Question about Smeg 24 in. DWD612SS Built-in Dishwasher
Dishwasher not working
Hi, l cant get my dishwasher to work. control panel lights go but not water coming in or sound.
  • 155 Answers
Try this first is there still water in dishwasher if so your water pump is blocked or failed.
second check your tap connection has it got a flood lock device fitted to hose if so will have to replace hose.if none of these help you may need to replace pcb in extreme cases.
hope this helps.
Posted on Mar 27, 2009
Samsung DMT - 400 delicate light blinking
please follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Fagor LF 65IT beeps 4 times a few minutes after switching on and all lights flashing on display
This is a flood warning. You must have water in the bottom of your machine which has raised the float and activated the flood switch. Open the lower front panel on your machine and for where the leak is coming from.
Apr 03, 2012 | Fagor LFA-65 IT Dishwasher
My LG Stainless steel dishwasher will not run. The interior light is on but the buttons do not work. If I reset the breaker, the panel lights up on pressing power but it then powers off.
Hi
If their is a beep sound and it is from the dial not from the bottom where the motor is so the issue seems to be with the Timer/control board going bad and should be replaced to solve this issue. However, you can unplug the unit and then blow some air with the help of hair dryer before replacing the Timer motor/control board. If the sound comes from the motor area then it is the motor that should be replaced. When the motor goes bad it will fill with water and empty. One more thing to check will be the door lock-switch assembly, because if the control detects door not locked it won't run cycle and will just drain the water out. Hope this helps...
Daniel
Jan 06, 2011 | LG LDF6810ST Stainless Steel Built-in...
When a setting is chosen it makes a humming sound and stops water does not run or drain.
Hello & Welcome to FixYa
If the hum sound is coming from the bottom panel then it is the moto that has gone bad and needs replacement. However, if you hear the sound from the control then it can be due to a bad relay in the control and it is recommended to replace the control completely. Please get back to me if you have any other questions.
Kevin
Dec 12, 2010 | Maytag MDB7100AWB Dishwasher
Water filling problem
change the input water hose to bigger size
Dec 19, 2008 | Neff 24 in. S4443 Built-in Dishwasher
Sounds like water....dx doesnt work
2H means the machine is taking longer than 99 minutes to run a cycle. Start the cycle and wait 5 minutes, then open the door. If water doesn't look like it is spraying out the wash arms or slowly coming out the wash arms, then check to make sure the filter at the bottom is clean. If clean, then sounds like your circulation pump isn't running or impeller has came apart.
Dec 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
No water in dishwasher
You need the check the water level switch which is located on the diaphram of the water fill assembly. This is located on the laft side of your machine behind the metal panel. if this switch sticks it will not allow water into the machine
Mar 03, 2007 | Bosch SHU9915UC Dishwasher
Problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Jan 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Smeg 24 in. DWD612SS Built-in Dishwasher Logo
311 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
