Question about Dell Dimension 3000 PC Desktop
Dell Dimension 3000 Motherboard
I recently purchased a new motherboard for my Dell since they told me my old one was no good. How do i go about installing it? is it difficult?
  • Dell Master
  • 1,183 Answers
You can use, the following link to replace the same
http://tinyurl.com/ycofwx
Thanks
proton
Posted on Jan 07, 2009
I want to replace the motherboard on a Dell Dimension 3000. How do I know which one to get? I have replaced a motherboard on a different computer before but that one was purchased for me.
It uses a ASUS P4P800-VM 478 Intel 865G Micro ATX Intel Motherboard. Know that you will probably have to revalidate Windows after changing motherboards because this is a major hardware change. You may have to call Microsoft. Also have some thermal grease on hand to reinstall the CPU on the motherboard.
Aug 26, 2009 | Dell (2336V) Motherboard
I changed the CPU fan on Dell dimension 3000 but it does not run.
Dell uses a proprietary fan on it's cpu's. This is more than likely your problem. The motherboard does not recognize the new fan and the motherboard is not powering it on. Without replacing the motherboard you are stuck using dell replacement parts for this model. The motherboard & psu are also proprietary in this model so it would take a whole lot of modification to use anything but Dell replacement parts. Your pc is shutting down due to overheating. Sorry. Hope this helps.
Jul 12, 2009 | Dell Dimension 3000 PC Desktop
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
Power source is ok so is the memory , is it the motherboard
That is usually caused by bad ram. Take the new ram out, put the old ram back in and see what happens.
Apr 11, 2009 | Dell Dimension 3000® Pentium® 4...
DVD drive help for Dell Dimension 3000
call DELL support and explain to them, they have send your the wrong type, what you have is IDE, they have send you the ATA. which the motherboard can connect.
Jan 09, 2009 | Dell Dimension 3000 PC Desktop
Motherboard
Here's a link to the Dell Dimension 3000 service manual: http://support.dell.com/support/edocs/systems/dim3000/en/SM/parts.htm#wp1043338
Look over the procedure and see if your comfortable with it.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Jan 07, 2009 | Dell Dimension 3000 PC Desktop
Motherboard blew up
I would recommend buying a replacement computer, and install the Dell IDE drive in an external 3.5" IDE hard drive enclosure. This way you can pull your information off the the Dell hard drive, and then blow it away.
Keep in mind that new computers use a SATA drive, your old Dell '8200 has an IDE drive. Also keep in mind that your Dimension 8200 drivers won't work on the new computer.
You might be able to install your Dell drive as a slave if you have an open IDE channel available.
Good news is, your old Dell uses RAMBUS memory, which is worth a lot. It's a good parts computer, and most people who look for computer parts know of the bad capacitor issue on Intel made Dell motherboards from that era.
May 15, 2008 | Dell Dimension 8200 PC Desktop
Dell 4600 motherboard
That particular Dell uses a power supply with non-standard wiring. The plug is the same size as an ATX plug, but it's wired differently. If you were to replace motherboard & plug in the standard power supply, it would damage the supply, or the motherboard, or both. Also, the front panel plugs (for power & power LED & hard drive indicator) are proprietary as well. Ideally you should replace it with another Dell Dimension 4600 motherboard. I've found replacements for reasonable prices on some of the auction places on the web. I recently replaced a failed motherboard in my Dimension 8300 with one I got from a popular auction site, I think my cost was about $59 plus shipping.
The other option would be to remove the hard drive, video card (if any), and optical drives, and consider a 'barebones' package from various sites such as geeks or newegg.
Jan 05, 2008 | Dell Dimension 4600 PC Desktop
Replacing the processor on Dimension 3000
Here is a link to the Dell field service manual. I find that these drawings are usually good enough to get me going.
Nov 14, 2007 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
256 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
