Question about Dell Dimension 3000 PC Desktop
Motherboard How do I install a motherboard in my Dell Dimesion 3000? Is it difficult?
  • Dell Master
  • 998 Answers
Here's a link to the Dell Dimension 3000 service manual: http://support.dell.com/support/edocs/systems/dim3000/en/SM/parts.htm#wp1043338
Look over the procedure and see if your comfortable with it.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Posted on Jan 08, 2009
Can a Dell F5949 be replaced with any brand motherboard?
Micro-ATX motherboard to fit your Dell would be difficult to find.
If you find a micro motherboard, check the motherboard mounting holes line up with the Dell's mountng plate.
Jan 22, 2012 | Dell (F5949) Motherboard
Bij doorstarten moet ik steeds f1 indrukken en bij het afsluiten krijg ik een blauw scherm met de tekst Hardware malfuction call your hardware vendor for support NMI:parity check/memery parity...
NMI parity error (Non-maskable Interrupt) is generally a motherboard or a RAM issue.
You can try flashing the BIOS to A04 (You'll need to copy the flash executable to a bootable CD or bootable USB drive to run the flash.
Try individual or different RAM modules
if all those do not resolve, issue is most likely the motherboard.
Jul 07, 2011 | Dell Dimension 3100 PC Desktop
Where and how do i remove the video card from a dimesion 3000
A Dell Dimension will most likely have the video card built into the motherboard. If you are installing a new higher-end video card, just install it in the PCI slot and plug your monitor into that card and install the drivers from the provided CD when windows boots up.
Jan 24, 2011 | Computers & Internet
Dell dimesion runnin win 7 only thing i
sir, i you have your motherboard installer you can use it to let you use your onboard video. please try to install it
Jan 21, 2010 | Dell Dimension 1100 PC Desktop
Hello, i have a dell dimesion e521. Our power
just remove your ram and reinstall it. that is loose contact problem.
Dec 11, 2009 | Dell Dimension E521 PC Desktop
Dell Dimesion 4600-Yellow light after I added memory
take out the newly installed stick and see if it comes on.  if it does, find out if the memory and motherboard are compatible.  if your computer no longer boots even with the new stick taken out, you probably already burned your motherboard and the damage is irreversible.  it can also be a bad stick that you installed.
May 18, 2009 | Dell Dimension 4600 PC Desktop
Wires connection
the display some time come and some time not come
Jan 30, 2009 | Intel D845GVSR Motherboard
Dell Dimension 3000 Motherboard
You can use, the following link to replace the same
http://tinyurl.com/ycofwx
Thanks
proton
Jan 07, 2009 | Dell Dimension 3000 PC Desktop
Motherboard drivers
I believe are speaking of drivers for the audio, video ect. Those can be downloaded from the dell site, go to support and put in the dell service code number that is on the computer. That will lead you to the drivers that you need.
Jul 13, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Burned Out w/Memory Upgrade
Is the video card built into the motherboard? If not you can try replacing just the video card to see if that works. Otherwise I am afraid you may have to replace the motherboard.
Feb 02, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
Alun Cox
