Question about Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD HDTV
'No Signal' on Sony XBR
Suddenly when we turned the tv on we noticed a black screen. About an inch from the top there is a ligh blue bar running across the whole screen and on left side it reads 'No Signal' and on the right side it says 'C611'. Channel 611 was the last one on ! I've unplugged the cable box completely - nothing happens. I'm wondering if something on the remote got pressed which re-set something ? Please advise
On the tv remote: press menu, external entry is highlight (yellow) right press on the outer circle then scroll down to video 4 (satellite entry) (it could be on video 3 depending of the satellite assignment entry) when video 4 is highlight (yellow) right press on the outer circle on the screen you will see 1080i if settle on an HD channel hope it will fix your Sony Bravia..
Posted on May 30, 2007
I have astron tv 14 inches. when i connect outdoor antenna the. tv screen turn black. no signal. no reception but when i disconnect the outdoor antenna it turn to blue screen.
blue screen means 'no signal' or 'signal level is too low' whereas black screen means that there's a signal. Check your antennae, do a factory reset to your unit and then try initial setup.
Feb 26, 2015 | Televison & Video
I was watching a dvd on my week-old Sony Bravia XBR-52HX909 for the past three hours when the screen suddenly went blank. The standby indicator light in red started blinking. I attempted to turn on the...
This tv only a week olds,should never having this problems already.The tv should be return and get a new tv for the replacement,this tv have tv Tuner signal board or tv power supply board distrubution problems.Even when the store test it out it work,don't take that tv back.Insit they give a new tv for the replacement.
Dec 13, 2010 | Sony Bravia XBR-52HX909 52 in. LCD HDTV
Blue line across top of my Sony XBR 60
KDF-60XBR950 replaced bulb, but no picture. It DOES have a solid green light when on.
Jul 21, 2009 | Sony Televison & Video
BRAVIA - Information bar on top of screen won't go away
You can turn off the information display using the user menus.
also hitting the display button should make any and all OSD information go away.
Jul 09, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Jun 26, 2009 | Samsung LN32A550 32 in. LCD TV
Lines in screen
They are stuck pixels...
There are some that say sending strong images that change from to color to color can help unstick them, but I say only dissassembly and cleaning of the contacts (there should be 2 ribbon cables, one for top, one for side) that probably got dust in it. Call it in under warranty if at all possible.
Apr 19, 2009 | Sony KDL-52XBR4 LCD Monitor
Sony Videoscope XBR TV
just need to balance the three colors red,green and blue that may help remove the front covers and look for black module that have sccree and focus controls just move a little bet left or right be carefull because you can loos the picture e-mail me for more info
Apr 07, 2008 | Sony KP-53XBR45 53" Rear Projection...
SONY xbr screen problem
It sounds like one of your circuit boards may be going out. I'm sorry I don't have a better response than that.
Jan 20, 2008 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony 57 Inch XBR 2001
I don't have the XBR, but on my sony, using the cable box remote, I had to go into menu/display/etc. and mark the 1080i, 720p, and 480i settings. you usually get a "if you can see this" comment if your tv accepts the settings. for standard tv i set the screen to normal, and when the upper channels go to HD, they auto go to full screen. Sounds like you are using the component cable, and also make sure you are on the video port of remote, and the the TV input. The above worked for mine. Hope it helps.
Dec 04, 2007 | Sony KP-57XBR10 57" Rear Projection...
Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD HDTV Logo
409 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
