Question about Compaq Evo N620c Notebook
Compaq Evo n620c boot problem
I came to use the laptop one day after not using for around a month.
It did not boot up past the windows logo then goes to blue screen and restarts itself.
I have tried a different hard disk but same prob happens.
Any sugestions?
Thanks
Steve
How do I install linux on a compaq n620c?
Acquire the set-up disc for Linux. Install as you would with Windows, but instead you are now installing Linux as the operating system.
Feb 03, 2012 | Compaq Evo N620c Notebook
Download a sound driver into my compaq Evo N620c
You can download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Sep 12, 2010 | Compaq Evo N620c Notebook
My compaq evo nc620c laptop wont boot up, only goes to the "compaq" log screen from where I can go into F10 rom based setup or F12 network boot only.
Without having seen it, it sounds like a hard drive problem. Could be dead, could be the boot info has been destroyed (virus?).
ROM setup should be able to tell you more about the hard drive, and whether Setup can see it.
Apr 03, 2010 | HP Compaq Evo n620c Notebook
Wireless software
if xp use this : www.opendrivers.com/driver/.../linksys-wpc54gx4-wireless-g-notebook-adapter-driver-2.0.1.19-windows-98se-me-2000-xp-free-do
Jun 12, 2009 | HP Compaq Evo Notebook N620c
I can not install Windows on my Compaq Evo N620c
The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
May 04, 2009 | Compaq Evo N610C Notebook
Compaq n620c evo laptop
Check your floppy drive and see if there's a disk in it and remove it. If there is no diskette in the floppy drive and you are still getting the error. You can go into the Bios and turn off the "boot from floppy drive", that way it will not look for the floppy drive when booting up. Hope this helps.
Feb 27, 2009 | Compaq Evo N620c Notebook
Cannot locate ram on compaq EVO N620c
The RAM is located under a panel on the LHS of the touchpad.
You need a thin blade/knife to slip under this panel to lift it up and out. It is clipped in with plastic catches on the panel.
Dec 17, 2008 | Compaq Evo N620c Notebook
Bios menu
Most Compaq units use the F10 key to enter the BIOS shut off your notebook if it is in hibernation though you may have to shut it down fully by pressing on the stand by power button and pulling at the power notch they should be located at both sides near the hinges of the screen if this does not work remove batteries this will surely bring your notebook to shut down. replace batteries then press power then press the F10 as soon as the Compaq logo comes out. Hope this works some Compaq models nee to be realy shut down before the F10 could be accessed
Jul 12, 2008 | Compaq Evo N620c Notebook
Compaq Evo N620c Notebook Logo
474 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
