Question about Delta Saws
My 16" Delta band saw blade is drifting how can I fix it?
My blade is drifting, I have replaced my blade guides with Cool Blocks by olson, they fit vary well and are not touching the blade. I used a piece of paper for by measurement between the blocks and the blade. Any thoughts.
  • rheasler Jan 13, 2009
    Sorry, My blade is not drifting on the upper wheel. It is not cutting straight. As I am cutting it is drifting to the inside of my table. The blade is in the middle of the upper wheel, and I have new tires!
  • 21 Answers
The blade guides are not intended to prevent your blade from drifting they are there to ensure proper blade path while cutting forces are being applied. There is a tracking adjustment for the upper wheel. Unplug the saw. Start with light blade tension. Turn the upper wheel by hand while adjusting the tracking knob. When the tracking is close set proper blade tension and check tracking again. You can make fine adjustments to tracking with the machine running.
Posted on Jan 13, 2009
Delta 28-160 3 wheel band saw and the blade slips off after 1-2 rotations of the wheel. I have replaced the tires with the blue tires.
one of the wheels will have an adjustment that aligns the wheel correctly
bands/belts always run to the highest point so one of the wheels is not true and presenting a high point causing the blade to run off
Sep 03, 2016 | Olson Cool Blocks 5008 Delta 28-180, 160 &...
Will a 59 1/2 inch blade fit my protech bandsaw model #3203
Click to open expanded view Olson Tko Special Band Saw Blade (TK17259) by Olson Be the first to review this item Price:CDN$ 24.15 FREE SHIPPING. Usually ships within 3 to 4 days. Ships from and sold by TEXASVALUE. 4 new from CDN$ 24.15 Hard edge Flex back For hard and soft wood, general purpose contour cutting, fast cuts, and medium finishes For Ryobi BS900 and BS901, BandD BS700, Sears Craftsman BS700, Pro-Tech 3202 and 3203, Delta 28-150, Colli Length: 59-1/2" > See more product details
Aug 13, 2015 | Blade Saws
Delta shopmaster. . How do i instal blade guard on Delta shopmaster?
To adjust the blade guides , you have to loosen the lock nut ( it's normal on the upper part of the guide kit, outside part). Move the guide carrrier until both bearings are approximately 1/16" behind the gullets of the blade. Release the adjusting screws to set both bearing guides to within 1/32" of saw blade by turning the micro-adjusting knob. You can then lock the bearing guide in position once the correct adjustment is reached. This works on 14" band saw. This is an instruction from the manual.
Jun 13, 2014 | Saws
KEEPS TEARING TEETH OFF OF SAW BLADES
Saw blade is contacting the blade guide bearings or rectangular bushings/cool blocks. An 1/8" blade is tricky to use. Make some cool blocks from very hard wood the will contact a narrow blade without destroying the teeth the blade will become hot so use blade lubricant stick.
Dec 14, 2010 | Saws
I have an old rockwell 14" bandsaw and am having
Follow these instructions, but before adjusting the guides see the link below.
It sounds like you have not correctly adjusted the guide blocks that ride on either side of the blade, both above and below the table. These small rectangular blocks can be adjusted by loosening the allen set screw in the guide that holds them in place. They should be pressed in against the blade lightly, without deflecting the path of the blade out of square to the table. (You may first have to sand the ends of the guide blocks square if they are grooved from use. Use a belt sander and a pair of vise grips to hold the blocks while you square them off.) Anyway, the guide blocks should allow the blade to run smoothly, (you might hear a tick tick of the weld passing through the blocks), but will not allow the blade to deflect from side to side. Correctly adjusted, they keep the blade aligned with the bearing behind it, and prevent the problem you describe.
Only after you have correctly adjusted these guides just behind the set of the teeth, and the blade is turning freely by hand when you spin the upper wheel, do you bring the bearings in to kiss the back edge of the blade. Make sure the bearings are lubed to spin freely with a little bearing lube or wd40, then bring both the uppper and lower bearings in until they almost spin or just barely spin when the blade is turned by hand. When you exert a little pressure during cutting they will then hold the blade in place between the guide blocks, so the blocks don't wear the teeth away. Please see this link for detailed instructions I gave another user. (possibly also here) They will apply to your saw as well. If you have any questions or further probelms, write back. You may also wish to check here for a pdf manual for your saw.(check both rockwell and delta).
If you take some care to properly tune the saw, you will get much beter cuts and the saw will be a joy to use.
Nov 26, 2010 | Delta Woodworking Delta Rockwell 14 Inch...
I jsut bought a used Delta 28-682 18" bandsaw. I am shocked by the poor quality of the blade guides. They are gapped so far apart that they hardly touch the blade unless it is twisted at a 45 degree...
It sounds as though the friction pads that go on the guides are missing. If you cannot buy a new set, try glueing some teflon blocks of the desired thickness to the guides.
Apr 06, 2010 | Delta 28 682 18" Steel Frame Band Saw
What size guide blocks for band saw 28-185? Are they 5/16 x 5/16 or 1/4 x 1/4?? Thanks.
They are probably the 1/4 , most people make these things themselves out of nylon or some other material, I have seen brass and copper, plastic, anything to let the blade slide. Even saw one saw with round copper rods in the square hole guiding the blade, anything will work. Save the trouble of buying this stuff. Hope this helps.
Jan 17, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
Size of Blade Guide Blocks for Delta BS100
I replaced mine a couple of years back with the cool blocks. Great Product. I have a 10" Delta and they worked great. You can measure the ones you have on the saw now. I can't remember if they are 3/8" or 1/2" blocks. Check out woodcraft.com and type cool blocks into the search field. They have all the different sizes and shapes available. I really think it was the 3/8" blocks that fit. I did call woodcraft to inquire if they would fit in my bandsaw and the customer service was great. They like to talk shop. If you have any questions please post.
Oct 12, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Saws Logo
475 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Delta Saw Expert? Answer questions, earn points and help others
