Question about Olympus Camedia C-8080 Wide Zoom Digital Camera
Shutter Button Stopped Working
I've had an Olympus c-8080 for 4 years and never had any problems with it other than a cracked LCD. Repairs are a bit pricey so recently when the shutter button stopped working I want to see if there is something I can do. The camera started acting weird and not letting me change settings, zoom, etc. so I powered off & on. The camera then acted like the shutter was already pressed, so I power cycled again. Then for about 5 times I could take 1 picture, and then the camera would seem to lock up... now everything works with out problem, except the all important shutter, which still does not respond after a "factory reset". Should I attempt some electric cleaner spray? Should I attempt taking it apart myself?
simplemitch
  • 752 Answers
SOURCE: Shutter release inoperative
The "button" is actually just a plastic extension for the actual switch on the printed circuit board. You will have to dismantle the camera to gain access to the board and then use a DMM to test the switch contacts.
Posted on Oct 04, 2007
jackboy
  • 2985 Answers
SOURCE: olympus mju zoom 140 35mm
This is like to be the zoom motor playing up.
If the camera is new[1 year or less] return it.
A repair is not a likely option.
Posted on Jul 23, 2008
Obertelli
  • 3006 Answers
SOURCE: Olympus C-8080 sticks at f8.0
You're confusing aperture with shutter speed but your camera is operating normally. The C-8080's smallest aperture is f8 and cannot go further.
The ranges available are:-
Wide: F2.4, F2.5, F2.8, F3.2, F3.6, F4.0, F4.5, F5.0, F5.6, F6.3, F7.1, F8.0
Tele: F3.5, F4.0, F4.5, F5.0, F5.6, F6.3, F7.1, F8.0
Shutter speeds are:-
15, 13, 10, 8, 6, 5, 4, 3.2, 2.5, 2, 1.6, 1.3, 1, 1/1.3, 1/1.6, 1/2, 1/2.5, 1/3, 1/4, 1/5, 1/6, 1/8, 1/10, 1/13, 1/15, 1/20, 1/25, 1/30, 1/40, 1/50, 1/60, 1/80, 1/100, 1/125, 1/160, 1/200, 1/250, 1/320, 1/400, 1/500, 1/640, 1/800, 1/1000, 1/1250, 1/1600, 1/2000, 1/2500, 1/3200, 1/4000 sec
I cut and pasted the above figures rather than typing them all from:-
http://www.dpreview.com/reviews/olympusc8080wz/
Posted on Jul 02, 2009
  • 22 Answers
SOURCE: Olympus C-8080, everything works except the shutter release
Does the shutter button feel like it's contacting twice as you press it in? if not, the spring disk in the switch is split; It has happened to me on other cameras on several occasions. Solution is to replace the switch.
If it works otherwise I would suspect the ribbon cable. They can get loose, or the contacts can get oxidized. I don't know specifically about the c-8080, on some cameras the contacts are tinned, which can oxidize. In that case it's a matter of gently rubbing the contact strip with a paper eraser until the contacts become shiny. Of course, that means disassembling the camera ;)
You've probably retired this camera or don't have it anymore but in case you still have it, I hope this helps a bit.
Posted on Dec 17, 2010
mark24354
  • 776 Answers
SOURCE: camera (Olympus SP500-uz) turns on,
Make sure you have the switch turned to "take picture (camera)" instead of "reveiw photos (green triagle)". On this one, i think it is a wheel on the top of the camera.
Only thing I can think of...
-Mark
Posted on May 05, 2011
Olympus lens 14 45
contact not the same check with with camera makers
May 18, 2014 | Olympus Cameras
Nikon D300s shutter button not working intermittently. Have to turn off and on to get back to work. It's not a focus problem. I've been using this camera daily for a year.
Sounds like you have a bad release switch. The switch is a bunch of stacked rectangular metal leaves, and they develop metal fatigue or just crack with heavy use. Unfortunately Nikon stopped selling parts July 13th, 2012 so you are pretty much out of luck trying to fix it yourself or find a reasonably priced independent servicer to fix it for you. [You might get lucky and find one that still has the part in stock, or find someone selling them on Ebay]. You will most likely have to send it to Nikon. Good luck.
Feb 27, 2013 | Nikon D300 Digital Camera
Olympus C-8080, everything works except the shutter release. I press the shutter button, auto focus is done but "no shutter release". Any ideas? Derek
Apr 28, 2010 | Olympus Camedia C-8080 Wide Zoom Digital...
Is there any way to rig a remote shutter-release for the Olympus sp 550 ouz camera?
yes there is. There are many different ways. but instead of explaining them all. I want you to go to google and type in "remote shutter-release for the Olympus sp 550 ouz camera" There are many websites that explain how to do this, and also sell the kits as well
Jul 07, 2009 | Olympus Camedia C-8080 Wide Zoom Digital...
Jun 28, 2009 | Olympus Camedia C-8080 Wide Zoom Digital...
Stopped working
check the cover and make sure the switch is making good contact... also if the cover is loose... tighten up the screws
Sep 01, 2008 | Olympus Camedia C-350 Digital Camera
Cannot see any picture in my view-finder or LCD
Sounds like a CCD issue, can yoou see menus and pre problem recorded pics on the memory cards but no live views That is a CCD issue, ala C-5050 CCD recall problem, identical symptoms.
Nov 16, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Olympus C-8080 LCD wont work
Is the battery setting set to Battery Save mode. If it is then the view screen does not work.
Apr 07, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
AF Illuminator
The AF illuminator allows the auto focus system to focus on dark subjects. When the shutter button is pressed half way, the AF illuminator will light up the subject. The default setting is “ON”.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
IESP auto focus
iESP is the default auto focus setting for the C-8080 Wide Zoom camera. It uses a contrast detecting system to analyze the entire image by comparing the subject against the background to achieve focus. When the shutter button is pressed half way on the C-8080 Wide Zoom, the AF target mark automatically moves to an area of the image where it finds the optimal contrast.
Olympus Camedia C-8080 Wide Zoom Digital Camera Logo
201 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
