Question about Fedders D Chassis A6D24E7A Air Conditioner
Compressor runs all the time
Hello, Suddenly (while running) the compressor on this unit runs all the time-does not cycle in and out-even when the power is turned off on the panel--lights on unit and fan are off but the compressor keeps running--power must be cut to the unit to shut it down completely--this unit has already had the circuit board control panel replaced (different symptom) ?I suspect that this unit may have control panel board problems in general?is this correct? I am suspecting the circuit board control panel again or maybe some sort of relay switch?any help is greatly appreciated?I can e-mail pics of inside of unit to assist in any parts ID that may need replacement. Thanks, Ben III 863-683-2054
  • Ben McConnell May 30, 2008
    The above poster is correct about the relay--replace the board--take a photo of the connections first--not too hard of a job.
    Ben III
  • CLUBKEV4U May 11, 2010
    I HAVE THIS SAME UNIT AND T6HE COMP RUNS FOR 5 MIN AND THEN COMP SHUTS OFFF FAN KEEPS RUNNING AND BLOWS HOT AIR IF I TURN OFF THEN ON IT WILL BLOW COLD FOR 5 MORE MIN THEN COMP SHUTS OFF
  • 236 Answers
The miniature relay that supply to your compressor stucked, it never open even if the power is off.
Posted on Jan 04, 2008
24ABR348A0031010 compressor starts then stops. Carrier 4 ton R22 unit. Worked great, then fan runs all the time. Compressor will start for less than a minute, then stop. Basically compressor will not stay...
Hello RR Hard start can't hurt BUT dosen't sound like the problem.Do you have a scroll compressor?They don't need a kit.Does it start every time?It could be short cycling on LOW PRESSURE SWITCH.If the unit is (pumping down) during the run time you have a restriction in the system.Make sure the service valves are open ,do you have a filter dryer colgging up or a bad TXV valve also could cause short run times.20-30 PSI the switch cuts out.
Jul 15, 2010 | Carrier 38BRC036 Air Conditioner
My compressor suddenly quit cycling what went wrong?
hi there!
there are several factor on cycling failure, most common on it is the pressure switch device,checking on this,plug out or switch off main circuit breaker for compressor, disconnect pressure switch if this is a single phase connection,there are two supply wire coming in and two wire coming out on pressure switch.direct connection of compressor motor on power supply to test if it is cycling manually,after direct connection of motor compressor to power supply w/out pressure switch,switch on for 5 to 10 minutes o build a low [pressure then swict off again,then switch on again even there is a low pressure observe if there is cycling motor running if this done replace pressure switch.if still have same problem motor tripping another case not to cycle bring this to electric motor service center.have a nice day dont forget to fix my rate.
May 07, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
Freezer fan runs for hours
When compressor cycles off, your freezer fan should shut off as well !
Freezer fan should not be spinning while compressor off.
You might need a control board replacement, that controls fan.
If you are talking about compressor run time, that is a bit excessive, usual causes are dirty condensers but you say they are clean - are your condensers at the bottom of the unit ? If so make sure the condenser fan next to the compressor is running too, blowing air ont he condenser.
Sep 26, 2009 | GE Refrigerators
Kenmore AC compressor on and off while outside unit fan running
If the out door fan keeps running and the compressor cycles off that would be the overload in the compressor.
What keeps the windings cool is the refrigerant back to the compressor.
For the overload to cycle it would have to be either not enough cooling back to the compressor or high amp draw, which could be the metering device (txv or orifice) or low on charge, or other things would be a bad capacitor, sometimes a bad start relay not staying open, when compressor gets up to speed or anything causing the compressor to draw high amps.
To check the refrigerant, he needs to check the superheat at the compressor it should be appoximately 12° to15°, and next time the compressor goes off if you shut the power off and feel the top of the compressor and if it's hot 130° or higher it's probably refrigerant.
Aug 14, 2009 | Heating & Cooling
AC/Heatpump units cycle numerous times blowing ambient air.
If the compressor never kicks in, I would check the start capacitor, thermostat and the compressor windings. Most times the start capacitor is defective. Some window air conditioners the fan will run while the compressor stop through the thermostat switch. If the thermostat switch is bad every thing runs except the compressor. Let me know, Thanks, Sea Breeze
Feb 07, 2009 | Dometic Rooftop RV Air Conditioner
Coleman rv a/c
It is definitely with the compressor. It should more like you may have a weak winding in the compressor, you can a hard start capacitor (sp5 ) that will help the compressor on restart. Note that this is a last chance solution for a compressor.
Oct 01, 2008 | Coleman Mach 15 Air Conditioner
Refridgerator compressor cycles on for 6 seconds then off for 1 minute
it sounds like a bad:
  • ·       start switch (on the side of the compressor) or
  • ·        compressor itself
the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
·                                 so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Jul 10, 2008 | Refrigerators
Compressor wont start
It is probably a failed run capacitor for the compressor. Without the capacitor, the motor can't even try to run, but it will draw extreamly high amperage until it trips the thermal overload (avarage trip time 5-10sec) after it has a few second for the safety to cool off, it will try again. Either that or the compressor truly is seized
Jun 22, 2008 | Coleman Mach III Air Conditioner
Fedders D Chassis A6D24E7A Air Conditioner Logo
415 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
