Question about Brother HL 1240 Printer
Replaced drum on printer
Printer will not print. We did have a recent power outage when the printer was on.
  • 685 Answers
Have u tried to unplug it and plug it back in.try this and let me know if it works again
Posted on Jan 08, 2009
I have a Canon Pixma ip90V printer and every time the printer starts to print it shuts off; any suggestions what to do?
Sounds like it is either the power supply or the board.
Try disconnecting the power supply (unplug the printer) for about 5 minutes. Reconnect and turn it on. If this works it will probably not be a long term fix. Sounds like your in for a new printer or power supply for it soon. Did you have a electric outage recently? Or power surge?
Mar 28, 2011 | Canon PIXMA iP90v Printer
Lost connectivity after power outage
If this is a printer WITHOUT WiFi or bluetooth - and you have it connected to another computer (Print Server) via a USB cable - you need to make sure you can see that computer from the other computer you are printing from. Use the network explorer - if you can see the computer and the printer you should be able to print to it.
Sometimes, it may be secured with a password. I found if I can map a shared drive from my laptop to my print server then I can print again. So see if you can see the printer and printer server computer from the other computer. If so you may need to add that printer again to you printer list.
May 01, 2017 | Zonet ZPS3611 Print Server
Okidata C5200N printer: streaky copies on magenta
If the streaks are only from the magenta then your magenta drum is bad. If you recently replaced it, it may still be under warranty.
Jan 19, 2010 | OKI C5200n Laser Printer
I have an HP c7180 all in one inkjet printer and recently we had a power outage. Ever since that time the colors are all mixed up. After the power outage, I was getting this error message: ""Ink System has...
If your product is in warranty then I recommend you to contact HP support to service or replace the unit. Otherwise perform the steps given below and verify the results.
  1. Turn on the unit.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 7 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
Oct 13, 2009 | HP Photosmart C7180 All-In-One InkJet...
"DRUM LIFE OVER" KX-FL511
just change with new drum and toner.after replacing when msg gone just press start.u will receive ur faxes in memory.MIAN AKHLAQ
Dec 31, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Power went out and back on; now printer won't print
I had the same problem after a resent power outage. Here's what fixed mine.
Turn the power switch off.
Wait a 15-20 seconds
While holding the button on the front panel down turn the power switch on.
After the drum light comes on release the button wait then press the button again.
Turn the machine off then back on again and you should be back in business.
To prevent the problem in the future if you are not using the printer turn it off and if the power goes off while printing get the printer turned off before the power comes back.
Oct 14, 2008 | Brother HL 1440 Laser Printer
Dell 3010cn Color Laser Printing Quality
yes..it's almost certainly the drum..did you get a new one or was it simply refurbished?
Aug 20, 2008 | Dell 3100cn Laser Printer
All error lights blinking and fan running but won't print...
Yes Mr. Guest and Mr SwT,
Replace the fuser assembly unit.
Definitely the fuser got problem. This can be confirm by pressing the Go button and only the Toner LED will light up.
What had happen was right after the power blackout the fuser has fused together both rollers (heating drum and rubber roller) where the paper pass through in between the rollers. Since there was a power blackout, the printer fan has stop functioning and the heat was unable to disperse out from the printer. Suggest to improve on design to disperse heat using aluminium cage in case of power blackout.
Who ever has a Brother HL-2040 should definitely use together with a UPS.
chekamal
Apr 27, 2008 | Brother HL-2040 Laser Printer
How to correct error message sram error missing E?
Hate to say this but most likely the Print Engine Control Board has failed.
May 09, 2007 | Xerox Phaser 7300DN Laser Printer
Brother HL 1240 Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
