Question about Durabrand DUR85
Problem with Dur7 Portable DVD
I have a Dur7 portable DVD player that plays CDs perfectly but has stopped recognizing DVDs. It seems very odd. We lost the remote to the thing a while back and was wondering if anyone has ever experienced this and fixed it. Thanks
SOURCE: Screen is completely black
There is a switch on the right side of the unit labelled Video Out (switch facing front of unit) or TFT On (switch facing rear of unit). First make sure that the switch is on TFT on. If it is then switch to Video out and then back to TFT On. This made our screen starting displaying again when it was black.
Posted on Mar 29, 2007
  • 40 Answers
SOURCE: No sound coming out of the Portable DUR7
is it from the tv no sound coming it mabe be due to faulty cable or due to the wrong connection to the tv do check the Manuel for the connection there is no problem with the dvd player
Posted on Jul 03, 2007
  • 291 Answers
SOURCE: Durabrand 7" Portable DVD Player DUR7
The charger=look on side of durabrand where power plug should go.there s/b somethine like [C+] or[ c-]
it is not really the letter C but the symbol of the outer rim of the plug that goes into DVD player.[C+] means that the outer shell of THE PLUG is negative (-) with the INSIDE being positive (+) with respect to a battery. [C-] again, the outer connection is (+) pos., inner connection (-) neg.
Look for power rating, as an EXAMPLE ( 5v at 1.5a [5 volts at 1.5 ampers]
Posted on May 22, 2009
  • 12 Answers
SOURCE: I am seeking the owner's manual for a Durabrand dur7 portable dvd player
you can find it here:
you may have to pay a small fee though...
please rate my solution
Posted on May 31, 2009
  • 3866 Answers
SOURCE: portable durabrand dvd wont read disc
If it is reading a burned movie from the internet make sure you set you brun software for captability mode.
If this is a orginal disk make sure its free of dust and scratches.
1. buy a lens cleaning kit from walmart or any other eletronics store.
2. Make sure the disc is free of scratches.
3. change disc's and see if it works on any others.
if these steps do not help then the laser would need to be replaced. Durabrand is a Wal mart brand i had mine for 2 years and i had to clean the lens 3 times with a cleaning kit.
Posted on Jul 17, 2009
Solved the problem by cleaning lens with plain water on a cue tip. Wasn't sure if a special solution was needed, but water did the trick.
Posted on Jan 31, 2010
0 characters
1 Points
My Sony DVD/VCR combo will play cds but not dvds. I took the top of the player off and I can see that the dvd spins but it won't play. It used to play everything very well but just stopped working...
Please clean laser lens with good quality cotton bud gently and check dvd disc playback, if still does not play, replace optical lens block.
Let me know model number of your Sony DVD-VCR combo to provide you optical laser block part number info.
Nov 15, 2009 | Zenith DVP615 Portable DVD Player
Will only play cd not dvds. lens turns red . plays dvd then stops by itself but no problem with cds
This sounds very much like a laser problem. ALL DVD players have a dual laser (one for CD other for DVD). It is very likely that the DVD laser has gone defective that is why you can only play CD's.
Another thing you can try is to clean the laser lens using isopropyl alcohol and a cotton bud - laser may be dirty/dusty as this can cause problems too.
If after cleaning the lens you can still only play CD's, then the laser will be defective. This will be an expensive repair job therefore it's cheaper to buy another unit.
Sep 12, 2009 | Durabrand DUR7 Portable DVD Player
Won't play DVD's but will play CDs
I suggests to try another dvd dics maybe it is not compatible to your player. try universal dvd dics...
Apr 16, 2009 | DVD & Blu-Ray Players
Plays cds but not dvds
If the lens is clean (clean with cotton swab and alcohol), then the optics are failing. DVDs require more power and accuracy to be read than CDs. The ability to read CDs but not DVDs is usually a good indication that the optics are starting to fail.
Feb 18, 2009 | DVD & Blu-Ray Players
SRD4900 Sylvania DVD/VCR Combo
Well first of all, why the hell would you press play when there was nothing in it???
Feb 01, 2008 | Durabrand DUR7 Portable DVD Player
CH-LDV 700B Portable DVD Player
check if the dvd player is compatable for mp3 and cds. also make sure the cds not copied try putting in a now 67 cd or something like that
Aug 12, 2007 | Cyberhome CH-LDV 700B Portable DVD Player
Durabrand DUR10 not playing
Less than a year old - take it back and get it replaced
May 21, 2007 | Durabrand DUR7 Portable DVD Player
Portable dvd player will play music cds but not video dvds
Chances are, your DVD player uses one laser to read CDs, and a different laser to read DVDs (since Cds and DVDs are read at different wavelenghts of light). If the DVDs you're trying to watch work properly in other DVD players, it probably means that the DVD laser is dirty, damaged, or burned out. Though you can try cleaning the laser (use Google for suggestions on how to do this, or check the Audiovox website), you will most likely have to get the DVD player repaired, or buy a replacement. Many of the newer CD/DVD players sold today use a single combination laser, which reads both CDs and DVDs, which means that when the laser fails, it will not work at all. Wish I had better news for you, but I guess that the only consolation you have is that your Audivox player still works with CDs...
Apr 01, 2007 | Audiovox D1812 Portable DVD Player
Durabrand DUR85 Logo
22 people viewed this question
Top Durabrand DVD & Blu-Ray Players Experts
 Mike M
Mike M
Gil Shultz
ray gallant
Are you a Durabrand DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
