.blogspot.in/2012/02/2009-chevy-impala-accelerator-pedal.html
stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
Engine accelerates when brake is applied?
http://technoanswers.blogspot.in/2012/02/engine-accelerates-when-brake-is.html
This
will help.
Thanks.
