Question about Panasonic NV-GS15 Mini DV Digital Camcorder
Camcorder LCD screen only operates up to 30 degrees from camera
The title says it all really. As I open the LCD screen, in either film or playback mode, the picture blanks out when the screen is opened more than about 30 degrees. The viewfinder remains operational throughout. Help!
  • 883 Answers
Open the unit. find the flat flexible connector to the LCD and then look at each end to verify if fully inserted into its mating connector.
Posted on May 31, 2007
Horizontal lines during playback on canon vixia hfs200
Are these lines showing up on the LCD & or on the resulting videos? I've noticed with mine that if I film in dark conditions, the HD quality is lower with lines or artifacts in the video. Otherwise, you may need a new LCD, but if it's not affecting the resulting videos, and you can see to film using the LCD, you can still use it as is.
Mar 23, 2013 | Canon VIXIA HF S200 High Definition Flash...
Hello, I opened the LCD monitor to right angles
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Sep 01, 2011 | JVC GR-D870 Mini DV Camcorder
THE LCD BUTONS ARE NOT FUNCTIONING/JAMMED,SO I CAN'T PLAYBACK OR RECORD.i HAVE TRIED TO FOLLOW THE INSTRUCTION FROM THE MANUAL ON TROUBLESHOOTING THE PROBLEM BUT FAILED.(switching between off and playback...
try to press the reset button. (there is a small hole inside when you open the lcd screen. press and hold the reset button inside that hole for 3 seconds and try again. you can also try removing the battery and then press and hold the power button for 30 seconds and try again.
Sep 07, 2010 | Sony Handycam DCR-HC30 Mini DV Digital...
LCD screen working only if turn counterclockwise
make sure you open the lens 90 degrees to the camcorder.normal operation of the cam will allow you to rotate the lcd to a maximum of 180 degrees and can eve close it with the lcd screen side facing out. you can try pressing the reset button.if it still won't work try removing the battery and unplugging it from the ac adaptor for at least a minute.if still doesn't work properly,issue could be with a bad ribbon inside the lcd that loses contact when you turn it clockwise.that of course would need replacement or repair.
Dec 06, 2009 | Sony Handycam DCR-SR80 HD Camcorder
Sanyo xacti digital camcorder screen not working when opened out
Hi!
It's most likely a damaged LCD cable which goes through the hinge - happens to many camcorders. You will have to contact your local Sanyo service center. I replace these cables for Sony camcorders every day.
Sorry for the bad news, but hope this helps.
Tom
Sep 27, 2009 | Sanyo Xacti E1 Waterproof Camcorder
The playback doesnt work
u can fix the problem by using the cleaning tape, play it for a 10 sec. only and then your camcorder would be fine. if problem persist then go to the nearby service centre .because you would nt be able to clean its drum Assy. manually.
Jun 17, 2009 | Sony Handycam DCR-VX1000 Mini DV Digital...
Can not import film to PC.
I have a partial solution for those whose files come up as audio. connect your camera via USB. Windows Movie Player should recognize the camera when you select capture device. When you have your camera selected hit next. Put the file in My Video and title it. When you are ready too capture video Hit play on you camera while in the review screen. The Movie Maker will then capture your video as it plays in the camera.
Jan 09, 2009 | Samsung SC-DX103 DVD Camcorder
Lcd buttons not responsive
Flexible Cable between LCD and Camera circuit seems damaged. Change this cable and hope problem will be solved.
Jun 01, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Mv600i digital video camcorder - no image on lcd screen in cam or playback mode
please someone help with this. My camcoder works very well when watching things I've filmed before but when I want to record it does not function. All I get on the LCD screen is the blue screen with Canon on it and through the lens it is black. The lens cap is of course removed. Then when I turn the red button to off position the camcoder does not turn off and the screen remains blue. I have to remove the battery to turn it off.
I've had my camera for 4 years and I filmed so many precious family moments in it.
Dec 28, 2007 | Canon MV600i Mini DV Digital Camcorder
Panasonic PV-GS35 Viewfinder screen connection problem in hinge joint
the hinge is definetly damaged and is going to need replacing. these hinges do need replacing if used allot because this is a moving mechanical part. This is not a easy thing to do, it needs to be done by a panasonic technician.
Oct 11, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Panasonic NV-GS15 Mini DV Digital Camcorder Logo
93 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
