Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Please help - camera will not focus
All of a sudden my camera will not focus and makes a tiny noise when I turn it off and on. There are no lines in the pictures, just blurry. I reset the camera but it did not help. Please somebody help me, my hubby is going to blame me :(
  • 2 more comments
  • anissa gooch May 30, 2007
    Also it has not been dropped.
    Just checked and it is on auto not macro. Any more ideas?
  • ArykahUofA Nov 03, 2007
    Identical problem. Makes the same noise when it turns on. Won't focus. Happened all of a sudden, and we haven't dropped it. I am worried about sending it in to Casio because of what people have said about them always blaming the customer - the camera has a minuscule scratch on it, so I'm sure they'll take that as evidence of mistreatment, even though we've never dropped it. What should I do?
  • Anonymous Feb 27, 2009
    yea right now i am having that exact same problem the dude said it would be like 150-200 dollars to send it in and is isnt a garentte if it will be fixed! i would recommend trying to fix it yourself...or getting a new one!
The problem is definitely with the gears.
I spent a few hours disassembling it and examining the problem - I took pictures of the major things, and I'll probably make a quick write-up.
Important things:
1. DO NOT touch lenses with anything! Scratches, dirt, smudges - all will really mess up your pictures. Use a q-tip and rubbing alcohol to clean.
2. Be Very careful with the ribbon cables - They are thin and fragile. (for example, in pic 4, you can see how I unscrewed the CCD and focus mechanism, flipped it over, and screwed a screw back into the chassis to hold it still so I wouldn't stress the ribbon cable that's wrapped intricately around the chassis & zoom motor. My tool [covered in lithium grease] is on the screw I'm talking about])
3. Be VERY careful with the ribbon cable socket clips. They are very similar to what are in Ipods and such, and I've broken one off with very little force. That latch breaks, you can either consider the camera a total loss or spend HOURS clamping the cable down somehow, only to have it come loose since the CCD chassis does not screw to anything, it is just compression attached to the body.
Really, just work the gears some with a small tool, Treat the whole thing as delicately as possible, clean the screw gear and put some grease on the gears - will be much smoother and probably better than new.
This camera was abused, it's been dropped, etc, and had glitter all in it. It was my girlfriends.
http://www.bitcore.org/stuff/Casio_Exilim_Fix/
-- Bitcore
Posted on Nov 09, 2007
  • 34 Answers
It's the focus motor gears. They have been knocked out of alignment, and the noise is the tiny focus motor spinning. The lens will need to be disassembled to fix it, but it is fixable...unfortunately, you probably won't get help from Casio.
Posted on Aug 09, 2007
    Genius:
  • 2,985 Answers
Have you got it set to Macro[very close work]? check you setting and the manual.
Posted on May 30, 2007
  • john ash
    john ash May 31, 2007
    Well it looks like the lens mechanism has become defective.
    Either all by itself or it has been knocked.
    So it could be a repair shop job.
    You could run it through the other settings and back again to see if it rights itself.
  • 3 Answers
I think the tolerences inside the camera are really tight and the case might have been tweaked. take out all the tiny screws holding the camera together. pull off the case 9leave battery and card in). operate the camera and see if the mechanism frees up/camera operates normal.
Posted on Jun 28, 2007
Whatever you do, don't send the camera to Casio America, Inc. in Dover, NJ. They ALWAYS claim the camera was abused. Then they try to get you to BUY a reconditioned camera!In the future, stay away from Casio products! THEY ARE A COMPLETE RIP-OFF.
Posted on Aug 23, 2007
How to fix my camera
Without having someone inspect the camera in person, it sounds as though a fault/defect has developed with the lens focus mechanism...that's about the only thing on this camera that's likely to make such a noise.
The first thing I would check is any focus options you have set in the menu. For example, is the camera set to continuous focus? That could keep the lens motor going constantly. If available, see if you have an option for spot focus or manual focus and if so, try setting it...that should, in theory, turn off the focus mechanism (and eliminate the noise).
If that solution don't help, unfortunately it may simply be time to replace the camera. The Finepix S3000 is an older 3.2 mp camera, which by today's standards is something of a dinosaur. Used, they're only worth $50 or less (I've seen a couple for as little as $15), so they're not really worth much effort at repair. Fuji makes some fine cameras, however like so many modern electronic devices today, they're simply not designed for longevity.
Mar 23, 2016 | Fuji FinePix S3000 Digital Camera
All of a sudden i went to turn and had no power in the steering wheel. Have noticed something is leaking into the driveway under the passenger side of the car. When turning the wheel it makes a loud noise...
Thats going to be the rack & pinion steering gear or the power steering pump. Have them checked soon! It can jam while driving and can ruin your day!
Aug 28, 2011 | 2001 Ford Focus
Just received my new Kodak Easy Share C142. It makes intermitate noise when it is turned on. I just put the batteries in that I received in the box so I assume the batteries are good. I have also turned...
This noise your hearing is probably the auto focus (AF)
But please confirm what type of noise you hear, update me with this information.
thanks for using fixya.com please do make sure you leave positive feedback and ratings.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2010 | Kodak EasyShare C142 Digital Camera
50% of the time, the camera focus does not operate. When the camera is turned on it makes a funny noise and view finder shows it is out of focus. Has it died!! Help, please. Ruth
hello ruth. you will have to take your camera to a camera shop and have them clean it and tune it for you. get an estimate first and then decide if it is better to do the repair or just replace it. good luck.
Oct 15, 2009 | Olympus Stylus 710 Digital Camera
55-200mm VR focus noise
The lenses have a focus motor built into them.when the camera is set to auto focus, once you press the shutter button, the motor activates to set the correct focus. VR is for motion stabilization. Turn off AF on lenses and camera and see if noise stops.
Dec 12, 2017 | Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
The lens is blurry and makes a buzzing noise when turned on
Well all the moving parts of the lent are plastic and most likely the reason Y you hear that sound it's because one of the hummmm the tiny wheels , that are connected to the mechanism of the focus on the lent is busted..... so replace that.
(some times if you take the camera to the beach the sand get to the mechanism ans stock the wells. In that case cleaning of the lent will suffice)
Now parts are not that easy to find some times companys only sale the complete lent and it will cost you, in that case you will need to decide if "REPAIR" or "BUY NEW" camera will be better
Jul 13, 2008 | Casio Exilim EX-Z77 Digital Camera
Auto focus
there should be a tiny little switch on the lens that shows 'AF' and 'MF'.  Make sure it is on 'AF' for auto-focus.  Also, is the lens rotating and locking fully?
Oct 11, 2007 | Nikon D50 Digital Camera
Blurry pictures, beep-click noise
Angie, You can call the repairs dept and they can give you a pretty good idea over the phone of how much it will cost. Their number is 800-706-2534 and then keep choosing option 1. They might ask you to send it in so they can look at it but they will send you an estimate of what it would cost to fix it before they do any work. If your camera will stay on long enough you can try resetting the camera but I doubt if that will do anything.
Jul 09, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Soft clicking-grinding noise
i think that you have the full-time auto focus on.
go into the menu and turn it of and all should be fine.
seekreep from Edinburgh - Scotland.
Jun 10, 2007 | Olympus C-7000 Zoom Digital Camera
C-8080 out of focus at all times
Here is the link to the manual; http://www.olympusamerica.com/files/C8080WZBasicManual.pdf Check page 31 - "focus lock" - it sounds like that could be your problem. Hope this helps, please post again if you need more info :)
Nov 13, 2006 | Olympus Camedia C-8080 Wide Zoom Digital...
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
3,068 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Starnley Johnwells
Starnley Johnwells
Are you a Casio Camera Expert? Answer questions, earn points and help others
