Question about Epson Stylus RX425 Multifunction All-In-One InkJet Printer
Printing half the page
The printer seems only to print half of the page (width-wise). The right half of the page is always completely blank, and there is a sharp line between the two. This occurs when I print from the laptop, but even occurs when the laptop is not connected, and it's just photocopying. Anyone have any ideas? Thanks, Paul
  • Paul Roberts Jun 02, 2007
    The technical support was no help.
    It hasn't sorted itself out yet :-(
    Genius:
  • 2,985 Answers
Do you know I've had that sometimes- then it sorts itself out. Try Epson technical support on the web site. or www.fixyourownprinter.com
Posted on May 30, 2007
  • john ash
    john ash Jun 02, 2007
    Try this.
    Go to Start/Printers and Faxes
    Right click on th printer and delete it.
    Find the software disk.
    Come off line and deactivate the Anti virus program.
    Unplug the USB printer line.
    plug the USB printer line back in and run the disk when asked to by the printer installation program.
    Takes about 20 minutes to do all this.
    When done try a print run
    Cime back and tell
  • john ash
    also try a look at
    fixyourownprinter,com
Horizontal alignment ok, but right half not printing.
One of two situations exists:
1. If the printing stops with clear stopping edge, then the PRINT WIDTH setting has been changed from the default full width setting of 104mm.
Check this by pressing MENU and then the NEXT button until you see a setting for MAX WIDTH. It should be set to full width of 104mm. Anything less will stop printing beyond whatever the setting is. Change it back to the full width setting.
2. If the printing stops by fading away to the right side, then that is caused by a pressure imbalance across the printhead. There is more pressure on the left side than the right side. There are two toggles that press down on the printhead and the pressure can be adjusted by moving the right toggle to the right so that more pressure falls on that side of the printhead.
Hope that helps !
Jul 20, 2010 | Zebra 140XiIII Plus Thermal Label Printer
The printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Feb 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
The printer does not complete printing the page and starts printing the other page whereby the first page is half blank.please assist me
good day. you may try re installing your printer driver and follow the steps carefully, hope this helps, have a nice day
Feb 04, 2010 | Epson LQ 680 Matrix Printer
No printing, just blank papers shooting out
First verify that the printer is working by printing a configuration page from the printer itself. If it prints fine, uninstall and reinstall the printer with the latest driver from HP.
If the printer will not print an internal config page, replace the ink cartridges.
Jun 22, 2009 | HP Photosmart C7280 Printer
When I click "Print" paper feeds through the printer, but nothing prints
try to reload your catridge on the carrier or cartridge holder..
and clean your printer tab circuit and also the cartridge tab circuit and run maintenance page on it..
go to your printer panel and select maintenance ..browse clean printhead..and print maintenance page..to clean the cartridge..
May 18, 2009 | HP Office Equipment & Supplies
Canon MP730 won't print at all (blank pages).
try to move the blue nozzel over the printing head to the from the right to the left and try, it will work
Feb 03, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Zebra TLP2844 Prints Centered and Half the Width
create a word template document with the page size the same size as the label. Set the margins to 0 and fill the label up with text. This should make the printer print right the way over the bale.
Nov 21, 2007 | Zebra Eltron TLP 2844 Thermal Label...
140XiIII left side print right side completely blank
Verify your LCD Display Print Width setting is set wider than your actual label width. The printer will only print to the width of the PRINT WIDTH setting. Also verify any driver or software settings as these override your printer settings.
Jun 30, 2007 | Zebra 140XiIII Plus Thermal Label Printer
Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
342 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
