Question about Toshiba 32HL95 32 in. LCD TV/HD Combo
No picture using component on Toshiba 32HL66
I have a new 32HL66. If I hook an XBOX 360 to the component input it works fine. If I hook up a PS2 or my Pioneer DVD player through component I can only get sound. Both the PS2 and the Pioneer work fine using component on my Hitachi CRT. Any help would be appreciated.
  • Ronald Smith May 30, 2007
    Thank you very much for the suggestion. I will check the tv manual again for what you suggested.
    The XBOX has a switch on the cable to select HD or component and it is set for the latter.
    Scholar:
  • 52 Answers
It may be a synch issue. Make sure your component input is set for the proper type of output. Your XBOX 360 is likely set to 1080i, but your DVD and PS2 are only 480i (or maybe 480p for the DVD if progressive scan). Sometimes component inputs are 'self adjusting' to the signal, but others require manual setting.
Posted on May 30, 2007
I have a daenyx lcd tv, model DN-15, input 12VDC-4A and am trying to hook it up to an xbox 360 console.
If you are using the Red/Yellow/White cable, that's composite cable, but if you're using the one that's Red/Yellow/White/Blue/Green, that's called component. So basically, you set your TV's input to the corresponding color match. 5 colors: Component, 3 colors: Composite.
Sep 13, 2014 | Video Game Consoles & Games
No picture or sound with brand new xbox friend's xboxs worked ok
Look like ur Xbox 360 AV RCA cables is not making contact to the input board very well.Take some rubing achahol cleans the all those input holes,take the RCA AV connections make couples twises to the red,yellow and white,will help.Make contact with ur input board it should work.
Apr 28, 2010 | Zenith SY2551S TV
XBOX 360 composite output works fine. Component
You say the component video is no good? Well this usually happens when it is wired up incorrectly, Ensure you have the right colors in the right jacks at each end, it is real easy to get mixed up... make sure Red goes to Red, Blue to Blue and Green to green, all alongside each other, NO ALSO using Component you MUST also run 2 more cables for the Audio, they are Red & White NOT the Red from the "Other" Video input, BUT the AV Red & White jacks, beside each other on the units. So all in all there are 5 cables taking the Video, 3 R, G, B. + The Audio, R & W.
Mar 02, 2010 | Microsoft Xbox 360 Console
Mitsubishi WD-62627 Projection DLP TV help with PS3
To localize issue better try plugging your xbox into input for your ps3 and see what happens. You may have a bad input. Happens.
Aug 28, 2017 | Mitsubishi WD-52725 52". Rear Projection...
My xbox shows no picture but has sound
This might not help everybody but it might be a cheap fast solution to the "Xbox 360 no picture but sound ok" problem. I have old refurbished 360 that has had no problems at all. SInce I got it have used it with powerwave cooler attached to the back. This cooler has seperate Outputs for Vga, SVga, audio, component and av. Don't need the microsoft cable at all just standard cables. Always had it plugged in with VGA or SVGA cables and got great picture. I bought new 360 and put the old one in bedroom with old tv which only has av inputs. Got shocking picture that was unwatchable but sound was good. Tried all ways but no different. Seems the xbox plug has problems. If you get the powerwave cooler it splits the xbox output socket in to seperate outputs for everything so you can use it with Vga or Svga cables if your tv has those inputs and it should work fine. Only seems to be the standard AV outputs that have problems. Haven't tried the componet leads but I guess they might work as well. If you only have the old yellow, red and white AV inputs on your tv this wont help you but if you have the other types of inputs it might fix it. The powerwave cooler you should be able to buy for under $20 so it could be a cheap solution for this problem everyone seems to be getting lately. It works for me at least so get one and give it a try.
Jun 16, 2009 | Microsoft Xbox 360 Console
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
Toshiba 57H82 Blurry Pic on HD inputs except Xbox 360
Probably your G-Hyper board. You will need expert servicer and should cost about 3-400.00
Craig www.classtorations.com
Jun 08, 2008 | Toshiba 57H82 57" Rear Projection...
Xbox 360 or Dish ViP 622
when i hook either my dish hd receiver up to the 1080i component video inputs, everything works fine if i set either device to 480p, but i get nothing i set them to 1080i.
Apr 09, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Xbox 360 hd and p56926
change back to 480 resolution and them go upscaling
Feb 20, 2008 | RCA P52926 52" Rear Projection Television
Toshiba 32HL95 32 in. LCD TV/HD Combo Logo
468 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
