Question about Sony PlayStation Portable (PSP) Console
PSP unit: when I press the square key, it turns the unit off
Unit is a couple of years old. Worked fine until recently. If I have to press the square key during gameplay, it turns the unit completely off.
  • 25 Answers
This problem of yours is something happen inside your psp try to go to a mechanic for psp he might fix it
Posted on Jan 09, 2009
The drive gear in my 25-30 year old kenwood chef is rounded instead of having square edges. Can I purchase this part worked great until now
extremely unlikely as manufacturers stop carrying parts after 5 years and aftermarket suppliers and service agent after 10 years
you may get gears from alibaba site but the time taken , makes junking it for a new unit a better idea
Nov 23, 2016 | Kenwood Food Mixers
Humidifier not working
Mine is a SUL495 Filter Free unit and worked fine last year and the first couple of days recently, but I'm having the same issue, motor running , no mist, and trying to talk to someone @ in customer service today is a joke, I've cleaned everything but still no luck, I paid $40.00 for this unit in Jan. 2011 and have about two weeks until the warranty runs out, and the other wonderful thing is the nearest service center is about 50 miles away, I may wait until Monady to try to speak to someone, but I probably won't like the answers.
Nov 25, 2012 | Sunbeam SUL496-UM Ultrasonic Humidifier
When printing, lines are not evenly aligned. This is a recent problem as the printer has worked beautifully for years. Is there a way I can adjust this?
Try reset your printer by following this procedure to reset it,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold # and 6 keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
Or
. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state. This should fix the problem.
Sep 16, 2011 | HP PSC 1210 All-In-One InkJet Printer
When I plug my LG dehumidfiyer Model LHD659EBL I hear a small beep and nothing happens. I can not turn it on or get a light on the panel to even light. This unit is only a few years old and it worked fine...
Remove the water collection bucket and reinstall it. Make sure the bucket fits "squarely" in the holder from top to bottom. The bottom should not tilt down at the bottom, when it's properly installed.
While you have the bucket out, look in the top of the bucket for a float valve. If it has one, it may be stuck in the UP position. Juggle the float arm to get it to return to the DOWN Position and reinstall the bucket as described above.
Either of the tings mentioned above, will cause the unit to not turn ON.
Hope this helped you and thanks for choosing FixYa.
Jul 26, 2011 | Dehumidifiers
I have this information in my psp: Setting
we have a same pr0blem. The only soluti0n is hold select botton start triangle nd square.den turn ur unit on. The unit will reboot it self nd bck to original fact0ry settings.
Jan 03, 2010 | Sony PlayStation Portable (PSP) Console
WATER QUIT RUNNING IN DOOR
Okay. My appliance is around four years old. The first time the water quit working was about a year ago (ice cubes / dispenser was fine). I just let it go and didn't worry about it. One day months later, I found it functional again. That lasted about a month or two, then it recently quit again. Tonight, I located the water supply line coupling under the unit on the left side under the freezer door, about five inches from the hinge. I separated the coupling (push lock type) and pressed the water dispenser lever. After a few seconds, the water flowed out just fine. I re-attached the coupling, turned the freezer coldness selector to 0 (off) opened the freezer door and fetched my wife's blow dryer. I ran the dryer along the inside of the freezer door near the black door seal frrom the hinge up to the water/ice dispencer compartment. I also ran it all along the back of the dispenseer compartment to the handle side of the door as I am unsure of where the water line runs. After about ten minutes of this, I attempted to dispense water with no luck. I continued with the blow dryer until the plastic and even the door seal were very warm to the touch. I closed the door and attempted to dispense water once again, and this time it worked. I turned the coldness selector back on. This time I set the freezer to 3 and the fridge to 7. I ran several cups of water through the dispenser since it's been sitting in the line for a while before drinking any. As for the "reservoir," I don't where or if one exists, but heating up the inside of the door from hinge to dispenser worked perfectly. Hope this helps someone!
Cheers!
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Aug 23, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Yamaha RX-V750 AV receiver power problem
i had the same problem, only none of the above worked until someone told be to replace the ceramic cap .022 630v c405 on the sub board, and after this mine has worked fine since
Mar 10, 2008 | Audio Players & Recorders
Magellan roadmate 300 wont stay on
It is the cigarette adapter, mine was doing the same thing until I bought a new adapter. When the old adapter plug to the GPS unit moved at all it would lose power.
Jan 13, 2008 | Magellan RoadMate 300 GPS Receiver
Sony PlayStation Portable (PSP) Console Logo
41 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
