Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL Washer
I have a Maytag Neptuen TL top load Washer. The display board does not engage. You push the buttons and it beeps but does not activate the command. It appears as if it is on pause, the time duration blinks but the machine does not start. Please help. The machine does not start at all.
  • carlos gonzo Jun 03, 2007
    After trying out your suggestion, the washer began to cycle but it wouldn't stop after that. It kept washing the close without stoping. A Tech came out and stated that the control panels weren't functioning property. Still have a non-functioning machine.
  • Anonymous Mar 26, 2014
    some buttons are lit but nothing works
  • 883 Answers
If this worked fine before, then I am only guessing that the water inlet valve has malfunctioned. try filling the machine with a garden hose...any change? if still no go, then be sure to have a shop-vac handy to remove the water you just added.
Posted on May 31, 2007
SOURCE:
The machine will display time of cycle, but once you press start it will not start. Some of the cycles when you press the buttons will not register. There is no code displayed. How can I be sure its the...
Google this Neptune TL Washer FAV6800AWW
You will find FAV6800A or FAV8800A help. I would not by a Control Board or any part until more trouble shooting is completed. We need to make sure you can get into Service Mode nd do some basic checks.
Mar 10, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Butoons on contro panel don't work
Cheryl,
I understand what you said. It sounds like your machine is the FAV9800A LCD Maytag Neptune TL. Is that correct?
If so try to power Cycle the washer control board by unpluging the washer 120VAC power for 30 seconds then re-power bach up.
If that dosen't clear the issue you may have a Control Board failure or issues with the KeyPad ribbion cable from the Console to the to the Control Board.
Here is the Service Manual for for the FAV6800A and your machine I believe FAV9800A. If you could confirm your model number.
Service Manual for reference. Sears Parts Direct for reference.......Rich
May 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune TL that the display is changing and beeping while the load is running and we can not change from the bulky cycle.
I feel you have a Control Board issue. This could be difficult to troubleshoot if you don’t have access to a replacement Control Board. See this post for random activity of the Console. If you decide to DIY I will help………Rich
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
May 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune tl washer
You will need to replace your timer control.
John
Sep 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune TL
Sounds like keypad needs to be replaced.
Jun 19, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Spin Option
The problems posted by kim875 and kirsty2 all seem to be the result of faulty signals from the electronic board. This seems to be a real problem with this model machine. I would try to get board replaced under warranty , if at all possible.
Dec 05, 2007 | Maytag Neptune FAV6800AW Top Load Washer
All buttons cause machine to beep
Trying unplugging for 20 minutes maybe you can reset it.
Aug 28, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
384 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
