Question about Konica Minolta magicolor 2430 DL Laser Printer
Want to buy 2530dl but...
I'm concern that the printer wont run 80 pound cover stock, that being the primary stock i use in my small business,would it print on that,do u have an answer?
  • Anonymous Mar 09, 2009
    i changed it to thick stock and have never been able to print on anything other than regular paper...it tries but for some reason it can pick up the thick paper. why?!
I own this printer and I've printed up to 110 lb metallic stock with no problem. Just make sure you change the paper setting to THICK STOCK.
Posted on Jan 25, 2009
Paper jam at fuser
Buy a new fusing unit can't get small parts for the fusing un it for these models
Sep 04, 2014 | Konica Minolta magicolor 2530DL
How do you change a 2002 Harley Road King stator?
Disconnect the battery. Drain the primary and remove the outer primay cover. Take the engine sprocket nut off, take the clutch adjuster out of the center of the clutch assembly and remove the mainshaft nut. This nut has LEFT HANDED THREADS. Remove the nut that holds the primary chain adjuster. Take the engine sprocket, clutch assembly, and primary chain off all together. Then, pull the rotor off the engine sprocket. It can be difficult to get off due to the strong magnets in it. Once off, there are four small bolts holding the stator on and two small screws holding the plug into the case. Installation is the reverse of disassembly. Torque the small Torx bolts that hold the stator on to 40 inch pounds. The engine sprocket nut torques to 150-165 foot pounds with one line of Loctite 271 heavy hold thread locker in it. The LEFT HANDED threaded mainshaft nut torques to 60-80 foot pounds with a single line of Loctite in it. You'll need a primary locking bar to keep the engine from turning while applying torque to the engine sprocket nut and the mainshaft nut.
Good Luck
Steve
Aug 15, 2011 | Harley Davidson FLHRC Road King Classic...
How do i replace the regulator & stator on a 92
There's nothing to replacing the regulator. It simply bolts to the frame. The wires from the regulator to the stator plug into the plug on the lower left front of the engine case. The larger longer wires runs back along the frame and up to the positive post of the battery.
There's a bit more to replacing the stator. To replace the stator, disconnect the battery and drain the primary case. Remove the outer primary cover. You'll have to take the engine compensator sprocket nut off and remove the mainshaft nut that holds the clutch assembly on. To get the clutch assembly off, remove the snap ring in the center of the clutch assembly and remove the clutch adjuster. The mainshaft nut is inside the hole in the center of the clutch assembly. The nut has LEFT HANDED THREADS. Take the nut off the primary chain adjuster and take the engine sprocket, primary chain with adjuster, and the clutch assembly off all together. The rotor is on the engine sprocket shaft. It can be difficult to get off because of the magnets inside of it. The rotor has two holes in it. I use two long bolts and put them just into the holes deep enough to hold the rotor by squeezing the ends together. Pull the rotor off. The stator is held on by four small Torx bolts and it has a wire support that is held on by two small sheet metal screws. When you install the new stator, make sure you use thread locker on the threads and torque the bolts to 40 inch pounds of torque. The sprocket shaft nut torques to 150-165 foot pounds of torque. The clutch mainshaft nut (LEFT HANDED THREADS) torques to 60-80 foot pounds. You'll probably need a locking bar or some way to prevent the engine from turning while you torque the nuts.
Good Luck
Steve
Aug 01, 2011 | Harley Davidson FXR Super Glide...
Need diagram to change stator on 99electra glide classic
I don't know of anywhere that you can get a diagram on how to change the stator in your ElectraGlide other than a factory service manual. But, all is not lost as it's really not that difficult if you have a few tools. An air wrench or you can trailer it to a tire store and give the guy a couple of dollars to take the compensator nut off, a primary locking bar or something to lock the primary from turning while you tightent the nuts, and a torque wrench capable of 150 foot pounds right hand and 60-80 left handed.
First drain the oil from the primary and disconnect the battery. Remove the left foot board. Remove the outer primary cover. Now remove the large compensator sprocket nut from the engine shaft. Take out the snap ring on the middle of the clutch assembly and remove the plate with the two ears on it. Remove the nut inside the clutch assembly. This nut has the LEFT HANDED THREADS on it. Don't forget. Remove the nut that holds the primary chain adjuster on. Now grab the compensator sprocket and the clutch assembly and lift the chain, sprocket, adjuster and clutch assembly out of the primary and lay on sheet of cardboard or something.
Go back to the engine sprocket and remove the sprocket shaft extension. Notice, there are some shims behind the sprocket shaft extension between it and the alternator rotor, do not lose them or mix them up with a shim that is going to come off later. Now, take two long quarter or five sixteenths bolts and stick them in the two holes on the rotor, not deep just about a quarter inch will do. Squeeze them together and pull the rotor off. Behind the rotor is a shim. It should be 0.090" thick, mark or remember that this shim goes there.
Now, you're down to the stator. There are four small screws that take a Torx wrench to remove and a plastic retainer with two small sheet metal screws holding the rotor and rotor plug in. Remove all these. and work the plug out of the case. Sometimes it's easier to simply cut the wires and push the plug out of the case from the inside.
Now, clean the hole for the plug and place the new stator ring on the engine sprocket shaft, plug wires coming off of the rear of the stator. I usually coat the plug with black RTV sealant to prevent leaks and work the plug into the hole from the inside of the case. Once you get it where it should be, put the small retainer back on using the two small sheet metal screws. Position the stator and install the new screws that came with it. If none came with it, put a drop or two of Locktite 242 blue on each screws and tighten them to 30-40 INCH pounds.
Put the 0.090" shim on, the rotor and the sprocket shaft extension with the other shims behind it on the engine shaft. Pick up the primary drive stuff with the engine sprocket in your right hand and the clutch assembly in your left. Hang the cluch assembly or the sprocket on the approtiate shaft and work the primary chain adjuster on the bolt that it goes on. Slide the sprocket and the clutch assembly to their seats on their respective shafts.
Now you will need a "locking bar" to go between the two sprockets, locking into the teeth of the engine sprocket and the clutch sprocket so that they cannot turn as you tighten everything up. Complete the assembly of the compensator sprocket and put two LINES of Locktite 271 red in the nut. Tighten the nut to 150-165 FOOT pounds of torque. On the mainshaft nut inside the clutch assembly, put one line of Loctite 271 red in the nut and tighten it to 60-80 FOOT pounds of torque LEFT-HANDED THREADS. Replace the two eared plate in the center of the clutch assembly and the snap ring. Replace the primary cover and refill the primary with lubricant. Fill just to the bottom of the spring in the clutch assembly. Do not overfill. Your clutch will drag making it impossible to find neutral with the engine running.
Good luck
steve
Aug 15, 2010 | Harley Davidson FLHTCUI Electra Glide...
How do I replace a drive belt on a 1999 harley
On a Big Twin, you must pull the entire primary drive off the engine.
Disconnect the battery. Take the outer primary cover off the engine. Remove the compensator (engine sprocket) nut. This nut is very tight and has Loctite thread locker on it. 150-165 foot pounds of torque. You'll need to something to lock the chain up so the engine does not turn while loosening or tightening this nut. We use what is called a "locking bar". Remove the small plate with the screw and locknut in the center of the clutch assembly. Remove the mainshaft nut up inside the clutch assembly. It torques to 60-80 foot pounds LEFT HANDED TREADS. Remove the nut from the primary chain tensioner. Grab the compensator sprocket and the clutch assembly and lift the primary drive out of the cover.
Take the small screw out of the center of the jackshaft and remove the starter jackshaft.
From the right side of the bike, remove whatever you have to remove to get to the starter, exhaust pipes or whatever. Disconnect the battery cable and the small wire from the starter. Remove the two bolts holding the starter on inner primary cover.
Go back to the left side of the bike. Remove the four bolts that holds the inner primary to the engine, and the two that hold the primary to the transmission. There's one bolt coming in from the backside that has a braided wire on it on the early models. There may be four bolts holding the inner primary onto the transmission. When you have all the bolts out, the primary will come off easily. If it does not seem to want to come off, you may still have a bolt somewhere. Do not beat on the primary cover with even a rubber hammer. It should come right off.
Now, you'll have to remove the rear wheel, rear shocks, belt guards, and remove the swing arm.
As you can see, it's a pretty involved job on a Big Twin.
Good luck
Steve
Jul 27, 2010 | 2000 Harley Davidson FLHRCI Road King...
HANGS BETWEEN GEARS, MANIPULATE THE SHIFTER UP AND
Sounds like you have some shifter pawl problems. If you remove your outer primary cover, you can see the shifter pawl just behind your clutch assembly. The problem could be the shifter pawls, the springs, or the carrier. You'll just have to go in there to find out exactly what it is.
To get the outer cover off, first loosen the primary chain tensioner beneath the primary cover. Then remove the large round cover from the outer primary cover. Beneath the cover is a spring with a locknut over the clutch adjuster. Drain the oil out of the primary and remove all the bolts around the primary including the left side foot rest and the nut at the front. Slide the outer primary cover off as you turn the clutch adjuster clockwise.
With cover off, you may can see the problem with the shifter pawl but I'm afraid that you're going to have to pull the engine drive sprocket and the clutch assembly off to repair it. To do this, you need an air wrench to remove the front sprocket nut and the clutch assembly nut. The clutch assembly nut is left handed threads. Take the snap ring out of the center of the clutch assembly and remove the clutch adjuster plate.
When reassembling the primary, torque the engine nut to 150-165 Foot pounds, the clutch nut torque is 70-80 foot pounds left handed, adjust the primary chain to 3/8 to 1/2" up and down with the engine cold. Check the primary chain adjustment thorough the upper inspection hole on the outer primary cover. I highly suggest you purchase a service manual to refer to if you decide to do this job. If you do it yourself, the book will pay for itself with this one job. Otherwise, this is a pretty advanced job and you might be better off taking to an experience mechanic.
Apr 01, 2010 | 2003 Harley Davidson XL 1200 S Sportster...
How to remove starter on a 2003 softail harley davidson
It's a lot of work.
First, disconnect and remove the battery. Don't want to lose a finger.
Drain the primary and remove the outer primary cover.
Remove the small bolt that holds the jackshaft onto the starter and remove it if you can. If it won't come out, you'll have to take the nut off the clutch assembly and slide it out just far enough to get the jackshaft out. To get to the nut, remove the clutch rod adjuster in the center of the clutch assembly by removing the snap ring. Loosen the nut, left handed threads. When retorquing 60-80 foot pounds, left handed. There is a coupling that connects the jackshaft to the starter, mark which way it comes out. Tapered end towards starter.
Remove the exhaust system if needed.
Remove all bolts holding the oil tank and lift it up as high as possible.
Disconnect the large battery cable and the small wire at the top of the starter.
Remove the two large bolts that hold the starter onto the inner primary cover.
Work starter out.
Mar 31, 2010 | 2003 Harley Davidson FXSTB Night Train
How do I remove the primary to get to my primary shift lever on a 2005 harley super glide
This is a major job. Far too much information for this forum. It will require a lot of typing in this small space.
First, you'll need a few tools that you may or may not have. You'll need an air impact wrench capable of breaking a nut with 165 foot pounds of torque and red locktite on it. Next you'll need a torque wrench capable of putting 150-165 foot pounds of torque on the nut. You'll also need a torque that will torque to 60-80 foot pounds LEFT HANDED. Not all torque wrenches will torque left handed threaded fasteners. If you have these or can get them, Please drop me a line at wd4ity@bellsouth.net I'll type out instructions step by step.
Feb 22, 2010 | 2003 Harley Davidson FXD Dyna Super Glide
When pulling in the clutch there is a loud squalching noise.
Sounds like your clutch throwout bearing is either bad or going bad. This is due to improper clutch cable adjustment. Just like in a straight shift automobile, if you keep your foot on the clutch pedal, the throwout bearing runs continuously shortening the life of the bearing. On a motorcycle, if the clutch cable is not adjusted to have just a bit of freeplay in it, the bearing will run continously as well shortening the life of the bearing. But, then again it could have just been a faulty bearing.
To repair the problem, you must remove the outer primary cover. First, drain the primary/transmission oil. Then you must loosen the primary chain adjuster beneath the primary cover. Loosen the lock nut and turn the adjuster bolt outward to lower the adjuster shoe inside the primary.
Then remove the clutch inspection cover, the small spring, and the locknut on the clutch release mechansim. Remove the left hand foot peg. Remove all the bolts holding the outer primary cover on. As you remove the primary cover, you will have to turn the screw inside the release mechanism inwards to get it out of the release mechanism.
Once you get the primary cover off, you can see the clutch throwout or release bearing in the center of the clutch assembly. Remove the snap ring and pull the bearing out. Inspect and replace the bearing if found to be defective. Carefully drive the center bolt out and the bearing out of it's holder. Install in the reverse manner.
Reassembly is reverse of disassembly. Install a new gasket on the primary and slide the primary cover in place while turning the clutch release screw into the the release mechanism. Install the bolts that hold the primary cover on and tighten. Tighten small primary cover bolts to 80-110 Inch pounds and the left foot peg bolts to 16-28 Foot pounds.
Adjust the primary chain tensioner to obtain 3/8' to 1/2" up and down slack when checked through upper inspection cover on outer primary. To adjust the clutch cable, find the bellows looking cover over the cable adjuster. Loosen the lock nut and adjust the cable as short as possible. Back at that the adjuster on the primary cover, slowly turn the adjuster screw clockwise until it bottoms out and quits turning. Do not force the screw to turn, just until it bottoms out. Now, back it up 1/4 turn and install the locknut. You may have to turn it just a bit one way or the other to get the locknut in. Install the spring and the cover with the quad ring in place. ADD OIL TO THE PRIMARY, 32 OUNCES of H-D Sport Trans or equilivent. To adjust the cable, adjust cable adjuster in the middle of the cable out as far as it will go without forcing anything. Squeeze the clutch lever a few times and adjust the adjuster so that you have 1/16" to 1/8" freeplay at the lever, about the thickness of a nickle between the lever and lever stancion. Lock the locknut on the cable adjuster and reposition the bellows cover.
As you can see, this is not a very difficult job but it is not for the "faint of heart" since it involves removing the primary cover. I would rate the job difficulty as "moderate" due to this necessity. The only special tool required would be a set of snap ring pliers. Good Luck!
Feb 14, 2010 | 2003 Harley Davidson XLH Sportster 883...
Konica Minolta magicolor 2430 DL Laser Printer Logo
91 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
