Question about Brother MFC 420CN All-In-One InkJet Printer
Brother 420 cn / 6 in 1 fax machine will not fax
It dials up and acts like it will fax and screaches, but a message comes up "comm. error 20 02"
Thank You, Monique
  • Frank
    Frank May 11, 2010
    do you need to dial 1 first or is dialing out of a company line then 1?
    President:
  • Brother Master
  • 990 Answers
Hello sir; I believe this problem belong to you phone comp, better contact with them.
Posted on Jan 07, 2009
Comm error message
PROBABLY BAD PHONE LINE, CAN TRY SOME OF THE FOLLOWING
SLOW DOWN THE RX TO 1700
TURN OFF ECM
INSTALL DSL FILTER EVEN IF ITS NOT A DSL LINE
MAKE SURE THE PHONE COPANY KNOWS ITS A FAX LINE
IF ITS VOIP IT MAY NEVER WORK WELL
RESEAT ALL CONNECTORS IN FAX 3900
TRY SETTING TO MMR
MAY ALSO BE PROBLEM WITH THE SENDING FAX MACHINEOR, THERE PHONE LINE
Jul 11, 2013 | Konica Minolta Minolta FAX3900 Digital...
I keep getting comm error 242 when people are faxing to me
The "sender's" fax machine is attempting to RECEIVE a fax. This happens because they don't have the document fully inserted into the scanner before dialing. (According to HP's error code listing for "comm error 242" - http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=buu02549) This is not a problem of a bad connection. Bad line condition codes are 223, 224 and most of the codes starting with 23.
Apr 28, 2010 | HP LaserJet 3050 Printer
I cannot receive faxes - it is coming up with error message comm - err
make sure there is no disturbance in phone line .
make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 19, 2010 | Brother MFC 7420 All-In-One Laser Printer
Cannot send Fax messages on Brother 420 due to full memory.
Perhaps you can try this:
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000100/000095/faq000195_006.html?reg=us&c=ca&lang=en&prod=mfc420cn_us&Cat=11
Nov 27, 2009 | Brother MFC 420CN All-In-One InkJet...
Comm error on a VOIP line
Fax cannot send on a VOIP line unless the VOIP line has T.38 fax protocol service.
Sep 25, 2009 | Brother FAX-575 Plain Paper Thermal
OKIFAX 4580 - Comms error
Hi just a note to say first theing to check is that the phone line is connected at both ends to correct sockets and that the connector to teh fax unit is connected to the line socket and not the phone socket as this is the main cause of line errors.. Good luck you could also check to see of you need to dial 0 or 9 first before you dial your number as you ma y be on an exchange line.. also check the fax settings to see if you have set the line type correctly either pulse or tbx..
Jun 30, 2009 | OKIFAX 4580 Plain Paper LED Fax
Hp laserjet 3380
did it work before??
if it did, then your printer has been damaged due to a surge in your phone line
Feb 03, 2009 | HP LaserJet 3380 All-In-One Printer
OUT OF MEMORY
Go into the printer settings on the computer and change it from-send dirrectly to printer - to - Spooling. It will send a small portion of the print job at a time there for the printer mempry will not overload and report out of memory. Please rate this help if it works for you. Thanks!
Jan 28, 2009 | Brother IntelliFax-2920 Plain Paper Fax,...
Brother MFC 420CN All-In-One InkJet Printer Logo
1,236 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
