Question about Zanussi ZEBF277W Bottom Freezer Refrigerator
Bad smell in Zanussi fridge
When I open the door to my zanussi fridge freezer there is a bad smell. However i have clearedthe fridge out completley and the smell still remains. It is only apparent when the door has been closed for some time so I'm thinking that maybe it is something to do with a build up of gasses?
  • eltham219 Nov 22, 2009
    Hi I have zanussi fridge freezer ZNB 323W which has had a bad problem intermittenly with odours I recently discovered that the bottom door tray allows spills (significantly milk)to escape into and through the lining of the door into the door itself and stay there. I discovered this while trying to clean the seals around the door and putrid liquid was escaping I have now cut open the seal and a lot of curdled and bad milk was there in liquid and solid form however I cant seem to accesss all of it as this very bad smell persists, this fridge was expensive and is only 1 and an half years old.. how can I get the door open to clean the inside... it is a very bad design fault here ! you should test it out yourself, the tray for milk ( with the white plastic fingers to hold stuff in place) sits into the bottom part of the door... if you spill a small amount of coloured liquid into this you will see the problem it disappears into the door !!! its a health hazard
5 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Posted on Oct 09, 2007
  • 54 Answers
SOURCE: zanussi zk73/46ef freezer working fridge is warm
if this is an air blown cabinet defrost it for 48hrs leave the doors open then try it. hope this helps
Posted on Feb 14, 2008
  • 51 Answers
SOURCE: smell
Try lemon and baking soda scrub
Posted on Sep 08, 2008
woodchuck789
  • 4070 Answers
SOURCE: zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Aug 24, 2009
How do I get rid of bad smell in the freezer part of my Zanussi fridge freezer ZBB 6286. Pilot light and fast freeze light are flashing.
first cut a potato in half and push it ion the middle of the freezer, it will absorb the airborne bacteria and reduce the smell . leave in freezer for about 2 hours then take out an throw away. next pour bicarbinate of soda into a bowl and put it into the freezer also leave overnight and smell should be gone
Mar 03, 2015 | Zanussi Refrigerators
Alarm does not come on when the fridge door is left open on frigde freezer
Alarm probably frozen, leave door open to let heat in to melt ice, the remove device.
Dec 14, 2014 | Zanussi Refrigerators
Zanussi zenb9950si
What is the beep for ? Temperature sensor ? Power sensor ? Door open sensor ?
Oct 30, 2013 | Zanussi & Electrolux Fridge Freezer Handle...
I have thoroughly cleaned out my Zanussi fridge/freezer, but there is still a lingering smell. It is definitely not food related, Could it be to do with the 'gassing' of the appliance?
unfortunaly you will have to remove the back panals in the freezer to expose the evaporator... and spray with antibactirial cleaner.. as barcteria grows hear and causes smells... nothing to do with gassing.... if gas leaked out the appliance wont cool at all.... Rob
Feb 06, 2011 | Zanussi Refrigerators
I have a zanussi fridge freezer model no zx56/4w. the fridge door was left open for 10 days now fridge is too warm and freezer is icing up
you need to totally defrost the fridge/freezer and start as if it were new and dry.allow 24 hours for the unit to settle to the correct temp.
please leave feed back
Sep 16, 2010 | Zanussi ZX56 / 4 Bottom Freezer...
Smell
Aug 25, 2008 | Refrigerators
I have an unexplained smelly zanussi fridge/freezer model Model zx99/5si? I have a zanussi frost free fridge/freezer model Model zx99/5si which is just 4 years old and it is now giving off a revolting...
Hi - we had this problem, and it was in fact where some blood from a defrosting pice of meat drained into the compressor condensation tank and began to decay!
I agree the smell is terrible, so a good clean up is needed but this solves the problem immediately!
Kind regards,
Mike
Aug 14, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Zanussi zk73/46ef freezer working fridge is warm
Feb 09, 2008 | Refrigerators
Smell
Our refrigerator had a strong smell and it was freon leaking into the frig.
Jan 27, 2008 | Amana SXD524VW Side by Side Refrigerator
Zanussi ZEBF277W Bottom Freezer Refrigerator Logo
224 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
