Question about KitchenAid KUDS24SE Built-in Dishwasher
Squeaky dishwasher door
Ten-year-old KitchenAid diswasher KUDS24SEWHO door squeaks loudly when the door is opened or closed. WD-40 was applied to the visible part of the hinge, but the door continues to squeak.
  • 837 Answers
Remove the bottom panel and "lubricate" from below
Posted on Jan 07, 2009
  • Jay Glendenning
    Jay Glendenning Jan 09, 2009
    Have you fixed your "squeak"?
  • 242 Answers
I can help you fix this issue , you will have to pull the unit out a foot or so. start will opening the door and looking up under your counter top , there should be two screws going into the counter top holding the unit in place , remove these and it should slide out.
when you get it out far enough to see the rest of the hinge get some oil/grese and apply to worn spots on hinge , move the door up and down to work it into the hinge. This should fix your problem. let me know if you have any more questions and how it turns out.
Phil
How to fix a squeaky door on a frigidaire gallery dishwasher
Thank you for your post, friend!
I see that you need assistance in repairing a squeaky door on your Frigidaire dishwasher. The best way to quiet down a squeaky door is to pinpoint the cause of the squeak. This could be an issue with your hinges, springs, or the cables. You can use a lubricant such as WD-40 on your those parts to see if that will help alleviate the squeaking. Hope this is helpful. -Matt
Feb 27, 2015 | Dishwashers
Is there any grease points for the door hinges? The door squeaks every time we open.
Hello. Get a can of a penetrating lubricant called WD-40 with a tiny tube applicator included. Open the door and you will see part of each hinge where the door meets the appliance case. Spray the penetrating lube on the exposed part of the hinge and then open and close the door a few times. Repeat as necessary. J.
Jul 01, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher racks squeak
WD 40 on the rack wheels and the tracks this will get rid of the squeak. cycle the dishwasher through a quick rinse b4 washing any dishes.
May 16, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Kitchenaid DW Door is very squeaky and loud
most likely the hinges are partially rusted through. resulting in all of those sounds. i doubt that you could get anyone to replace the hinges for less money that the cost of a new dishwasher so I recommend replacement.
Aug 16, 2009 | Dishwashers
Squeak - Squeak
if it is kitchenaid/whirlpool unit it has 2 nylon ropes that connect door hinges to the springs on either side of door hinges.these ropes slide over plastic wheels and with time it stars making noise.just cln those wheels and apply little bit of regular bearing grease on those plastic wheel.noise wil go away.to do this u have to pull the unit half way out to access those wheels on lhs and rhs lower front end corners of the unit.good luck.
Aug 15, 2009 | Dishwashers
Squeeking, swaking door springs
Hi there
Thats a common problem with sprung door hinges, get some WD-40 lubricant spray and spray the spring until the squeaking stops.
Good luck and thanks for using Fixya!!
Feb 19, 2009 | KitchenAid Dishwashers
Difficult to pull door open and loud click coming from left hinge
I would check for obstruction in the path of the door spring areas. If appropriate, remove the bottom access panel (typically 2 screws); open/close the door in attempt to observe the inside bottom left and right for the clicking sound.
If not already done so, also ensure your dish-washer is raised of the floor a little bit; leveled and properly secured to counter top with 2 screws.
-C
Fremont, CA
Jan 30, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
Squeaky door
wd will not work order and replace the door link assembly installe all parts in the bag, youll be fine easy repair part number 8194001
Nov 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Squeaky door
On our KitchenAid dishwasher we had the same problem--a REALLY loud squeak as it opened. The sound comes from the nylon rope slipping along the plastic pulleys. We've had the DW for about 3 years and the noise has gotten worse over time. I was determined to win the war against the noise and am happy to say I fixed it today.
The trick is to use a dry lubricant on the cord and on the pulleys. I used Dry Graphite by Gunk. It comes in an aerosol spray can and once the stuff dried the squeak was gone. I'll let you know if it comes back...
May 16, 2007 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwashers Logo
617 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
