Question about HP Photosmart C6180 All-In-One InkJet Printer
Printer will only print, not copy fax or scan
I have a hp photosmart c6180 all in one printer. It has been working great and all of a sudden I can only print now and not copy, scan or fax. I have tried uninstalling and reinstalling and still the same. I can find not a thing wrong with the printer other than only printing. Any help would be great.
  • esrom Jan 10, 2009
    I found out by elimating different procedures that the scan, fax and copy features of my all in one photosmart printer I found that the scanner light was out and could not be reaired , therefore requireing me to purchase a new model, fortunatly this is one of those rare times when I actually bought a extended warranty.
  • 827 Answers
It is possiblethat the all in one solution software you used in XP doesn't work with Vista, after some update or other. You did the right thing by uninstalling and reinstalling. Make sure you have the correct driver from the HP site..
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP C6180) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Posted on Jan 07, 2009
  • chris grams
    chris grams Jan 07, 2009
    Here's the HP software link:
    http://h10025.www1.hp.com/ewfrf/wc/softw...
    Try getting the latest driver for your operating system and installing that from the Device Manager, and installing the driver by using the 'Let me choose the driver' option and navigating to the folder where you unzipped the latest downloaded driver to, click Install, then reboot and it should work..
    There has been a lot of trouble with the All-in-one software and Vista, but if all else fails, Scan by using the Photo Gallery method above.
    Good Luck!
    Chris (ziraffa)
I can't get my HP potosmart C6180 ALL IN ONE PRINTER TO SCAN/COPY OR FAX WITHOUT GETTING A SCANNER FAILURE MESSAGE SAYING UNABLE TO SCAN,COPY OR SEND A FAX
Solved! I now can scan wirelessly throughout my network. I downloaded the drivers for a friends newer HP all-in-one scanner and I can scan. Look for the driver for the 309a series of printers and install it. Complete the install and set up your existing printer. You can now scan, print, fax wirelessly. It includes updated HP apps for these functions that work with OS 10.5. I didn't upgrade to the HP 1.1 drivers through Apple. The file name is: PS_AIO_05_C309a_Net_Full_Mac_WW_102.dmg
May 24, 2011 | HP Photosmart C6180 All-In-One InkJet...
Unable to scan, copy or fax message on HP C6180
Please follow the steps and then let me know the results:Click Here
May 23, 2010 | HP Photosmart C6180 All-In-One InkJet...
My HP C6180 has suddenly stopped copying. All other services work fine (fax, scan, print etc). It selects the paper, the dispay shows it copying...but it doesnt do anything else. I have to power it down...
What you can do is reset the Printer
Unplug the power cable...........
Press and hold # & 9 Button
while holding down plug in the power cable
This is the Printer Reset
But this will erase all the setting in your printer
Oct 17, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180, File is too large to send after scanning
Hi
You may check the resolution of the scanned picture,lowering down the resolution to some extent will not damage the quality of the scanned image,also it will lower down the file size to great deal and this should help you send the fax without any issues.
try it and get back to me for any assistance
thanks
Techbuddy247
Aug 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart c6180 all in one printer will not scan or copy
The scanner bulbs ahve gone bad.U need to get it them replaced.Before that try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
see if it works.
Mar 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 won't scan documents
Suddenly since last week I can not scan to my E Mail or iphoto anything. It simply says -" sorry scanner can not be initialized. Error communicating with scanner
Feb 22, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 prints but won't copy or fax...
i can not recieve faxes. It use to work fine. I can send them out, but not receive.
Jan 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
SCAN,COPY,FAX PROBLEM
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.     Here is a manual if you dont already have one.   http://h10032.www1.hp.com/ctg/Manual/c00486336.pdf
Oct 26, 2007 | HP Photosmart 3310 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
374 people viewed this question
Seeker5211
Seeker5211
