First Option: Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So Secend Option: Your Phone Network IC Fault So Please change Network IC And Network Signal Problem will Solved if it is there isn't much you can do on this side of the network. Contact your phone company.
Not sure what it was soaked in, but if you dry it out, your phone may function again. Don't try to turn it on right away; remove the battery. Don't use a heater or anything hot to dry it out. Use compressed air to get as much moisture out as possible. Then put it and the battery in a container of uncooked rice overnight.
Its probably damaged the board in the phone but it may have just gummed up the charging port remove the battery and clean the charging port and the battery contacts and phone to battery contacts using rubbing alcohol and que tips. Hope this helps Chris
You may try default phone and security code to remove restrictions. ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
