Question about Maxtor One-touch III Mini 40 GB USB 2.0 Hard Drive
Maxtor won't allow me to delete files that are no longer on my XP
I can't delete files from Maxtor that I already deleted from My XP computer. When I click on the drive that Maxtor is connected to, I only get a small portion of the directories coming up. Not the ones that I want to delete files from.
  • K0025805 Feb 07, 2009
    Hi
    I have a similar problem. I cannot delete any files from my maxtor portable drive (200GB)
    Where is the logic here? There are no instructions coming with the drive either... There must be a way..
    Do I need to refigure my laptop or pc to do so?
    I woud be grateful for advice.
    Gemini
    Problem Solver:
  • 14 Answers
You might not be able to see the hidden files... If this is the case you can enable XP in order to view them as follows.....
Windows XP and Windows 2003
To enable the viewing of Hidden files follow these steps:
  1. Close all programs so that you are at your desktop.
  2. Double-click on the My Computer icon.
  3. Select the Tools menu and click Folder Options.
  4. After the new window appears select the View tab.
  5. Put a checkmark in the checkbox labeled Display the contents of system folders.
  6. Under the Hidden files and folders section select the radio button labeled Show hidden files and folders.
  7. Remove the checkmark from the checkbox labeled Hide file extensions for known file types.
  8. Remove the checkmark from the checkbox labeled Hide protected operating system files.
  9. Press the Apply button and then the OK button and shutdown My Computer.
  10. Now your computer is configured to show all hidden files.
Posted on Jan 08, 2009
I was looking for a manual for my Maxtor one touch III - 500 GB - s/n 2cav32oh - I don't know how to remove any files from my Maxtor in order to free up space. Thank you I'm not sure if I received a manual...
Double-click My Computer. Double click on the removable drive. Double click on the name of the backup? Double click on C. Double click on Documents and Settings. Double click on HP-administrator? Double click on Desktop. Keep or delete what you want. Click the Back button. Double click on My Documents. Keep or delete what you want. Hoe I remembered it all ok. Let me know if you need anything else. Nice talking to you Pauline :)
Feb 08, 2010 | Maxtor One Touch III 500GB FireWire/USB2.0...
How to format maxtor 80gb hard drive
Insert the drive into the bay and connect power and ribbon cable.
Go to Start > Control Panel > Administrative Tools >
Computer Management > Storage > Disk Management
Right click on the drive, click Mark Partition as Active then Format.
In this day and age, it's always best to format to NTFS file system.
Nov 06, 2009 | Maxtor Hard Drive
Problem open up my maxtor one touch 500gb to retieve photos
first, recover your files. You will need to use hard drive deleted photo recovery program like Asoftech Photo Recovery, you can follow this video to recover deleted photo
http://www.youtube.com/watch?v=sNxApz_PBW8
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Sep 09, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Cannot delete files from Maxtor Hard Drive on Mac
Hi Simon Is there a problem deleting or is it that you just don't know how to do it?
If it's the former you need to supply a bit more info. If it's the latter then it's very easy.
Highlight the file you want to delete, right-click and select move to trash (second item down).
This moves the file to the trash but doesn't delete it.
Next you can right-click on the trash icon in the dock and choose Empty trash or go to the finder menu and select empty trash from there. After that your files should have been deleted from the maxtor.
Simple eh?
Aug 13, 2009 | Maxtor Hard Drive
I can't delete files from my Maxtor 3200 external hard drive
The other comments are not the easiest way to free up space on the drive. The reason you aren't seeing a change in free space is because of a drive error (probably unplugged without unmounting). So First open up disk utilities and fix the hard drive (should only take 1-2 min). After the drive is fixed select erase free space (zero out data is fine for now). This usually takes about 20 min for me with a 120 gig hard drive. This allows you to have the free space without having to move all of those files around (which for me would be a problem because I have 100 gigs used on my drive, which would take forever).
Jun 20, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Can not delete anything on maxtor basics 160gb
Open the drive through My Computer and right click on any file folder hat you want to delete. Choose Properties. When that screen opens, uncheck the box next to Read Only, click Apply, then Ok. See if you can delete the folder. If that works, then you will have to do that for every folder/file that you want to delete.
Feb 01, 2009 | Maxtor Hard Drive
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Does maxtor 3100 storage automatically add file to itself?
Yes, it is wise to do a house cleaning on your Maxtor. Whether you delete everything or not is up to you. However, do not do this by formatting the hard drive.
If you find you need a file later you deleted from the drive, a free program called 'FileScavenger' can recover it for you. If you format the hard drive the ability to recover a file becomes highly unlikely.
We techs have expensive software to recover files should you need to get it retrieved, but the interface is designed for techs and not the average user.
Regards,
Worldvet
Jun 08, 2008 | Maxtor Personal Storage 3100 (M01E100) 100...
Maxtor one touch iii mini
You have a possible corrupted file. Open My Computer and right-click the drive icon. Click PROPERTIES in the menu. Click TOOLS. Click CHECK NOW. Click a check into the AUTOMATICALLY FIX FILE SYSTEM ERRORS box. Click START. The OS may tell you a reboot is required.
If all else fails, dump the data to some other storage device and use DISK MANAGER to delete the partion, make a new partition and format.
Nov 29, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Open Questions:
Having issues on Acer Product ' call +1888784-9316 Care Number 24/7 Helpline Acer is a Taiwan-based electronics multinational that is best known for its computer products, although it also produces other consumer electronics such as personal digital assistants and mobile phones, as well as computer-related products such as servers and storage devices. Acer has ruled the consumer electronics market because it has the most innovative approach. Acer laptops are famous for their energy efficient performance with long lasting battery life, high portability due to the laptop's light weight construction, along with the added features like high speed Bluetooth and wireless connectivity and also wide screen display that provides exemplary image quality with higher resolution. Because of all these and many more qualities acer support have made it to the top of the list of customer's choice for best laptops. But its users might face some issues from time to time that could prove to hinder their important work and so, to prevent this, we have a team of technically superior and experienced technicians who can be contacted anytime on our toll free call acer tech support number. Issues faced by Acer customers:- • Black laptop screen issues • Stretched images on laptop screen issues • Laptop heating up followed by forced shut down • Window update issues • Crashing issues in acer computer support • Windows 10 upgrade problems • Computer Tune up issues • BIOS update • Virus removal issues Call on our Acer support phone number acer customer service and get all these issues and many more related to Acer laptops, addressed by our technically advanced and experienced support team members. Our Services: If you have any query or issue related to Acer laptops that you want to get resolved in the most efficient way possible by some of the greatest minds in this job with highest levels of experience then contact us on our toll free Acer support phone number. Contact our technical support team for any assistance regarding issues concerning Acer Laptops by Calling on our acer technical support phone number. Get all your troubles sorted out in a matter of few minutes by most courteous and experienced technicians.
Jun 18, 2018 | Acer Computers & Internet
See all Maxtor One-touch III Mini 40 GB USB 2.0 Hard Questions
Maxtor One-touch  III Mini 40 GB USB 2.0 Hard Drive Logo
350 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
