Question about HP Compaq d530 PC Desktop
New video card - now an error message
Hi guys
I just bought a LG digital monitor, so to get a digital signal from my d530 CMT I installed a Diablotek XGI Volari V3XT 128MB AGP into the AGP slot on my mobo. Easy I thought. I've got XP Pro SP 3.
Now when I boot up I get a message that's flashed for a few seconds, "110 - Out of Memory Space for Option ROMS. The option ROM for the following device was unable to run due to memory constraints. If you choose to continue, one or more PCI devices may not work properly." Then booting continues normally.
I'm not sure if I'm getting a digital signal at all - I see "Analogue" flashed up on the monitor before that disappears too. And Microsoft Flight Similator seems to run a little jerkily although to me the display seems to have great resolution (which may be due to the 1:10,000 rating of the monitor, nothing to do with the video card).
This was a cheap card - $25 - but the reviews seemed ok. All I wanted was a digital signal good enough for Flight Similator. And thought I had lots of memory.
Can anyone explain what the message means, and what I should do next - trash the video card?
Thanks
Mark
  • Mark
    Mark Jan 08, 2009
    Gary - I installed this Diablotek AGP card last fall after reading positive test ratings on the net, seeing it had an AGP interface and supported the 8x standard. Well, ok, it was a cheap buy. But I'm not into games, I just wanted a PCI or AGP card to replace the integrated one on the mobo that doesn't provide a digital signal. The 3 negative buyer comments hadn't been posted yet on Tigerdirect (they no longer sell this card). I haven't had similar problems as those buyers. And as the BIOS error message flashes up then disappears just as quickly, there's no other issue booting up, and the monitor seems fine, I thought it was just a peculiarity - and maybe the operating system was sorting out a hardware issue as XP loaded.
    As you suggest I downloaded a XP driver program for this card from Diablotek.com. But when I ran the setup, I got a Microsoft 'crash and burn' warning dialogue box - "... not passed Windows Logo testing to verify compatibility with XP... " So I stopped installation.
    Should I go ahead and run the installation anyway? I've got this new driver package on my new Z drive - the original drivers will be on my old C drive along with the operating system.
    Markrobin - I did get into BIOS and under Device Options I found an "AGP Aperture Size=64MB" listed. Not knowing if it mattered, I toggled that to 128MB to match the card, then saved, and rebooted. It didn't matter - no difference at all. I still get the same BIOS hardware error flashed up with the monitor seeming to display fine. The monitor's a decent LG Flatron W1952TQ with a digital contrast of 10000:1 that I bought last fall.
    So what to do - replace this cheap card? And what would you suggest for something that's less than $100 and give a digital signal to help Flight Similator X run a little better?
    Thanks guys. I really appreciate your expertise and generosity in offering suggestions.
    Mark
    Scholar:
  • 149 Answers
Check the bios of the machine for
1. disable onboard vga when pci is installed
2. look for a setting like
set acpi/usb buffers at top of memory
this setting should be enabled
Posted on Jan 07, 2009
    Novelist:
  • 124 Answers
Hi Mark,
Have you updated the BIOS? If not, I'd at least do that (to 2.44 Rev A, released in August 2008) to eliminate a BIOS issue.
The OEM PSU (power supply) in the D530 supports up to 240W, which is not much for electronics today. However, a 128Mb card should be OK. If it was a power issue, the overload protection would kick in and the system would shut down. The D530 CMT accepts up to AGP 8x, which this card supports.
This card is not very well rated. Go to Tiger Direct and you'll see that some people had driver issues. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4107596&CatId=28
You might want to visit the Diablotek website and see if there are update drivers available.
One other thing... it may be a pain, but I'd go back to the original graphics card and use the monitor with it first, just to be sure everything works. There may even be some software included with the monitor you'll want to install. At that point, THEN do the update. Never do more than one hardware change at a time... I've learned that the hard way. ;-)
Good luck,
~Gary
Posted on Jan 08, 2009
  • 1 more comment
  • Gary
    Gary Jan 08, 2009
    In my last paragraph, "then do the update" should be "then do the graphics card update". Sorry. ;-)
  • Gary
    Gary Jan 11, 2009
    Hi Mark,
    There are many drivers available that work fine but don't happen to have full Microsoft approval, and thus this warning dialog will come up. You should be fine to let it install. Worse comes to worse, you can always uninstall the driver later. I've installed dozens of drivers with this initial warning and had no trouble.
    If the driver update doesn't work for you, then your best bet is to get a more popular and proven video card. Just keep in mind the power requirements as the OEM power supply is rated at 240w. Although some video card specs are overrated, as a "padding" of protection for the manufacturer, I personally had a 300w card trip the PSU auto-protection when trying to watch a DVD movie.
  • Gary
    Gary Jan 11, 2009
    Sorry, one last thing. If you do decide to get another video card and are tempted to get one with higher power requirements, you'll have to replace the PSU (power supply). There are many on the market at reasonable prices, but beware of the proprietary ATX case design HP created that may require a different orientation of the PSU. Some people reported having to drill new holes. Check the HP support forums for more information.
HP D530 HDMI video card
check ur motherboard manual
May 17, 2012 | HP Compaq d530 SFF PC Desktop
Dear my computer not display. i m check the ram .but not display . no beep sound . proper processer fan on and off but not display apper.
Check your video card. Try another monitor that you know that works if it still does not display try a new video card.
Jan 18, 2011 | HP Compaq d530 CMT PC Desktop
I WANT TO DOWNLOAD HP COMPAQ D530 CMT
you can easily download the setup from the following sites
forums11.itrc.hp.com/service/forums/questionanswer.do?threadId
h18000.www1.hp.com/products/quickspecs/11632.../1163
h30499.www3.hp.com/t5/...PCs...HP-d530-CM
ptf.com/vga/vga+hp+compaq+d530+cmt
www.topshareware.com/...hp-compaq-d530-cmt.../downloads
www.user-guides.co.uk/download/hp/hpcompaq/hp-compaq-d530-cmt-manual-placa-
download and install it on your device,it will work just be fine
Jan 14, 2011 | HP Compaq d530 CMT PC Desktop
Hi guys, I have an issue with my old HP Compaq D530 CMT Desktop. The power light blinks 5 times when I power on the pc (Pre video memory error). The Hp site suggests to: 1 Reseat the DIMMs in the memory...
Try the DIMMs in another motherboard.
Download the free 'MEMTEST86+' software, and burn it to a CD-recordable disk.
Put just _one_ DIMM into your computer, and boot from that disk, to run an intensive "memory-test" of that DIMM. If it "passes" (about 30 minutes per 512MB), then repeat with the other DIMM.
Jan 06, 2011 | HP Compaq d530 CMT PC Desktop
Should I remove driver for integrated intel extreme graphics 2 before installing geforce mx agp video card with win xp. What is the proper procedure ?
Hi bhuisingh, I pulled these instruction from the NVIDA forum for removing the drivers.
  • It seems a lot of people on the forums are getting error messages which can simply be solved by making sure old drivers are removed correctly. This isn't always the solution, but its certainly the first step to take in finding the solution. Also, I thought it would be useful to have a general guide on how to do it properly.
  • In order for new video card drivers to work correctly, you must first make sure that all old drivers for the video card are removed, as the old ones can conflict with the new ones, giving various errors when trying to run games ect.
  • Firstly, remove old drivers by navigating to device manager, and select display adapters, double click on your graphics card, select the driver tab, and select uninstall for your video card driver.
  • Download and install driver cleaner pro here http://www.download3k.com/Install-Driver-Cleaner-Professional.html
  • Once installed, reboot your computer and start in safe mode, run driver cleaner and select "Nvidia" from the drop down list to be cleaned. This will remove all remaining parts of the old driver. It should be run in safe mode as this has the best results.
  • Once cleaned, restart the computer. Install the new driver.
If this helps, would you please rate the solution. If this does not help, please leave a comment giving me more information on the problem and I will try to help you further.
Dec 30, 2010 | HP Compaq d530 CMT PC Desktop
I found vga drivers but it not work either i installed directly from the icon or from root directory of the this model d530 cmt. how can i install vga drivers?
It looks like the error in ur registry because of invalid registry errors so make ur registry error fix by using reginout registry cleaner and then install ur recommended driver as u want to install vga driver.
Aug 31, 2010 | HP Compaq d530 CMT PC Desktop
HAVE INSTALLED mICROSOFT WINDOWS 7 ON MY HP d530 cmt, BUT I
You need to call or visit hp.com and see if the video drivers support Windows 7.
If you have bought an indepentant video card ( a video card that DID NOT come with the computer), then call the manufacturer of the card or visit the vendor's website and ask for/search for any Drivers that support Windows 7.
If none of these Ideas work, you may need to replace your video card with a Windows 7 compliant video card.
Hope this helps
Mar 27, 2010 | HP Compaq d530 CMT PC Desktop
I have a Silicon Image 164 ADD DVI card added to my HP desktop DVI-D access card in an effort to get a dual monitor configuration. I get an exact clone in the second monitor. I have an HP compaq desktop...
If the Intel graphic card is part of the motherboard, you need to disable this in the BIOS. You need to install the Silicon grpahic driver, then you will be able to configure the screen resolution etc for each monitor.
Jun 10, 2009 | HP Compaq d530 CMT PC Desktop
How to install new hard drive
2 choices for you. Get the external to run the game or 2. Add a larger hdd to the system as a slave drive leaving the smaller drive as the master. If you go the 2nd route just make sure you buy a compatible hdd. Hope this helps & please remember to rate my answer.
Dec 28, 2008 | HP Compaq d530 PC Desktop
No booting
The problem is Operating systems are co-dependent on hardware.
If the motherboards, processors, ram, video adapters, etc don't match you would not be able to swap hard drives and expect to boot.
You could try pressing F8 on boot and try to access safemode.
If it does boot into safemode immediately it will want to reactivate windows.(because of all the hardware changes.
If it still can't boot, you may want to put the 80 gig in as slave to the 40gig and ghost the 40 gg hard drive over to the 80.
If you don't want to lose your data on the 80 gig then reboot with an xppro cd and reinstall windows in the same partition overlaying the installation on top of existing windows directory.
the new windows will have to be activated but all data will still be there.
Apr 15, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP Compaq d530 PC Desktop Logo
1,196 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
