Question about Acer Aspire™ T180 PC Desktop
Acer aspire T180 will not power on
I have unplugged it and tried to power it back on. the cd drive will eject but cpu will not power on. cant find my receipt to see if its still under warranty
  • evasiveltk Jan 08, 2009
    ow... sounds exactly like my presario s40wm-b model... it does that and the hard drive spins with all the fans... but the thing wont get on the boot screen... i took it to the people down in my town and they said i have to replace the motherboard.
  • Whodatbe May 11, 2010
    Do you hear or see any fans running? if not then it is likely a motherboard issue, or possibly a bad power supply. it may be best to take it to a shop so they can check for a short or blown capacitors.
    Genius:
  • Acer Master
  • 1,102 Answers
If you hear no fans it does'nt neccessarily mean a motherboard problem.
I would think this may be your power supply.
Most small pc repair stores will test the power for you on the spot
at little or no cost.
Is the fan on the back of the pc powering
let me know
Posted on Jan 13, 2009
Acer aspire t180 cd tray wont open
It could be a few things but does not sound software related. 1.) The drive is bad (happens more often than you would think). 2.) No power to the cd drive (less likely)-The power cable attached to the cd drive has come loose or fallen off. You will need to open up the computer case to check. 2.) A cd is stuck in it (even more less likey)There is usually a tiny hole on the front of the cd drive that you can fit the end of a paper clip into. Push the paper clip in and it should force the cd tray to open. You will need to push the tray closed with your hand. Considering you can buy a new CD Drive for about $40 now, and the fact that more than likely the drive is bad, I would go out to Best Buy and get a new drive, and replace the one you have. If for some reason that does not work, you should be able to return the new drive to the store.
May 11, 2014 | Acer Aspire™ T180 PC Desktop
At startup, screen flashes blue, but will not stay open long enought to read. continues to enter setup. nothing will open vista program fron there. only repeats steps
If the Operating System Restore CD finishes and the computer reboots and ejects the CD and it still doesn't work, the problem could be with your hard drive.
If the computer powers off on its own unexpectedly, the problem could be with your power supply.
Replacing these parts can be done in most cases using only a screwdriver to remove the case screws on the computer, opening the case, then unplugging the old unit and plugging in the new one in the same spot.
Dec 05, 2013 | Acer Aspire™ T180 PC Desktop
My acer t180 freez in screen acer
Mine had the same problem. I left it on for 30 mins and it finally booted.
Have you tried the step of removing battery and unpluging power supply for at least ten minutes ?
Apr 21, 2012 | Acer Aspire™ T180 PC Desktop
I have a disc jammed in the disc drive of my acer aspire 1800. How do I remove it
Normally there is a manual eject hole near the disk tray. Use a paperclip straightened out to eject the tray
Aug 07, 2011 | Acer Aspire™ T180 PC Desktop
Trying to find my aspire T180 factory setting password so i can take it back to factory setting
first power off your system remove the cover in the motherboard remove the small battery and switch on the computer while doing make sure all the hard disk and cd rom power has to be removed then place back the battery in the compartment then switch on the system press Del button and enter the correct date and time then click save and exit then connect the HDD and cd drive power and switch on the computer your computer is now set to factory defaults
Feb 26, 2011 | Acer Aspire™ T180 PC Desktop
My cd drive won't open. When I press the open button nothing happens.
probably there's something wrong with your cd drive,the connection might be loose enough for it to run properly. try to open your cpu box and remove the cd drive for a while from the mother board and connect it back...
Nov 02, 2010 | Acer Aspire™ T180 PC Desktop
Acer Aspire T180 Won't turn on--
There is a similar problem posted here: http://www.fixya.com/support/t344696-acer_aspire_t180_ub72_not_boot
Unplug all USB devices as it may be trying to boot from a USB drive.
If you don't have USB drives plugged in try booting into the BIOS to see if the computer is booting that far. Restart the computer and keep hitting the DEL button, that should get you into the BIOS.
Aug 14, 2008 | Acer Aspire™ T180 PC Desktop
Startup problem
i suggest you do this: When the Acer screen pops up, hold Alt and tap F10, doing this will restore your computer to factory settings.
Dec 30, 2007 | Acer Aspire™ T180 PC Desktop
How do you reset Acer Aspire T180-GB7Z PC
Perform a system recovery:
Does not come with recovery cd's - there is a program that allows you to burn the disks or
recover.
3 ways:
1. If in Windows - Start - Programs - Acer empowering technology - Acer E-recovery management -
click on Restore at bottom then "Restore to factory default settings"
2. Or click on Burn disks instead of restore
3. if unable to ge into Windows then Alt/F10 during boot right after Acer splash screen on startup
End User Technical Support and Service (USA only)
For end user technical support, spare parts and service: 1.800.816.2237
Acer Aspire™ T180 PC Desktop Logo
113 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
