Question about Lucent PARTNER18 Corded Phone
We had a power outage and now unable to retrieve voicemail
Messages on system manager phone as her password was forgottenLost power and need to re-program 18d phone.
  • 1 more comment
  • gteducati Jan 07, 2009
    Lost power and need instructions on how to re-program.Incoming calls ring one time and then goes to intercom.
    I need to re-program my lucent 18D phone,do not have password.
    How do i set the number of rings to answer on a lucent 18D?
  • 19,396 Answers
Contact lucent support at 1-888-232-4111, they will assist step by step in configuring your phone.
Keep the number above for further reference.
Posted on Jan 09, 2009
  • 916 Answers
Here is the manual for your phone I hope it helps you
http://support.avaya.com/elmodocs2/partner_acs/r7/518457701_2.pdf
Posted on Jan 08, 2009
    Genius:
  • 1,239 Answers
Hi here is it
NOTE: Only StarMOBILE can be used to perform this recall. Attempting to use the StarSCAN will cause an error message indicating “This ECU cannot be flashed by StarSCAN. Please flash this ECU with StarMOBILE.” This procedure must be performed with software at the latest release. If this WIN flash is aborted or interrupted, repeat the procedure. 1. Open the hood. Install a battery charger and verify that the charging rate provides 13.2 to 13.5 volts. Do not allow the charger to time out during the flash process. Set the battery charger timer (if so equipped) to continuous charge. NOTE: Use an accurate stand-alone voltmeter. The battery charger voltmeter may not be sufficiently accurate. Voltages outside of the specified range will cause an unsuccessful flash. If voltage reading is too high, apply an electrical load by activating the park or headlamps and/or HVAC blower motor to lower the voltage. 2. Connect the StarMOBILE scan tool to the vehicle data link connector located under the steering column and place the ignition to the “RUN” position. 3. Power ON the StarMOBILE scan tool. 4. Connect the CH9410 StarMOBILE scan tool ethernet cable to the StarMOBILE and the dealer’s network drop. 5. From the desktop, launch the “StarMOBILE Desktop Client” software. 6. Establish a connection with the StarMOBILE scan tool. 7. Select “ECU View”. 8. Select “WCM Wireless Control”. 9. Select “More Options”. 10. Select “ECU Flash”. 11. Select “Browse for New File”. 12. Enter your ID and password.
Posted on Jan 07, 2009
  • ABHISHEK.C
    ABHISHEK.C Jan 07, 2009
    13. Compare the highlighted software part number with the software part number
    displayed at the top of the screen.
    􀂾 If the part numbers are the same, the module is up to date and
    reprogramming is not required. Continue to Step 20.
    􀂾 If the software part numbers are different, continue with Step 14 to
    reprogram the module.
    14. Highlight the required flash file and select “Download to Client”.
    15. Click the “Close” button and then the “Back” button.
    16. Highlight the desired file.
    17. Select “Update Controller,” press the select button and follow the on-screen
    instructions.
    18. Resynchronize each Remote Keyless Entry (RKE) transmitter (also known as a
    FOBIK) using the following procedure:
    a. Remove the “Start” button cover, insert the RKE transmitter into the ignition
    switch and start the engine.
    b. Allow the engine to run for a minimum of 5 seconds.
    c. Turn off the vehicle and remove the RKE transmitter from the vehicle.
    d. Verify the function of the RKE transmitter to ensure proper operation.
    e. Repeat Steps 18a through 18d for all additional RKE transmitters.
    f. Install the “Start” button cover.
    NOTE: If the customer did not bring both RKE transmitters, be sure to
    explain the synchronization process to them so that he/she can synchronize
    their other RKE transmitter(s).
    19. Clear any Diagnostic Trouble Codes (DTCs) as follows:
    NOTE: Due to the WIN programming procedure, DTC(s) may be set in
    other modules (PCM, TCM, ABS, BCM, MIC, WCM, etc.) within the
    vehicle, if so equipped. Some DTC's may cause the MIL to illuminate.
    a. From the “Standalone Home” screen highlight “All DTC’s” and then press
    the select button.
    b. Highlight “Clear All Stored” and then press the select button.
    c. Follow the screen prompts on the StarMOBILE screen.
    20. Turn the ignition key to the “OFF” position and remove the StarMOBILE unit,
    StarMOBILE cable, and battery charger from the vehicle.
    Claims for vehicles that have been serviced must be submitted on the
    DealerCONNECT Claim Entry Screen located on the Service tab. Claims
    submitted will be used by Chrysler to record recall service completions and
    provide dealer payments.
    Use one of the following labor operation numbers and time allowances:
    Labor Operation Time
    Number Allowance
    Wireless Ignition Node update
    previously performed 08-H2-91-81 0.2 hours
    Reprogram Wireless Ignition Node 08-H2-91-82 0.3 hours
    NOTE: See the Warranty Administration Manual, Recall Claim Processing
    Section, for complete recall claim processing instructions.
    All dealers will receive one copy of this dealer recall notification letter by mail. To
    view this notification on DealerCONNECT, select “Global Recall System” on the
    Service tab, then click on the description of this notification.
    Service Procedure (Continued)
    Completion Reporting
  • 827 Answers
If the message waiting light is on. Is it lit on ext 10? If so, there might be a message in the general mailbox.
Log into voicemail
Use mailbox 9991 #
password is 123456 #
See if there are messages in there.
Hope this helps
Chris (ziraffa)
  • chris grams
    chris grams Jan 07, 2009
    Hi again,
    try this:
    To change the ringing on the phones:
    From Ext. 10 or 11:
    Feature 00
    Left Intercom Twice
    Right Intercom Once
    Dial the Extension Number you want to program
    The lines light up:
    Steady Green for Immediate Ring
    Slow Flashing for Delayed Ring
    Fast Flutter for No Ring
    Touch each line button to toggle the ringing for that line.
    When they are set, press the Right Intercom to do another extension,
    or Feature 00 to quit
    Can't synch the time with any external source, but to change the time, again go to Ext. 10 or 11
    Feature 00
    Left Intercom Twice
    Dial #103
    Enter the time as HHMM (24 Hour Military format)
    Feature 00
    Hope this helps
    Chris (ziraffa)
  • chris grams
    From manual:
  • 4,806 Answers
Hi there
  1. While the telephone is on-hook, press the PROGRAM button
  2. Press [Redial]
  3. Press the appropriate access code and number of pauses
    in order to get a second dial tone
  4. Press the PROGRAM button again
Good luck
  • Lee Hodgson
    Lee Hodgson Jan 07, 2009
    System Reset—Programming Saved
    (#728)
    Description
    This System Programming procedure resets the system while retaining the
    currently programmed settings. Reset the system only when it fails to function
    correctly after a power failure or down period.
    Considerations
    Using
    This procedure is skipped in the sequence of programming procedures
    when cycling. To use this procedure, enter the code directly.
    The system reset begins immediately and takes only a few seconds.
    Resetting the system disconnects all active calls.
    Resetting the system resets any active features at an extension to the
    programmed settings. For example, if an extension has calls forwarded to
    another extension, resetting the system turns off Call Forwarding (if the
    feature is programmed on a button with lights, the reset also turns off the
    light for the Call Forwarding button).
    You cannot interrupt the reset process or use any telephones in the system
    during the reset process.
    To reset the system:
    Press Feature ( 0 ) (0) System Program System Program # 7 2 8 . The display reads:
    Reset–Save All
    When the reset is completed, the system is no longer in programming mode and
    the date and time appear on the display. If a power failure has occurred, the
    time may not be correct; change it using System Time (#103).
    System
    Good luck
  • Lee Hodgson
    For extensions X and Y, set Line Ringing for all lines to Immediate Ring.
    Use Line Assignment (#301) to assign all the lines to extensions X and Y that
    you want the machines to cover.
    Make sure extensions X and Y are not assigned as Pickup Group Extensions
    (#501), Calling Group Extensions (#502), Night Service Group
    Extensions (#504), or Hunt Group Extensions (#505).
    Adjust both answering machines to answer on a different number of rings (so
    they do not both try to pick up the same call). For example, set answering
    machine 1 to 4 rings and answering machine 2 to 6 rings. (If you cannot
    adjust the two answering machines to answer on a different number of
    rings, assign some lines to Immediate Ring at extension X and other lines
    to Immediate Ring at extension Y.)
  • 4,472 Answers
I am going to need you to redescribe your problem more clearly. The password has been forgotten?
Thanks,
Lee
    Sergeant:
    Novelist:
  • 326 Answers
Cant get your question exactly plse rewrite your question with complete details and wat help you need exactly.
We had a power outage at our office and when the power came back on, our voicemail was not working. All other functions on the phone work, but we cannot retrieve voicemails or transfer to them.
Depending on your system and the level of power overvoltage protection you could have easily fried a component of the system - ie if your system is disc dependent for holding messages ( ie like old Octel systems) you could have fried the disc or disc controller.. Have you carried out an experiment yet by calling yourself and leaving a voicemail message to see if the system itself reports any error when trying to post a message?
Jan 16, 2017 | Lands Phones
Restore incoming call rings after power outage AVAYA
If you have a Backup & Restore card you can manually restore the system. If not you will have to restore everything by manually including voicemail greetings and automated attendants.
May 21, 2014 | Avaya Corded Phone avaparp18d
Message light blinking but no message there cannot remove message light
you have to log in to your account at the phone service provider and reset message waiting indicator. If you have a contract company managing your ip phone service, call them, and say you need the message indicator reset.
Mar 07, 2013 | Mitel 5330 IP Phone
Lost directions on uniden cordless phone DXAI8580-2, unable to access message as code using does not work????
If you mean the PIN for remote access, that's a two-digit number. If you've forgotten what it is, you can change it at the base station by following the instructions on page 12 of the manual.
If you mean the messages on your telephone company's voicemail system, try dialing *67 (that's star-six-seven). If that doesn't work, contact your telephone company for instructions on accessing their voicemail system.
Jul 10, 2012 | Lands Phones
How can I check the voicemail, my assistant left and I don't know how to retrieve?
Where did your assistant check the voicemail? In a TVA system, each extension VM password can be reset from mailbox 999. If you don't have that password, you would have to call your dealer/installer or check their notes. If you're trying to get to the General Delivery Mailbox, it's done from the Message Manager's mailbox (998). Again, it needs notes, but I think you can reset that password from MB 999.
Carl
Aug 13, 2011 | Panasonic KX-T7633 Corded Phone
Don't know how to retrieve voicemail
On the main base is a round silver button. At the bottom of the button says play. It this does not solve your problem you may have erased them or your volume is turned down so you can hear them.
Jan 23, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Voicemail
The answer for both of you is the System Administrator's mailbox. It lets you addl, delete and edit mailboxes and reset passwords.
When your system was installed, you should have been given instructions and passwords for both the Message Manager and System Manager's mailboxes. The access to those boxes is similar and I will not give out that sequence in a public forum, but you should be able to find it in the manual or via email to me...I'll show up on the web somewhere.
Carl
Apr 16, 2008 | Panasonic KX-T7433B Corded Phone
Multiple log in to voicemail
We shut the phone system off for about one minute and it reset the system without losing any of the messages.
Feb 07, 2008 | Lucent Lands Phones
Power outage last night. Deleted all saved voicemail messages. when turned on - machine says "no massages" How do I retrieve lost messages?
I'm sorry there isn't. Answering machines like this have very little ROM memory. After a powersurge and outage like last night, it wiped the whole memory chip. You can try there support page. It's actually pretty good. http://telephones.att.com/telephones_ui/support/index.cfm
Jun 28, 2007 | Lucent 1872 Corded Phone
Lucent PARTNER18 Corded Phone Logo
Top Lucent Lands Phones Experts
Paul C.
Computer Repairing
Computer Repairing
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
