Mona again ok, it's been 24 hr now... and l re-screwed all the screws... l was not able to take off the back cover, but l hope that l was able to at least let it "breathe"...? should l try and power it up again or wait longer?... especially since it's coke, l am very worried because of the sugar in it... l started an experiment and placed a drop of coke on a piece of plastic just like the laptop and see when it dries... it's still sticky... if it would be the same inside... should l wait until it's all dried up...?
  • 44 Answers
Glad to see its working for you
Posted on Jan 08, 2009
How to remove back cover of viewsonic VT2430
Download the service manual from here:
http://elektrotanya.com/viewsonic_vt2430-1m_vs12335-1m.pdf/download.html
Apr 28, 2015 | ViewSonic VT2430 24"" LCD TV"
Taking off cover
Sometimes there are screws at the very back of the unit that hold the top cover on.
Feb 26, 2014 | JVC HR-A591U S-VHS VCR
I have a Sony Trinitron WEGA TV 21", Model- KV-HP212M83, brought 4 years back and till now not a single problem. But today morning when I power on TV, it is not getting on. I checked all my power...
If your plug points are getting power, then follow as listed below.
Open the back cover carefully. identify the screws with a torch light, remove them.
You may have to remove two screws holding the audio video socket panel. This
is in the back panel. TV weight is on the front side. Hence guard it. By chance
by applying pressure on the screw driver it may fall off!!
Follow the power wire and check the fuse. It may have a small cover where the
fuse is secured. Remove the cover and take the fuse out.
Just view fuse in light. If the wires are parted apart, replace it. same type and rating.
Oct 08, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Where is the fuse. No power
Hello there:
In order to get to the fuse you will first need to remove the outer cover this is done by removing the 6 or 8 screws that are on the back panel the screws that are along the edge .
Next remove the screws that are on the sides there should be 2 or 3 per side.
Next the cover should slide to the rear about 1 inch then it should lift off from the rear and up once the cover is off look on the side and you will see a circuit board that has the fuse on it now simply remove the fuse and replace it with a new one
NOTE### MAKE SURE THAT THE FUSE IS THE SAME MEANING WATAGE ECT OK
once the fuse has been replaced plug in the microwae and see if it now works and if so great just put the cover back on and you are in buisness again but if it still doesent work you may have a inverter problem this is the part that gives the microwave its power ok
Hope this has been very helpful for you
Best regards mike
May 24, 2010 | Whirlpool GH7208XR Convection / Microwave...
Both controls are at warmer setting but refer and freezer side still get`s to cold and coils ice up after couple days and have to hand de-frost
the A D C adapitve defrost control has failed and will have to be replaced . . the coil frost over when a defrost cycle doesn't happen every 8 hr of run time.. this control is located in top of fresh food side at the top in the back two screws hold it to the top cover . about 1/2 hr job / a d c is a pc type board in a plastic case . **** hope this helped ..
Jan 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
How to set time Casio W-89H two button watch
Actually, the watch has 3 buttons -- "Light" being the 3rd one. Press Mode until a number in the time mode begins flashing. Then press the Light button to get it to the hour indicator. Use the 12-24 Hr button to set it to the current hour. Then press the Light button again to get it to the minutes section. Again, use the 12-24 Hr. Button to set it to the next minute coming up in the current time. Then push the Light button again. This will bring up the seconds indicator. At the precise time the minute you set before begins, hit the 12-24 Hr. button, and the indicator goes back to zero and begins ticing away. Then hit the Mode button again until the watch is in the current time mode. Hope this helps. I use Internet time to set a precise time.
Jul 17, 2009 | Casio Watches
Loose handlebars
Easy 1 min job but an hr taking chrome off. Here is the readers digest version. Start with the headlight off first screw under light on chrome trim. then pry it off. unfasten the screws holding light on about 7 screws, then unplug light. their is a chrome piece on the top of light chrome has a nut holding it on take nut off then lift that piece off. pop the piece of plastic off the key hole it prys off two screws under it remove them. that piece of chrom has a screw in it in front of handlebars you uncovered it when you took that chrome cover piece off. JUST loosen it. Now im sure you took off your windshield before you started so now remove your bolts that hold on the quick release windshield on both sides. Your chrome nacell will now split apart to show your 4 bolds that lock down your handle bar. See I told you 1 in job but hr to take off the samn chrome. When you put that ling cover piece of chrome back on ..NOT To TiGHt or it will snap the piece the plastic goes on. Hope that helps.
Jun 19, 2009 | 2004 Harley Davidson FLHRS - FLHRSI Road...
Ramona
Sorry if there is still a sticky substance on the swith use cotton swabs and rubbing or denatured alcohol to clean get a can of pressurized air from walmart and blow any excess off. Again I apologize about the delay.
Jan 07, 2009 | Computers & Internet
Sony Ericsson Mobile
OK.
I wouldnt recommend it but...
Back..
Two rubber screw caps on the top, remove them to reveal 2 T6 screws
Front...
Under the walkman label are two more screws.
Then front cover should just come off.
see: http://www.youtube.com/watch?v=UR8mqXd4Jrw
Hope this helps! (If it does pls rate me) :-)
Sep 28, 2008 | Sony Ericsson Walkman® W880i Cellular...
JVC HR -J655EK Video Stuck
Hi hannah. The simplest way to remove stuck tapes is to remove the top cover. Usually just a couple of screws. Then remove the stuck tape and put the cover back into place. You can also look for emergency eject hole and insert a snall pin into the hole and attempt to eject the disc while repeatedly twisting the pin inside the hole.
May 16, 2008 | JVC HR-J461MS VHS VCR
Computers & Internet Logo
David Payne
David Payne
